What is the best oil to use for my 2005 Toyota Tundra?
Discussion in '1st Gen Builds (2000-2006)' started by Tundra Man 05, Jan 25, 2022.
  1. Jan 25, 2022 at 7:06 AM
    Tundra Man 05
    Tundra Man 05 [OP] New Member
    2005 Tundra
    Should I use the Toyota brand oil and filter or is there a better product out there? I just purchased a 2005 Tundra and it is time for an oil change. I want to do it right?
  2. Jan 25, 2022 at 7:16 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Use any oil you can afford, that does the job that meets Toyota's specifications, which is just about any oil brand.
    Use the weight they specify and change filters at every oil change.......done
  3. Jan 25, 2022 at 7:27 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yes almost any Full Synthetic will help to clean engine internally. Even Wallyworld's full synth would work fine.
    I do like Mobil 1 for its cleaning claims, see attached:
  4. Jan 25, 2022 at 7:42 AM
    Wallygator
    The oil that says 5w30 on the bottle should work great for your application
