What long tubes are you running?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2mchfun, Aug 12, 2023.
  1. Aug 12, 2023 at 8:09 AM
    2mchfun
    2mchfun [OP] Cool story, but did your new TTV6 tow a shuttle?
    Looking for advice and opinions on long tubes here ( Ha! Can't wait! @hagrid). Thinking I have ruled out a supercharger and will keep my truck NA for longevity reasons. The plan is long tubes with high flow cats, DD dual exhaust, 5.29 gears, IPT HP valve body, deep pan, and a custom tune. So, who makes the best 5.7 headers for the long haul?
    Rdrcr, hagrid and BUGEATER like this.
  2. Aug 12, 2023 at 9:03 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Color preference? Cuz it's going to determine length.
    Also, monstrous girth.
  3. Aug 12, 2023 at 4:43 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I have the Stainless Works headers and high flow cats but I've only had them on for a few months. Only thing I can say is pay attention to where the O2 sensor port is on the LTH, you'll get some AFR oscillation the further back it is from the original position. If you don't have a wideband gauge you probably wont notice it.
    2mchfun[QUOTED][OP] likes this.
  4. Aug 12, 2023 at 5:47 PM
    2mchfun
    Those are exactly what I was thinking of using also. Still have a lot of research to do, but hopefully something such as the Underdog Racing Development MAF sensor calibrator will allow for getting AFR's set for the best overall results. Thanks for your post and your many other inspirational and informative posts! Much appreciated!
    Saltyhero13[QUOTED] likes this.
  5. Aug 12, 2023 at 7:16 PM
    Saltyhero13
    I'm not familiar with that MAF device so I can't comment but not sure messing with the MAF would fix what I am seeing.
    On the SW LTHs the O2 bung is after the collector (several inches from the stock position) so the ECU is seeing a delayed reading of AFRs. The delay seems to make the ECU overcompensate on adjustments so you get this oscillation effect after the ECU responds to the overcompensation. Idles fine so it isn't really noticable unless you are running an AFR gauge. I think Scan gauge can pick it up too. Relocating the O2 sensor with a new bung higher up on the header is one way I've seen the issue fixed.
    As far as what is on the market for headers I've seen Kooks, American Racing Headers (ARH), Doug Thorley (I've seen shorties but I think they make long tubes too) and I think one more. @dirtydeeds has commented on the build quality of some of these in the past. You can ping him for more details since he probably sees more installs than my one off case.
    Sounds wise I thought the SW would be too much but they aren't too bad cruising around. Definitely a deeper tone. They do sound like an angry scream emanating from the maw of hell when you get on the gas though. Windows down for full effect. Video audio wont do the sound justice since the audio gets compressed.
    Performance wise I only picked up about ~10WHP but I'm running a blower. You might pick up more since you are NA.
    I did pick up about ~.5 to ~1 MPG which shocked me. If I'm not deleting gas I can get 14 City fairly easy. May not be all headers if the headers at all since I had to get retuned for other mods I had made.
    Good luck and happy hunting. Hopefully you get some more response form others running LTHs.
    Rdrcr and 2mchfun[QUOTED][OP] like this.
  6. Aug 12, 2023 at 7:41 PM
    2mchfun
    Thanks again! I think you were trying to think of JBA as the other one. As for Keith, my plan is to definitely reach out to him for advice and pricing when I get closer. He might even know something about the URD MAF device or something else that will work to get the best AFR's. Kinda starting to think that I should probably do the Solid off-road engine mounts too. What do you think? Never fails, one thing leads to ten others!:annoyed:
  7. Aug 12, 2023 at 7:59 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    ARH, Kooks and SW stand alone headers all neck neck down to the much smaller stock mid pipes. So for true large pipe (3” or 2.5”) you’d have to have it custom made (like DD race exhaust). ARH has a full setup that doesn’t neck down to stock but is not 3” apparently, may be good to go for naturally aspirated though.
    Rdrcr, Saltyhero13 and 2mchfun[OP] like this.
  8. Aug 12, 2023 at 8:06 PM
    2mchfun
    Thanks! I will check out the ARH and also speak with Keith when I get things narrowed down a bit more.
