What needs to be trimmed?
Discussion in '2nd Gen Tundras (2007-2013)' started by I3uddy, Feb 23, 2017.
  1. Feb 23, 2017 at 9:29 AM
    I3uddy
    I3uddy [OP] New Member
    Kennesaw, GA
    2011 Magnetic Gray SR5 DC 5.7L
    MBRP Dual Exhaust, tint, coin holder cell phone mod, pioneer in-dash DVD, interior LED's, stubby antenna, LED Tailgate light-bar, para chord wrapped Oh shit handles, Tonnopro hard fold cover, bug deflector hood shield, Fuel hostage 20x9 at +20 wrapped in Nitto Terra G2 285/65/20. Debadged, Aries bull bar.
    I have a question about trimming. I have and am about to install bilstein 5100 all the way around with the front at top setting and toytec shackle on the rear set a 1. On the way are fuel hostages 20x9 at +20, tires also on the way are nitto terra g2 295/65/20.
    So my question is what would need to be trimmed(flaps, skid plate, please not body mount, wheel well covers??), and is it noticeable should I decide to sell in the not to near future ( 2011 SR5 approx. 62k miles) and put the factory wheels and tires back on?
    For the bilstein install local shop asked $400 to do it with alignment, seems kinda steep. I think i'll give it a shot this weekend with the rental spring compressor or just take them up to the shop and have the front strut coils done? advise?
  2. Feb 23, 2017 at 9:32 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That's a true 35". You're probably going to need to do it all.
    I3uddy[OP], Law323 and ColoradoTJ like this.
  3. Feb 23, 2017 at 9:59 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Sorry about your luck but the body mount will be where you have issues. You'll need about 3 inches to be able to clear anything larger than a 285/75r18. Granted, you wont rub a lot but you definitely rub.
    I3uddy[OP] likes this.
  4. Feb 23, 2017 at 10:14 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    *NOTE: mine is a gen 3, so there may be some differences. Maybe a gen 2 owner will chime in*
    I have 3" lift in front (.5" more than you'll be) and with my 295/60/20 (34.29" according to cooper website) and a +18 wheel, I had to:
    1. remove both front and rear mud flaps in the front
    2. push the wheel well liner forward and re-drill the two screws underneath to hold the new position
    3. use a heat gun to re-shape the liner some giving me a little more clearance (mostly where the bulge in the liner is on the bottom...you'll see it when you remove the mud flaps)
    Nitto lists your tire size at 35.12", so it is a safe assumption you'll need to do everything I did, plus possibly chop the body mount. This I'm not sure about, I'd have to see how much clearance I have.
    joem1cha3l and I3uddy[OP] like this.
  5. Feb 23, 2017 at 11:19 AM
    I3uddy
    Kennesaw, GA
    Thanks for the input, I don't really have a problem with the flaps or wheel well liner, I would rather not have to get into the body mount. Would going down to 285/65/20 help? The 295/65 is 35.1" tall and 11.6" wide with the 285/65 its 34.6" and 11.2" is that enough clearance to stay away from the body mount. I will put my order on hold until I hear. Is the width of the tire the issue or the height?
  6. Mar 13, 2017 at 9:31 AM
    I3uddy
    Kennesaw, GA
    Thanks for the replies, I have the 5100's installed with the wheels and tires, ended up going with the Terra G2 285/65/20 on fuel hostage at +20 offset. Removed the mud flaps, loosened the well liner and moved it forward. Doesn't seem to rub anywhere else.
  7. Mar 14, 2017 at 5:12 PM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    I have 5100's on top setting all around. I put on Toyota Trd 20x9 Carve wheels with 275/60/20 Bfg Ko2's and I had to pull off the 2 side pieces on my skid plate. That was it. I was actually a little surprised after doing quite a bit of research and people saying that I wouldn't have any issues but they were hitting it. It ended up working out I was able to just bend them down and they snapped off on the spot welds. Nice and clean
    glaster likes this.
