What options to get when buying new Tundra
Discussion in 'General Tundra Discussion' started by Tacogrande, Jul 26, 2015.
  1. Jul 26, 2015 at 9:42 AM
    Tacogrande
    Tacogrande [OP] New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Hey guys looking for some advice here. I am looking to order a 2016 Tundra SR5 double cab 5.7l 4wd longbed with tow package and trying to decide what options to order with it. I know i want the SR5 UPGRADE PACKAGE.
    Also i think i want:
    Deck rail system- Is it worth it?
    tow mirrors- are they worth if i only tow occasionally?
    running boards- I really liked the running boards on the truck i test drove. Are the factory ones worth it or is there a cheaper and better aftermarket option out there?
    Entune premium audio- actually not really sure i care about this but is it worth the cost?
    Integrated trailer brake controller- get this or an aftermarket for cheaper?
    the 5.7l with flexfuel option???
    heavy duty batter and alternator? did you guys get this?
    lot of stuff to think about. Dont want to have regrets after the purchace so looking for help from you guys.
    thanks!
  2. Jul 26, 2015 at 9:58 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Deck rail system- Yes, I like but now useless with my Undercover Flex tonneau cover.
    Tow mirrors- Yes, Love mine.
    Running boards- Yes, Tundra's, even stock are a little high. I'd go aftermarket. Cheaper and better ones out there.
    Entune- I like it.
    Integrated brake controller- Yes, I will be buying this and adapting to my 2015.
    5.7l- A must. Flex Fuel- Doesn't matter if you don't want to put a supercharger on it.
    Battery and alternator- Not necessary unless your going to be putting subs or something else that needs a lot of power.
  3. Jul 26, 2015 at 11:16 AM
    Tacogrande
    Jeremy
    Tonneau cover maybe in the future but not necessarily very soon.
    No supercharger
    No subs or anything needing lots more power. I do use a power inverter sometimes camping, jobsite or in the country but i have used it on my GMC with no problems. It is a Tripp Lite 2000 watt inverter.
    About the tow mirrors...I assume they stick out farther. The ONLY thing i dont like is that they are not automatically retractable. So i may need to get out each time i pull into the garage and fold them in. The regular mirrors are small enough i would not need to do that.
    Ford Super Duty has automatic folding mirrors why cant the Tundra?
  4. Jul 26, 2015 at 11:46 AM
    Might as well go with line-x in the bed too.
  5. Jul 26, 2015 at 12:05 PM
    mdavis
    Michael
    Rock Hill, SC
    Yes the tow mirrors stick out farther. I could see how that would be annoying to manually fold them in everyday but a double cab long bed is a long truck. You sure it would even fit length wise? My garage is about 3" too short to fit my crewmax.
  6. Jul 26, 2015 at 1:22 PM
    chphilo
    chphilo Tundra addict
    Western PA
    From what I understand, tow mirrors with the retractable feature are about twice the price of the regular ones.
  7. Jul 26, 2015 at 2:05 PM
    Tacogrande
    Jeremy
    I will have an extra 5' of space to spare when the truck is parked in my garage. Garage is directly in front of my custom cabinetshop. If i did not use my shop for wood it has enough room to park 8 more vehicles.
    On a quote they gave me, it lists the tow mirrors at an extra cost of only $50. Hope that is not a misprint.
  8. Jul 26, 2015 at 2:36 PM
    mdavis
    Michael
    Rock Hill, SC
    Man, sounds like the garage I need. For an extra $50, its a no brainer. Get the tow mirrors.
  9. Jul 26, 2015 at 3:03 PM
    I have tow/haul package which comes with the tow mirrors, hitch, higher rated rear springs, and 4.3:1 rear diff. Glad my Tundra has it all. If my tow mirrors are out too far, I just roll down the windows and fold them in. Takes a couple of seconds. I've had several people ask me about my tow mirrors and where to get them. Factory or online of course
  10. Jul 26, 2015 at 3:54 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    All of them.
    ok. flippant answer aside. It depends on your intended usage. I'd go for the tow package, integrated brake controller, tow mirrors and deck rails at a minimum, but then I tow/haul quite a bit.
    Toyota factory nav is actually one of the better systems out there, so it would be on my list.
  11. Jul 26, 2015 at 11:06 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Deck rail system: Yes if you use the bed a lot for hauling stuff like moving furniture, wood for projects or other larger items in the bed. Good spot for bike mounts too.
    Tow mirrors: I don't like the look as much as the sport ones. They do stick out further. You can get power gold standard with limited and platinum.
    Running boards: Depends on what you like and what your going to use them for. There are so many choices out there from steps to running boards to rock sliders that can be cheaper or more expensive than stock.