    Rdrcr likes this.
  9. Aug 12, 2023 at 8:12 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I’m anxiously awaiting a custom DD dual 3” race exhaust which is supposed to arrive next few weeks. I’m excited for the noise complaints!
    FrenchToasty and 2mchfun[OP] like this.
  10. Aug 12, 2023 at 8:15 PM
    2mchfun
    Have a blower on your truck or stock intake manifold?
  11. Aug 12, 2023 at 9:05 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Yes a 1.9L Magnuson + some other upgrades so I'll likely be in the 650-700hp crank range with the headers and retune. Will be a hoot (until something blows up). A dealer installed Magnuson is a pretty nice plug and play 550hp (for 10K usually including tax and install), if the person keeps it as-is should be same reliability as stock.
  12. Aug 12, 2023 at 10:05 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    JBA longies
    2mchfun[OP] likes this.
  13. Aug 13, 2023 at 1:21 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’d do stainless works,kooks or arh and get a custom tune from OTT
  14. Aug 13, 2023 at 11:15 AM
    Saltyhero13
    @2mchfun Yes. JBAs were the ones I was forgetting.
  15. Aug 13, 2023 at 12:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    JBA's with DD 3in race exhaust. Single high flow cat per side with 1.9 magnuson.
  16. Aug 13, 2023 at 2:40 PM
    Saltyhero13
    I've not seen any Tundra trucks run that high without E85 or a built engine. Looking forward to your findings.
  17. Aug 13, 2023 at 2:47 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Judging by some of the 0-60 times some of the trucks are doing a few might be there. Or damn near
  18. Aug 13, 2023 at 2:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Theortically I was in the 650-700 crank HP range...with Bullydog 93 crap tune. Kaboomb went the engine.
    reywcms, 2mchfun[OP] and Saltyhero13 like this.
  19. Aug 13, 2023 at 2:58 PM
    Saltyhero13
    Yeah I'm impressed by the numbers I've seen posted **while in Mexico**. Tundra is a big heavy truck, seeing #s in the low to mid 4s is crazy to me. It is not like these folks are running street tires and stripped vehicles.
    Depends on what we think driveline loss is though. 20% loss would mean pushing ~580WHP, impressive and hopefully safe.
  20. Aug 13, 2023 at 3:00 PM
    Saltyhero13
    What broke if you don't mind sharing?
    Rdrcr and 2mchfun[OP] like this.
  21. Aug 13, 2023 at 3:48 PM
    2mchfun
    What did y'all do with your stock cats?
  22. Aug 13, 2023 at 3:54 PM
    Saltyhero13
    I sold mine to a meth head...
    MatthewPTguy, Rdrcr, hagrid and 2 others like this.
  23. Aug 13, 2023 at 3:59 PM
    FrenchToasty
    Mo
    Bone stock
    Same
  24. Aug 13, 2023 at 4:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I brought my stock cats to a recycling place. Didn't get jack for them. How do those tweekers get more money?
  25. Aug 13, 2023 at 4:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  26. Aug 13, 2023 at 5:42 PM
    Saltyhero13
    Thanks for sharing this. Great write up. I will definitely be reading that thread through the end.
    Rdrcr, 2mchfun[OP] and Mdl[QUOTED] like this.
  27. Aug 13, 2023 at 6:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Didn't mean to hijack this thread...
    Running LT's with a decent exhaust by itself was great and woke the 5.7 up. It left you wanting more.
  28. Aug 13, 2023 at 6:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Saltyhero13 . A little bit after mine went Viktorg blew his. There was the initial confusion on what size injectors(480 or 535) and fuel pump limitations. I thought it may have been fuel pump related but was later told that the Bullydog 93 tune was most likely cause.
  29. Aug 13, 2023 at 6:22 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    yea that tune I’ve heard is garbage
  30. Aug 13, 2023 at 7:07 PM
    centex
    centex New Member
    The bullydog tune is a generic canned tune. If you are going FI, get an actual custom tune.
    Rdrcr, Mdl, Saltyhero13 and 2 others like this.
