What PSI?
Discussion in 'Wheels & Tires' started by Bappa, Mar 7, 2018.
  1. Mar 7, 2018 at 9:54 PM
    Bappa
    Bappa [OP] Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I just got a new Toyota Tundra. The dealer put on coil overs and bigger tires - Toyo A/T 295/70R18
    When I got home I noticed the tire pressures varied from 39 to 48. When I looked up that tire on the Toyo website, it said the maximum pressure was 80 PSI. When I went to Discount Tire for a tire check, the guy said he couldn’t go any higher than 38.
    What’s a good pressure for daily driving?
    geno0506 likes this.
  2. Mar 7, 2018 at 11:45 PM
    geno0506
    geno0506 New Member
    Michael
    I have the same exact size tires but mine are Nitto Ridge Grapples and got them at Discount, they always air them to 38 as well, no problems here for street!
    Sunnier likes this.
  3. Mar 8, 2018 at 3:55 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Easy way to find the correct pressure for bigger tires is to make a chalk mark across the tire tread and drive in a straight line for a little bit. If it is gone the pressure is right. Have some left in the center, pressure is low. Have some on the outer edges the pressure is to high. Tire pressure will vary based on type of tire (i.e. LT vs. non-LT and sidewall construction).
  4. Mar 8, 2018 at 5:50 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    X2 for chalk test, it varies by tire
    15whtrd likes this.
  5. Mar 8, 2018 at 5:54 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    ive never heard that, great tip
  6. Mar 8, 2018 at 6:13 AM
    15whtrd
    15whtrd Mr. Blonde
    Bump the pressure up higher than you think it should be and perform the chalk test. Slowly let air out of the tires and keep retesting until you get it to where there is almost no chalk on the outer edge.
    NewImprovedRon likes this.
  7. Mar 8, 2018 at 6:25 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Did that a lot in my old hot rod days. That method been around probably longer then I been alive.
    15whtrd likes this.
  8. Mar 8, 2018 at 8:03 AM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    Call Toyo they will give you a recommendation, then do the chalk test starting at the recommended pressure and adjust up or down as suggested. Toyo's suggestion will be pretty close and their customer service is good for that kind of info.
  9. Mar 8, 2018 at 8:10 AM
    ToyotaTundraMike
    2015 Tundra
    Been interested to find out this info as well. I have 275:70:18 Cooper ST Maxx with same rating. Toyota was putting them at 36 psi for the longest time until I decided to play with it myself recently. Put the fronts on 45 and the back on 40. My average MPG almost went up a whole mpg since then but the ride is a little stiffer compared to when they were at 36. Wondering what the sweet spot is with this size.
