What jack do you use for general work on your Tundra?
Discussion in 'General Tundra Discussion' started by Teriks, Sep 19, 2017.
  1. Sep 19, 2017 at 4:00 PM
    Teriks
    Teriks [OP] New Member
    Tom
    Front Range, CO
    2008 Toyota Tundra Limited DC 4x4 5.7
    So I've decided that my current, old, crappy jack is not going to cut it with this truck, especially with the front lifted 2.5" and the rear pending a 1" lift. The POS i have now only goes a bit over 14" which is obviously not enough - I need to get the truck in the air enough to handle putting the rear shackles on, and with 31" tires it barely moves at all with the jack maxed out.
    How would you go about getting around this? Stacking blocks of wood seems dangerous, as I'd need more than two. Getting a new jack is expensive, but may be my only option. Do you guys have a regular jack that goes well over 20" maxed out, do you use offroad jacks, or do you have some other tool or trick to get your higher-than-stock Tundra in the air?
  2. Sep 19, 2017 at 4:02 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
  3. Sep 19, 2017 at 4:06 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Wow those are nice jacks.
    I don't have his problem because mine is stock. However, if I needed to, I would use a 6"x6" block cut from a post and my 3 ton floor jack.
  4. Sep 19, 2017 at 4:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Do you have jack stands? You just need a block of wood temporarily on the jack to get it high enough to get the jack stands under. You should not be under your truck with just the jack alone.
    BravoDeltaRomeo, Patriot and Law323 like this.
  5. Sep 19, 2017 at 4:08 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
  6. Sep 19, 2017 at 4:09 PM
    sdhq_offroad
    GILBERT, AZ
    Yes, both the 5-8" (small) and the 8-13" (large)
    Baja Mike[QUOTED] likes this.
  7. Sep 19, 2017 at 4:15 PM
    Allied 3 1/2 ton ...gotten from my Father
    Patriot likes this.
  8. Sep 19, 2017 at 4:16 PM
    TheBeast The Beach
    MIM likes this.
  9. Sep 19, 2017 at 4:19 PM
  10. Sep 19, 2017 at 4:22 PM
    TheBeast The Beach
    2.5 front. Not enough height for the sides but perfect for rear diff.
    I'm using the frame on the side.
  11. Sep 19, 2017 at 4:23 PM
    Teriks
    Tom
    Front Range, CO
    Yup, always use jack stands. Finding a block of wood is proving harder than thought - picked up a 2x4 at ace and hand-sawed it, but that's obviously only adding 2" of height. I figured cutting a few more slabs off and gluing them together might work, but that's where I'm worried about integrity of the makeshift "extension".
    Those jacks by SDHQ look pretty sweet but that's the price tag I'm trying to avoid - for now.
    joonbug[QUOTED] likes this.
  12. Sep 19, 2017 at 4:53 PM
    sdhq_offroad
    GILBERT, AZ
    Nothing. Just the cost of powder coating vs raw.
  13. Sep 19, 2017 at 5:36 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Jack Mechanic down at the JiffyLube
  14. Sep 19, 2017 at 5:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I use a 6x6 block of wood and my stock jack with jack stands. Hasn't let me down yet
    GNTundra likes this.
  15. Sep 19, 2017 at 6:03 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    I have a Craftsman 4 ton and 4 12 ton jack stands. No idea why I have 4, I've only ever used 2 at a time. Also a 48" HiLift with a slider adapter.
