What Lift Is This????
Discussion in '2.5 Gen Tundras (2014-2021)' started by rycherd, Mar 5, 2019.
  1. Mar 5, 2019 at 2:04 PM
    rycherd
    rycherd [OP] New Member
    Richard
    Castle Rock, CO
    2015 SR5 Crewmax Tundra
    4" lift, 35" Nitto G2, 20" Fuel Trophy rims, Nerf bars, grille
    I purchased this truck used from dealership, original owner did a trade in so no info on lift was provided.... Pro comp brand.
    1- from Google searches I believe it's a stage 1 but not 100% sure
    2- factory struts
    3- I've assumed it's 4" but not sure (currently have new 35" tires)
    I would love to upgrade but have no clue what I'm working with and hope someone has something similar or at least knows what the heck it is. Thanks in advance.IMG_20190305_145623.jpg
  2. Mar 5, 2019 at 2:13 PM
    15whtrd
    15whtrd Mr. Blonde
    Not 100% but it looks something like a 6-7 inch bracket lift. Also looks like they cut out the crossmember. So you will either need to source one and have it put back in if you want to get rid of this set up. Or work with what you got and upgrade those springs and coil overs. Somebody will chime in and give you better insight.
    Black Wolf and rycherd[OP] like this.
  3. Mar 5, 2019 at 2:19 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Icon makes a coilover for 6” bracket lifts. Part 58651. Is that rear shock messed up?
    rycherd[OP] likes this.
  4. Mar 5, 2019 at 2:22 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Looks like a 6" trailmaster. 4wheelparts should be able to tell for sure if it is
  5. Mar 5, 2019 at 2:46 PM
    rycherd
    Richard
    Castle Rock, CO
    Thank u
  6. Mar 5, 2019 at 2:47 PM
    rycherd
    Richard
    Castle Rock, CO
    I think it's that crappy rubber sleeve but I'll check it out. Thx
  7. Mar 5, 2019 at 2:54 PM
    15whtrd
    15whtrd Mr. Blonde
    Oh good they didn’t cut your crossmember!
  8. Mar 5, 2019 at 3:07 PM
    rycherd
    Richard
    Castle Rock, CO
    This is how it sits which made me think a 4" lift.
    15whtrd and jewsNbrews like this.
  9. Mar 5, 2019 at 3:45 PM
    Mine isn't either, but it's an older kit
  10. Mar 5, 2019 at 3:52 PM
    Mnorris1206
    08 tundra
    This is how my R.C . lift is also not cut but everyone is telling me to get the longer dif drop and cut the cross member idk what to do at this point. I assume cv axles in the future but I would rather throw 100 dollars a pair of them on the truck then to cut that out .
  11. Mar 5, 2019 at 3:57 PM
    Mnorris1206
    08 tundra
    Looks like a 6" to me .And after seeing the spacers they used.
    15whtrd and rycherd[QUOTED][OP] like this.
  12. Mar 5, 2019 at 4:28 PM
    15whtrd
    15whtrd Mr. Blonde
    I wouldn’t want to cut it. I also don’t know what to think about a diff drop either. Ive read some negative affects about changing that angle and possible oil issues. I’d rather change a CV than the diff. But I have no real evidence other than what I’ve read.
    Mnorris1206[QUOTED] likes this.
  13. Mar 5, 2019 at 4:38 PM
    Mnorris1206
    08 tundra
    Yea I just changed my driver side because we pulled on the knuckle to much trying to put the new struts in. Our fault because we didnt loosen the Axel nut at all. But the new cv Axel was only 59 dollars .With the core charge .
    15whtrd[QUOTED] likes this.
  14. Mar 5, 2019 at 4:39 PM
    Mnorris1206
    08 tundra
    Does your truck ride stiff? Just curious because it also has a big pre load spacer as well .The one directly on the spring .
    15whtrd likes this.
  15. Mar 5, 2019 at 4:40 PM
    Longer diff drop??? Explain please
  16. Mar 5, 2019 at 4:42 PM
    Mnorris1206
    08 tundra
    My R.C . lift is the first one they made then they revised it I guess where now you have to cut the cross member .Mine has a dif drop but my guess not as much as the second lift kit they came out with .
  17. Mar 5, 2019 at 4:48 PM
    You n must have same kit, my RCM is not cut at both ends, I seen another Tundra with a RC kit n CV axle angles were not as tweaked as mine, I've sent pics to RC to show em, they said it's an older kit, and I do have diff drop bracket, I did order there extended struts but look cheap, so I haven't installed, @Les7311 has done this and says the ride is better
  18. Mar 5, 2019 at 4:52 PM
    Mnorris1206
    08 tundra
    Yep I also have called R.C they told me I would have to buy the dif kit and new skid plat they come together they are around 350.00 for the kit. I did also change my struts but to the n3.0 lifted struts they make a huge diference .
  19. Mar 5, 2019 at 4:54 PM
    @rycherd where are the rear blocks between the leaf springs and axle, get a better pic?
    15whtrd and Mnorris1206 like this.
  20. Mar 5, 2019 at 4:56 PM
    Mnorris1206
    08 tundra
    /\/\ same it looks like small spacer and maybe some shackels ?
    TXRailRoadBandit73 likes this.
  21. Mar 5, 2019 at 4:59 PM
    Yeah they not like mine
  22. Mar 5, 2019 at 5:01 PM
    Cud be a 4 1/2" kit, I spoke with RC, they have some items that cud put mine at 4 1/2", believe also RCD lifts has extended Bilstein struts n rear shocks for 4-6" kits
  23. Mar 5, 2019 at 5:03 PM
    Mnorris1206
    08 tundra
    Nope thats My next move get the back to ride better maybe a leaf pack. Or small spacer and shackles
  24. Mar 5, 2019 at 5:18 PM
    rycherd
    Richard
    Castle Rock, CO
    Stiff as hell, the bed gets the hops sometimes on the hwy
  25. Mar 5, 2019 at 5:20 PM
    Mnorris1206
    08 tundra
    Yep and wondering about the front also like even cracks in the Rd. You can feel all of them too .Well hopefully you find out what kit you have. Then get some nice coilovers to help with the ride.
    rycherd[QUOTED][OP] likes this.
  26. Mar 5, 2019 at 5:22 PM
    What's your tire n wheel size, see your CV axle angles
  27. Mar 5, 2019 at 5:23 PM
    rycherd
    Richard
    Castle Rock, CO
  28. Mar 5, 2019 at 5:25 PM
    You must have shackles or more leaf springs, my rear blocks are way bigger
  29. Mar 5, 2019 at 5:33 PM
    Mnorris1206
    08 tundra
    I'm running 35 12.5 18 on fuel krank 18x9 s
    Pic of cv angles and a not so good pic of the rcm.and truck as it sits now
  30. Mar 5, 2019 at 5:36 PM
    Mnorris1206
    08 tundra
    @rycherd . My lift spacers before I put lift struts on see the pre load is not as much as yours looks to be .but pics are hard to determine .
