What Locking Hitch Pin Do You Use?
Discussion in 'Towing & Hauling' started by Bergy24, Dec 18, 2022.
  1. Dec 18, 2022 at 2:53 PM
    Bergy24
    Bergy24 [OP] New Member
    2021 Cement Crewmax Limited TRD 4X4
    I have a 6x12 enclosed trailer and the locking hitch pin I have is kind of sloppy and I would like something better.
    Preferably Stainless so no issues with rust.
  2. Dec 19, 2022 at 7:22 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I dont use them. The are Ok if you remove them after use and store them, but every one I have used, (stainless or not) that sits on the truck ends up rusting or otherwise locking up and end up needing to be cut off.
    Bergy24[OP] likes this.
  3. Dec 19, 2022 at 7:30 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I use BOLT locks for my hitch as well as the coupler and swing tongue on my boat trailer
    https://www.boltlock.com/
    unfortunately they are not compatible with the push button start fob key
    KNABORES and joseph_womack like this.
  4. Dec 19, 2022 at 7:57 AM
    timsp8
    NY
    I use Bolt also. They have a YouTube video showing how to break it off along with a couple of competitors. Of course they won, but it only took 3 minutes or so.
    https://m.youtube.com/watch?v=-Lq6_N5K1L4
    WVI, joseph_womack and Gaston like this.
  5. Dec 19, 2022 at 8:16 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I hadn't seen that video before. Like anything with trying to prevent theft, it is all about deterring the average thief and making it hard enough they move on to an easier target.
    joseph_womack and timsp8 like this.
  6. Dec 19, 2022 at 8:24 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I keep one on all the time just to prevent my hitch cover from being stolen. I've used the Masterlock (shown in that video), was ok for a while but the anodizing faded (red to pink) and it eventually had to be cut off.
    I now use this one: https://www.amazon.com/gp/product/B07GB17XD7?ie=UTF8. The locksmith who cut the Masterlock off (was hoping I could get it off without), suggested to use Tri-Flow on them. Every once in a while spray it in the locking mechanism and the shaft and work it in. So I won't say the lock itself is better, but the maintenance is probably what helps.
    I also have to laugh at that video, I've passed that marina many times on my bicycle :D.
    MedCityMoto likes this.
  7. Dec 19, 2022 at 8:38 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Also use BOLT, no issues with 5yo ones that are outside 100% in the rain etc.
    Gaston[QUOTED] likes this.
  8. Dec 19, 2022 at 9:53 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I use a Rhino one with weatherproof cover on it. Once a year I hit it with a dry lube in the locking mechanism, and my hitch covers I engrave quit wandering off.
    NewImprovedRon likes this.
  9. Dec 20, 2022 at 4:58 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I use marine grease 2-4-C grease and spray the lock (where the key goes in) with either CRC 06026 Heavy Duty Corrosion Inhibitor or BOESHIELD T-9 Rust & Corrosion Protection/Inhibitor and Waterproof Lubrication.
    I had a hitch that was rusted so bad the shaft would not come out of the holder. Since then I protect the hitch with lots of 2-4-C. Salt water is a tough environment.
  10. Dec 20, 2022 at 5:20 AM
    rothmigo
    rothmigo New Member
    DFW TX
    2020 Tundra Crewmax Platinum
    7" BDS/Fox, 5.29, 37x13.50 Nitto, 22x12 Hostile Rage,BAM
    Factor 55 locking pin. Stainless and made in USA. Had it for a couple of years and tow a small toy hauler with no signs of wear on the pin. I'd try a pipe on it but don't want to know!
  11. Dec 20, 2022 at 6:07 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    https://softride.com/tightening-hitch-pins/
    I have been using this for 14 years on 5 different vehicles. Never really cared for it and it’s been exposed to the salty winters here. In addition it has taken countless NYC love taps along with some large hits.
    There is zero play when towing which is the initial reason why I bought it. I will never tow without one on my personal vehicles. It’s a much better experience.
    Simply a great product that has more than proven itself in IMHO.
    7E05F11D-95C3-4330-A990-D571001DBCDC.jpg F4303C44-5B5F-4AAB-906F-C19C1A84A798.jpg
    Clemsonman14 likes this.
  12. Dec 27, 2022 at 5:18 AM
    Retired...finally
    Call me cheap but I use a standard pin with two holes in the free end. One small hole for the hitch clip pin and a larger one for the padlock. Handy for me to have a handful of keyed alike padlocks to use on the trailer hitch and locking my ramps to the underside of my ATV trailer.
    WVI likes this.
  13. Dec 27, 2022 at 5:23 AM
    Bergy24
    Sounds simple but effective. I am assuming you drilled the 2nd hole for the pad lock?
  14. Dec 27, 2022 at 2:25 PM
    Retired...finally
    No, I did not. I just found it in my ever increasing junk pile. A quick search found one on Mcmaster Carr that had the lock hole but not the smaller hole for the hitch pin.
    Bergy24[QUOTED][OP] likes this.
