What lugnut torque on Method 703s
Discussion in '3rd Gen Tundras (2022+)' started by mambajack, Feb 27, 2023.
  1. Feb 27, 2023 at 1:55 PM
    mambajack
    mambajack [OP] New Member
    So was in transit to the dealer for alignment after installing level kit, heard noise and wheel lugs on front passenger were loose, pretty sure I torqued to 100ft lbs. What does everybody else use?
  2. Feb 27, 2023 at 2:24 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    100lbs should be good, just need to make sure the rim is seated to the hub better
  3. Feb 27, 2023 at 2:32 PM
    DFS
    DFS New Member
    2022 Capstone Tundra
    Should be 97 Ft/Lb's per Toyota to match OEM spec so you're good.
    Welderdude80 likes this.
  4. Feb 27, 2023 at 4:12 PM
    Aces and 8s
    Aces and 8s I Turn Wrenches
    2023 Tundra CM Ltd
    Book says 97, so that's what I torqued my methods to. No issues.
  5. Feb 28, 2023 at 6:24 AM
    mambajack
    thx all, I must have just not gotten them quite right on the wheel, 40 miles after tightening again, still tight