    Entune premium audio: Depends if you are ok with a little less quality sound and features. Or if you plan to upgrade to aftermarket speakers anyway. Depending on price I would prob skip it.
    Integrated trailer brake controller: if you plan to tow go with the stock one. Aftermarket may be a little cheaper but you will have to figure out a mount.
    5.7l: absolutely. Love the power.
    Flex fuel: No you won't use it and it's not recommended to use E85 in it from other tundra owners. If there is a price break for flex then go for it but don't pay to have the option.
    Heavy duty batter and alternator: Not needed unless you add enough electrical add on accessories like winch, off-road lights, etc.
  12. Jul 27, 2015 at 7:54 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    If you can get a non flex fuel, try to do that. There are quite a few guys out there having problems with them. I dont, thank goodness, but if it's possible to get one without, do it. Another thing that I think is weird, some people got tow hitches that were not class 5. So before you take ownership, make sure it is. I'd get the upgraded alternator and so on, just in case you ever need it and definitely the brake controller. Hell, I'd get everything you listed as long as the side steps were black.
    Black Wolf likes this.
  13. Jul 27, 2015 at 8:05 AM
    I agree. The alternator/winter upgrade is only $50/$100 or so I think. Why not get it? I know it's not much dollar wise compared to swap one out should you change your mind later. Tow Haul option will not give you the best mpg due to the 4.3 diffs. But is excellent for 4X4.
    TruckyTruck[QUOTED] likes this.
  14. Jul 27, 2015 at 8:38 AM
    53flattie
    53flattie New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    Re: the brake controller - I'm not sure if they have it sorted out now or not, but when I bought mine in May of this year, they were not offering them. The dealership said they had yet to see a 2015 with the factory controller.
    But, if it's an option now, I would go for it if you plan to tow anything with trailer brakes.
  15. Jul 27, 2015 at 10:34 AM
    TruckyTruck
    Gary
    Toyota claims they have it worked out and ready for 2016s. Sure wish there was an option for 2nd gens. I like my controller and tried mounting it where it would look professional or classy, but nothing beats the stock look.
  16. Jul 27, 2015 at 1:09 PM
    MC Mike
    MC Mike New Member
    Central NY
    2015 tundra SR5 TRD
    Fuel Pump 20x9 wheels with 33x12.5 Federal tires. 3/1 lift level kit from off road and TRD PRO grill and hood bulge
    I ordered a Tundra with and SR 5 package and a TRD package. will that come with the read roll down window?
  17. Jul 27, 2015 at 1:22 PM
    TruckyTruck
    Gary
    Crewmax right? It should, but you should make sure. I've seen some that didnt.
  18. Jul 27, 2015 at 1:32 PM
    MC Mike
    MC Mike New Member
    Central NY
    2015 tundra SR5 TRD
    No not a crew max just a extended cab
  19. Jul 27, 2015 at 1:39 PM
    Tacogrande
    Jeremy
    No Double cab has the 3 piece rear window with horizontal slider. You might get the powered slider.
    Congrats!
  20. Jul 27, 2015 at 1:44 PM
    Tacogrande
    Jeremy
    Well guys i just got back from putting a deposit down on a 2016 with the 36 gallon tank.
    I did not order the entune premium with navagation, or the step bars, or the spray in bedliner.
    However...there will be a 2-3 week period where i can make changes to my order. It is projected to be in production in 1-2 months.
    Here is a silly question..will you guys make fun of me if i do not upgrade from the styled steel wheels?
    Do you think it is stupid to not upgrade to the alloy wheels? I think it is an $800 upgrade or so.
    Anyhow i am pretty excited.
  21. Jul 27, 2015 at 1:45 PM
    MC Mike
    MC Mike New Member
    Central NY
    2015 tundra SR5 TRD
    Aw that sucks I kinda wanted that
  22. Jul 27, 2015 at 1:49 PM
    MC Mike
    MC Mike New Member
    Central NY
    2015 tundra SR5 TRD
    Congrats!!!! No making fun we all have a different taste. You can always upgrade with aftermarket anytime you want to
  23. Jul 27, 2015 at 3:42 PM
    csuviper
    Broomfield, CO
    Get the cheapest wheels and tires possible from factory and upgrade to the aftermarket wheels and tires that you really like.
  24. Aug 3, 2015 at 7:18 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    For the 2016 models, all 5.7 will have the brake controller. The 38 gal. tank is available with the SR5 only with the upgrade package. It is standard with Limited.
    Front/rear sonar is avail as Technology option on SR5
    Entune and Nav is standard on all SR5s.
    Entune Premium with Nav standard on Limited and optional on SR5
    New 2016 color, Blazing blue pearl
  25. Aug 3, 2015 at 7:24 PM
    Welcome from CO.
