what OEM air filter to use
Discussion in '2.5 Gen Tundras (2014-2021)' started by r.c.pilot, Apr 5, 2024.
  1. Apr 5, 2024 at 2:41 AM
    r.c.pilot
    r.c.pilot [OP] New Member
    2016 white tundra
    own a 2016 tundra time for a air filter change Toyota is showing two options for this year my question is which one to use? Thanks r.c.
  2. Apr 5, 2024 at 3:55 AM
    morgaj1
    morgaj1 New Member
    AL
    2021 Tundra Platinum CM 4x4
    Assuming you have a 5.7L engine, 17801-0P100 is the one you want
    bulldog93 likes this.
  3. Apr 5, 2024 at 6:46 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Might be worthwhile to open the air filter housing and verify the filter is paper with foam rubber surround. If so, 17801-0P100 is correct. If the filter is white synthetic appearing material (almost felt or cloth in appearance) built in a substantial plastic frame, its the other filter part number.
  4. Apr 5, 2024 at 9:51 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    An the new ones r half as thick..
  5. Apr 6, 2024 at 3:11 AM
    r.c.pilot
    2016 white tundra
    Thanks for the response yes it's 5.7L motor. Glad to be a member!!
    ATV25 likes this.
  6. Apr 7, 2024 at 6:52 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Yea I noticed this when I got home from the parts department at dealer. They seem to have more plets though. I'm going to use them and don't see a reason that makes me scared.
  7. Apr 7, 2024 at 7:04 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  8. Apr 8, 2024 at 3:07 AM
    MountainMan
    MountainMan New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
  9. Apr 8, 2024 at 4:26 PM
    SanDiegoTundra71
    SanDiegoTundra71 New Member
    Doug
    Lakeside, CA
    2016 SR5 Tundra Crewmax
    285/70/18, Eibach Protruck 2.0 suspension
    There are 2 versions (unsure why)
    A charcoal one which I have in my (2016 5.7) and one with a plastic cage around it (I made mistake of getting that one first time) it didnt fit was too big. So I got the 0P100 version.
  10. Apr 8, 2024 at 6:36 PM
    737fixer
    737fixer New Member
    Small thread "Different Air Filters" will show you the considerable size difference between the 17801-0P100 and the Toyota Economy Line 17801-YZZ15.
