What made you choose 20" or 18" wheels?
Discussion in '3rd Gen Tundras (2022+)' started by phatjoe, Dec 31, 2021.
  1. Dec 31, 2021 at 7:52 AM
    phatjoe
    phatjoe [OP] New Member
    2019 TRD Pro Voodoo Blue
    Hello,
    New Tundra (SR5 with 18" wheels) will be delivered today...time for new wheels and tires! I'm debating between either 20" or 18" wheels (regardless of the size 18+ offset). I'm sure others have debated these two wheel sizes. I know the 18" has the larger sidewall so the ride may be a little better.
    But curious why others went with a particular size. Mostly for looks? Comfort? Maybe some of the comments will help me decide.
    Prostar 190 and Bradanglin22 like this.
  2. Dec 31, 2021 at 7:53 AM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Rubber to wheel ratio. How big of a lift/tires are you going to run? 18’s are lighter and more rubber is better off-road
    Baja Mike and Metro14536 like this.
  3. Dec 31, 2021 at 7:54 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I run 17’s but still applies to 18’s. I personally prefer the looks a lot more. But also the benefits of a much better ride, better tire selection, and tires are typically cheaper too.
    I also believe the wheels are normally cheaper too than 20’s. It’s a win win all around.
  4. Dec 31, 2021 at 7:58 AM
    phatjoe
    I'm probably going to run with 34" or 35" tires, nothing too crazy. No off-roading for me.
    Prostar 190 likes this.
  5. Dec 31, 2021 at 8:13 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    18s ride smoother and I actually prefer the look. Also, I change my own tires and I couldn't imagine trying to lift heavier wheels.
    rebmo likes this.
  6. Dec 31, 2021 at 8:16 AM
    I also run 35" and just like the looks of the 20's with 35" tires. I don't off road either.
  7. Dec 31, 2021 at 8:18 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    20's. Cuz "floating the mainstream" is for average guys. :hattip:
  8. Dec 31, 2021 at 8:19 AM
    nuclear
    nuclear New Member
    Smaller is better if you offroad and need to air down, allows you to get more sidewall without the risk of potential problems in doing so.
    Acedude likes this.
  9. Dec 31, 2021 at 9:06 AM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    I switch between 20” and 18” wheels/tires (both oem sizes) on my 2020 sport.
    The 20” setup is for summer since I’m mostly on pavement. Stiffer ride, better cornering, negligible mpg increase and looks a little cooler.
    The 18” setup is for winter. Definitely more bounce/cushion but it’s more comfortable imo, the extra sidewall helps with obstacles, and it helps my confidence to drive over stuff.
    If I had to pick one option I’d go with 18” for better wheel protection, cushier ride and ability to go 285 or 295/70 at some point.
    rebmo likes this.
  10. Dec 31, 2021 at 9:26 AM
    Looks, comfort, and ability to air down put me on 18" wheels. I hate the rubber band look and it's not a sports car so the handling benefits of a rigid ride are a waste.
    rebmo, Baja Mike, DexterL and 3 others like this.
  11. Dec 31, 2021 at 10:01 AM
    18” for the ride quality and less vibration and balance issues. Lots of available tire sizes. Won’t be off-roading much in the new Tundy. Old Tundy has 16”. It’s the hunting rig now. Although I do like the look of a 20” wheel.
  12. Dec 31, 2021 at 10:33 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    18” are better in every way I’m aware of besides looks. If you think bigger wheels look better. I think smaller wheels look better
    rebmo and Cpl_Punishment like this.
  13. Dec 31, 2021 at 10:38 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    18's without a doubt, unless you are mall crawling. I ran 20's on my prior tundra's and my 19 for a bit, switched out to 17's and will never go back
    rebmo likes this.
  14. Dec 31, 2021 at 11:00 AM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Your tires are the first form of suspension to hit the road. More sidewall equals a smoother ride. 18s came on my truck but I'd like to get 17s not only for the smoother ride, but because tires are cheaper for 17" wheels than 18" wheels. At least in my case. BFG KO2 A/T for an 18" is about $320. Same tire in 17" is about $266. I plan on keeping my truck for a long time. So it would be cheaper in the long run to get 17" wheels and tires.
    TundraTed and Cpl_Punishment like this.
