What kind of water valve is this?
Discussion in 'Home Improvement' started by Netmonkey, Jun 27, 2018.
  1. Jun 27, 2018 at 9:32 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    my wife and i are thinking about replacing our kitchen faucet so i went to look under the sink to see how the existing faucet is hooked up. i expected to see a typical water valve where you can just turn a knob to shut off the flow, but, instead, i see this...
    what kind of valve is this? and how the hell do these work? there are knobs that you can pull or push and one looks pushed in while the other looks pulled out. I want to make sure that i understand how these work before i mess with them. does that knob only disconnect the line? or does it also shut off the flow? or do i need to turn off the water to the house before disconnecting these lines?
  2. Jun 27, 2018 at 9:37 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I've never seen those. They look like some kind of shutoff valve. I'd pull them and turn on the faucet and see if the water flows. I can't quite understand why they'd connect the supply lines behind the cabinet where you can't get to them. You'll have to cut the back of the cabinet to access them to replace it needed.
    Edit maybe the cabinet has a large enough access whole behind the white etscucheon (trim piece)
    15whtrd likes this.
  3. Jun 27, 2018 at 9:38 AM
  4. Jun 27, 2018 at 9:42 AM
    Netmonkey
    Georgetown, TX
    NewImprovedRon and Pudge like this.
  5. Jun 27, 2018 at 9:47 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  6. Jun 27, 2018 at 9:55 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Hmm. Never seen those before.
  7. Jun 27, 2018 at 9:56 AM
    Never seen before
  8. Jun 27, 2018 at 10:03 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    Me likey
  9. Jun 27, 2018 at 10:03 AM
    15whtrd
    15whtrd Mr. Blonde
    Learn something new every day. Never seen those before. But the video was informative. Not sure if I like. I like my water connections well outside the wall. I’d want to put some
    O-ring grease on. Careful not to mar the mating surfaces when installing. Slow leaks are the worst kind. Hard to detect until damage is done. I hate mold!
    Still a cool product. I would have the water turned on and purged before installation of the escutcheon. Dry the area real well, and observe. I put tissue or paper towels under my sinks after everything is completely dry. This is a great way to see if anything new develops.
  10. Jun 27, 2018 at 10:08 AM
  11. Jun 27, 2018 at 10:16 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s the difference between a good plumber and one that gets called again. I never want call backs. You could’ve done everything beautifully but leaks happen to the best of us. The more thorough you are the less likelihood of problems. Checking your work is the difference between a good plumber and a great plumber. Not just a once over. It may take a little more time and make me look slower than the next guy. But I’ve had customers that really appreciated the lack of problems after I’m gone.
    Treat everyone’s house as if it were your own LOL. I wish I could find a mechanic like me.
  12. Jun 27, 2018 at 10:17 AM
    :amen:
    15whtrd[QUOTED] likes this.
  13. Jun 27, 2018 at 10:20 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    So that exact style is new to me but there is something similar that used to be popular for new homes. Does your home have a main water shut off panel in the home for each room? The system was by Viega and it’s called a Manabloc system. They have don’t use them anymore. They were convenient to shut off certain rooms but prone to having issues. 28A1C0E1-5DAA-45A7-933F-601442EEE411.jpg
  14. Jun 27, 2018 at 10:21 AM
    Whaaaaaaa is that?!?!???
  15. Jun 27, 2018 at 11:00 AM
    15whtrd
    15whtrd Mr. Blonde
    That is badass! Its a manifold system for every water source in the home. Everything branches from that point. Some home can have multiple manifolds depending on the size of the house.
  16. Jun 27, 2018 at 11:02 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    This is how you run a pressurized beer tap to every room in your house.
  17. Jun 27, 2018 at 11:02 AM
    15whtrd
    15whtrd Mr. Blonde
    :yes:
    I was way off!
  18. Jun 27, 2018 at 12:02 PM
    1UPPER
    TEXAS
    Flux capacitor!
    The Viega systems are actually hated by most plumbers since they are notorious for leaks and busted lines. If you have one it’s usually not a good thing.
  19. Jun 27, 2018 at 12:07 PM
    Since I know what @1UPPER does for a living, and is always right- I would take his suggestion. Just my .02.
  20. Jun 27, 2018 at 12:25 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Thank you for kind words Sean! Everyone has their own preferences but I know my plumbers hate those systems. The idea is cool but the reliability not so much.
  21. Jun 27, 2018 at 12:31 PM
    Rex Kramer
    Georgia
    True ... I won't touch them.
    I prefer working with PVC and CPVC.
    1UPPER[QUOTED] likes this.
  22. Jun 27, 2018 at 1:21 PM
    15whtrd
    15whtrd Mr. Blonde
    They look really cool, the idea is great. But I prefer more the old fashion way. I like pex pipe but I prefer Uponor. No clamps. Keep it simple with minimal 90s and fittings. Or copper.
    831Tun, 1UPPER and Rex Kramer[QUOTED] like this.
  23. Jun 27, 2018 at 1:29 PM
    Rex Kramer
    Georgia
    Copper is great as long as the pH of the H2O isn't acidic.
    1UPPER and 15whtrd like this.
  24. Jun 27, 2018 at 1:49 PM
    15whtrd
    15whtrd Mr. Blonde
    Exactly! And reverse osmosis water will kill copper.
    Rex Kramer[QUOTED] likes this.
  25. Jul 13, 2018 at 9:33 PM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    The only call backs you want are repeat business.
  26. Jul 13, 2018 at 10:07 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    And, I don't use the plastic fittings, only the brass ones for Pex.
