What is the filter in the air box lid
Discussion in 'General Tundra Discussion' started by 2015Crewmax, Feb 28, 2020.
  1. Feb 28, 2020 at 3:22 PM
    2015Crewmax
    2015Crewmax [OP] New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
  2. Feb 28, 2020 at 3:28 PM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    I've been told it's a charcoal filter
  3. Feb 28, 2020 at 3:37 PM
    Cthulhu
  4. Feb 28, 2020 at 4:26 PM
    It's just a filter for emissions when you shut the truck off. Most of us remove it. It won't hurt anything at all by removing it.
  5. Feb 29, 2020 at 8:24 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    so let it in,ya I'm a liberal
  6. Feb 29, 2020 at 8:43 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Except for you chances of passing a smog check. If the Tech notices it’s gone he can fail you I believe. It’s considered a modified emissions device.
    That being said I would remove it.
    EDIT: At least this is the case in CA
    ATV25 likes this.
  7. Feb 8, 2022 at 6:59 PM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    I just removed mine, are they supposed to be this dirty?![​IMG] (Pic is the post below this one)
  8. Feb 8, 2022 at 7:03 PM
    TundraTRD08
    Wesley
  9. Feb 9, 2022 at 1:18 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    at 15 years old, not surprised its dirty. That bottom corner with what looks like a burn might be a little concerning to see.....
    TundraTRD08[QUOTED] likes this.
  10. Feb 10, 2022 at 8:55 AM
    TundraTRD08
    Wesley
    Makes sense. And actually that “burn is kinda like an oily substance. It was inside the intake(still is) throttle body, and hose thing in between the air box and throttle body. I replaced this piece and the throttle body and now I’ve taken this out. Any clue why oil is coming up? Looks like it’s been doing it a while.
  11. Feb 10, 2022 at 9:58 AM
    MadMaxCanon
    It makes sense if it was on your TB as well. Probably years of small residual fumes and dirt mixing together. I dont think I would be worried about it if everything is running fine and you arent failing smog or anything.
  12. Feb 10, 2022 at 5:15 PM
    TundraTRD08
    Wesley
    Probably, and a lack of smog checks is one of my favorite things in Arkansas!:rofl:
  13. Feb 10, 2022 at 5:30 PM
    MadMaxCanon
    Oh ya haha forgot. That's amazing.
