What is this?? Engine bay mystery
Discussion in '2nd Gen Tundras (2007-2013)' started by NWTundra11, Oct 8, 2017.
  1. Oct 8, 2017 at 9:18 AM
    NWTundra11
    NWTundra11 [OP] New Member
    Looking at purchasing this 2010 4.6L Tundra, 108,xxx miles.
    Car history shows 1 accident (slight damage, minor, no airbags deployed) to Left Front.
    Spray/corrosion of some sort, seems to originate from battery area. Could a battery spray or slosh and create this?
    Thoughts?
    k0diak8o8 likes this.
  2. Oct 8, 2017 at 9:19 AM
    NWTundra11
    Would you shy away from the purchase because of this?
  3. Oct 8, 2017 at 9:26 AM
    TheBeast The Beach
    Tundras batteries are known to corrode...quick...
    Also check cam towers for oil leaks
  4. Oct 8, 2017 at 9:27 AM
    TheBeast The Beach
    mine looked like that at some point..I cleaned the area, change the metal clamps and new battery.
  5. Oct 8, 2017 at 9:43 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Looks to me like some battery corrosion got hosed off and sprayed into the engine bay.
  6. Oct 8, 2017 at 9:59 AM
    NWTundra11
    hey good call on that
    040Tundra likes this.
  7. Oct 8, 2017 at 10:00 AM
    NWTundra11
    thanks
    cam towers leak from front or back on this motor?
  8. Oct 8, 2017 at 10:19 AM
    TheBeast The Beach
  9. Oct 8, 2017 at 10:24 AM
    NWTundra11
    Gotcha.
    Anything else come to mind at the 100k mile mark on these rigs?
    Sale price I have them down to is 18,500.
  10. Oct 8, 2017 at 10:28 AM
    TheBeast The Beach
    seems a bit high.
    Also check AIP pumps. they tend to fail on early models.
    FlashCulprit likes this.
  11. Oct 8, 2017 at 11:01 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    My thoughts as well. Looks like someone hosed or brushed the corrosion off of the terminals. That stuff splatters and stains the hell out of everything.
  12. Oct 8, 2017 at 11:45 AM
    NWTundra11
    how do you check these?
  13. Oct 9, 2017 at 2:07 PM
    NWTundra11
    So...
    Gave it a look again today and sure enough, drivers side cam tower/valve cover gasket has a nice little leak in the rear corner. Looks like it has cause some build up on the underside of the crossmember as well from the oil catching the wind and coating the crossmember. Nothing major obviously but an $1800 fix at the Toyota Dealer locally.
    Unless they come down a chunk in price i dont feel like a $20k truck should leak a drop...
    757TUNDRA, Mysticwolf and 040Tundra like this.
  14. Oct 9, 2017 at 2:21 PM
    tmart
    tmart New Member
    Travis
    I wouldn't pay that price, that's a lot of mileage and the smaller motor. I'd keep looking
  15. Oct 9, 2017 at 2:31 PM
    NWTundra11
    Thanks. I have em down to 18k now actually (20 with taxes and license fees)
    If they dropped it the cost of the service for that leak I might be tempted
    TheBeast likes this.
  16. Oct 9, 2017 at 2:55 PM
    TheBeast The Beach
    yep it is very common. Gives you some leverage on the sale ;)
  17. Oct 9, 2017 at 2:57 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    It would map a code from what I remember. So a check engine light could be on if this was the case. If it was cleared you'd need to unplug the battery for a bit, reset and drive it for a bit to get it to "re-code". Alternatively you would have to pull the AIP/S from the truck to confirm and clean. The pumps are located in two different spots the 4.7 valves and pump are under the intake manifold.
    Should note: This wont damage or detriment your truck in any way if failing, however, it's an EPA required device and can cause emissions failure.
  18. Oct 9, 2017 at 3:22 PM
    128K less mileage
    Bigger engine
    Higher re-sale
    $15k
    I would keep looking or get this
    757TUNDRA, FlashCulprit and TheBeast like this.
  19. Oct 9, 2017 at 3:40 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Nothing to be overly concerned with...
  20. Oct 9, 2017 at 3:55 PM
    NWTundra11
    Thanks all - search will continue. Have a line on a 2011 with 85,000 miles for not much more
  21. Oct 9, 2017 at 4:02 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Not a snow balls chance in hell I would pay $20k for a truck with 208,000 miles on it and being the 4.6l.
    JTP, kenomouth64 and T-Rex266 like this.
  22. Oct 9, 2017 at 4:05 PM
    NWTundra11
  23. Oct 9, 2017 at 4:06 PM
    Your OP says 208
    mdavis likes this.
  24. Oct 9, 2017 at 4:10 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    keep looking I got a 15 4.6L SR DC with 28K on it for 23,000$
    JTP and kenomouth64 like this.
  25. Oct 9, 2017 at 7:33 PM
    Ericsopa
    Ericsopa Old man and the sea
    Yeah...I had (have) exactly the same thing on my '13 CM when I bought it. Always assumed it was from the battery.
    Wynnded[QUOTED] likes this.
  26. Oct 12, 2017 at 5:35 AM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Anyone look at the battery tray under the battery?
    That corrosion might wind up spraying all over the place like that with rain coming through the grill at speed too.
  27. Oct 12, 2017 at 5:35 AM
    JTP
    The Big Black Moose
    Ditto
  28. Oct 21, 2017 at 2:51 PM
    badams1897
    badams1897 New Member
    Bobby
    2013 Tundra Black Limited with Canyon Red Interior
    3.5" Level Kit in Front and 2" in back. MB TKOs 285/65/20 BFG KO2 ATs
    My 2013 did the same thing as well. I need to get an Interstate battery put in. Curious anyone know if Toyota will pay for a new one? I have warranty until 85k miles.
  29. Oct 21, 2017 at 5:57 PM
    BIGUGLY
    Paul
    2018 Limited
    Buy a better battery, interstate, or optima. I had horrible luck with Napa branded batteries off gassing and corroding areas around the battery. Asked a mechanic friend and he stated all low price batteries will start your vehicle but there not sealed as well as some of the premium brands. I switched to optima and never again had any corrosion issues.
  30. Oct 21, 2017 at 6:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think batteries are considered consumable.
