What is the difference between a pre load collar lift spacer and something like a Bilstein 5100?
Discussion in 'Suspension' started by TRDProMTB, Mar 23, 2025.
  1. Mar 23, 2025 at 2:19 PM
    TRDProMTB
    TRDProMTB [OP] New Member
    2021 Tundra TRD Pro & 2025 Tundra 1794 Hybrid TRD OR
    I’m trying to understand the difference between the two. Doesn’t the bilstein achieve lift by doing the same thing a pre load spacer does? If both provided the same amount of lift wouldn’t they theoretically provide the same ride, handling, and comfort?
  2. Mar 23, 2025 at 4:57 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    You are not preloading - the spring rate remains the same with either lift. On a spacer lift, you are placing a spacer at the top of the shock between it and the chassis shock bracket. In this setup what you gain in lift, you lose in amount of travel. With 5100’s the lift is at the bottom of coil, where it sits on the shock, so you don't lose suspension travel.
    The other affordable lift using OE shocks is to replace the OE coils with slightly taller ones, like OME coils.
  3. Mar 27, 2025 at 9:44 PM
    textundra12
    textundra12 New Member
    I’ve never liked how spacer lifts ride. I would recommend going 5100. 6112 even more so
  4. Mar 30, 2025 at 10:10 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    A preload collar spacer (i.e. spacer between top of spring and the "hat" of the coilover) will have the same effect as preloading from the bottom like when you move the lower spring perch up on a 5100. However, I'm pretty certain the 5100 has a slightly longer extended length than the stock struts so while you are still losing the travel with both, the 5100 gives you more to start with so you have that amount more in the end.
    TRDProMTB[OP] likes this.
  5. Mar 30, 2025 at 3:17 PM
    caboj
    caboj New Member
    CA
    2018 Tundra CM TRD OR
    If both are same amount of lift with same spring then yes, you get the same amount of lift. However, each will put you in a different range of the shock’s stroke. Each being in a different stroke range will alter how the shock reacts to the same bump, rut, freeway transition, etc. A spacer puts more preload on the shock and puts you closer to the end of its range. A collar / clip moved up will put you higher in the shock range. Most agree, and myself, that the spacers don’t feel as good. Your past the small bump sensitivity and already closer to firmer end stroke support which is why they ride harsher.
  6. Mar 30, 2025 at 3:23 PM
    Libagui
    Libagui New Member
    Librado
    2024 midnight black Toyota Tundra Limited, TRD offroad
    https://www.tacomaworld.com/threads/the-ultimate-tacoma-lift-guide.509171/
