What is the best spray or roll?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jodigatorz, Oct 22, 2018.
  1. Oct 22, 2018 at 5:56 AM
    Jodigatorz
    Jodigatorz [OP] New Member
    2014 tundra dbl cab
    2" level kit black rhino wheel
    Should I get the spray in or roll on bed liner? Does anyone have experience with this?
  2. Oct 22, 2018 at 6:14 AM
    Spray. Nice even coat.
    Jodigatorz[OP] likes this.
  3. Oct 22, 2018 at 7:56 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    If you're having it done professionally it should be sprayed. If you're doing it yourself and have the ability to spray that'll probably come out better.
  4. Nov 27, 2018 at 9:23 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I used to spray professionally, and that’s always best...
    But if you want to save money and do it yourself, rolling wil give you adequate thickness...then use spray over it to get a beautiful even texture.
  5. Nov 27, 2018 at 9:42 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    Spray in bedliner is the way to go. I pushed it off as a waste of money, but later regretted and it was worth the extra coin. Plus it has a lifetime warranty.
