What offset/backspacing for XD 825 Bucks?
Discussion in 'Wheels & Tires' started by BLV, Jan 16, 2017.
  1. Jan 16, 2017 at 12:46 AM
    BLV
    BLV [OP] New Member
    2017 Tundra Crewmax Limited
    2.5" Rough Country leveling kit
    I am new to the forum and I recently purchased a new 17 Tundra crewmax limited. I had a 2.5" Rough Country leveling kit installed but the dealer is having problems getting the wheels I want to fit right. I decided on the 20x9 XD 825 Bucks, but what offset and backspacing do I need and also what size tire do you recommend. I want to run a toyo open country a/t2. Any help would be appreciated. Thanks.
  2. Jan 16, 2017 at 12:50 AM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Check out custom offsets dot com. You can search by wheel size for tundras and it shows what the size tire and backpacking you need without rubbing.
    https://www.customwheeloffset.com/wheels-tires
    https://www.customwheeloffset.com/w..._diameter_from=20&wheel_diameter_to=20&page=1
  3. Jan 16, 2017 at 1:19 AM
    BLV
    BLV [OP] New Member
    It just gives me a list of wheels and sizes. Doesn't say if it will rub or not.
  4. Jan 16, 2017 at 5:26 AM
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    I'm pretty sure 33s are as big as you can go. Will have to do a little plastic trimming in the back of the well because of rubbing at full lock.
  5. Jan 16, 2017 at 7:08 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    285/65/20 which is roughly a 34.5" tire will fit with some rubbing at full lock. And what is hitting causing the trouble with the wheels fitting?
    zcarpenter92 likes this.
  6. Jan 16, 2017 at 7:17 AM
    bigoltater
    KC
    Leveling Kit,33'BFG
    You need to go to the gallery section.
  7. Jan 16, 2017 at 9:00 AM
    BLV
    BLV [OP] New Member
    The wheels the first ordered had 285/55/20 on them and was rubbing hard on the front and the back. These are barely bigger than stock though.
  8. Jan 16, 2017 at 9:10 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm not 100% sure but, I think you want an offset in the +18 to + 25 range. You'll need to remove your mud flaps, trim the skid plate and move the front liner forward a bit. At least this is what I did to run a 34.5" tire. All very easy stuff to do.
  9. Jan 16, 2017 at 2:49 PM
    BLV
    BLV [OP] New Member
    Also, the truck sits about 3/8" higher in the front now. It needs a 1" in the rear or so. I'm having trouble finding one to order, any suggestions?
  10. Jan 16, 2017 at 4:23 PM
    Zharris
    Zharris Merica!
    If you just got it done, the front will settle down some after driving it a bit.
  11. Jan 16, 2017 at 6:16 PM
    BLV
    BLV [OP] New Member
    That is good to know. The truck just has 350 miles on it, so I'll give it some time to settle. I appreciate all the advice. This is my first tundra, I was always a Ford man before but the wife and I both are Toyota now.
  12. Jan 17, 2017 at 4:23 AM
    Zharris
    Zharris Merica!
    Yeah, put some miles on it. I'm almost certain it'll settle down the 3/8 of an inch to be level. Maybe even be a touch lower in the front.
  13. Jan 20, 2017 at 2:16 PM
    BLV
    BLV [OP] New Member
    What size of tires should I run with the xd 20x9 with +35 backspacing and the 2 1/2" leveling kit?
  14. Jan 20, 2017 at 9:19 PM
    Zharris
    Zharris Merica!
    You could probably get 285/65 under there without modification. Anything bigger and I think you'd probably have to do some trimming and stuff.
  15. Jan 20, 2017 at 11:09 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I looked these up on the KMC site and I don't see a +35 offset for a 2017 tundra. I do see a +18, +25 and +30. I've read here quite a few times that +25 falls in the "sweet spot" for our trucks. Myself, I'd order either the +18 or the +25. Just my 2 cents worth.
  16. Jan 21, 2017 at 6:08 AM
    BLV
    BLV [OP] New Member
    They put 285/55 on it now and they barely clear with out rubbing but they look really small. The place put a 2.5" leveling kit on it when I asked for a 2". Of course they didn't remembering me saying that. If I raise the rear up I'm afraid the tires will look even worse. If I put a 2" on the front do you think it would give it a better over all look with those tires.
  17. Jan 21, 2017 at 10:48 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That puts you at about 32.4". If it clears at 2", I would go 2" over having to raise the rear.
    831Tun likes this.
  18. Jan 21, 2017 at 10:57 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    ^^^What Joon said.
    joonbug likes this.
  19. Jan 21, 2017 at 11:13 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Or if they will swap your tires, and you're willing to trim a little, you can put a 1" shackle or block on the rear and just get bigger tires. Ride might suffer a bit but it'll look much better.
