What is a differential drop kit?Do I need it for leveling?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ttprodr, Oct 25, 2015.
  1. Oct 25, 2015 at 8:18 AM
    Ttprodr
    Ttprodr [OP] New Member
    15 CM 4X4 Tundra
    18x9 level 8 Guardian wheels 275/65/18 Coopers ATP Weathertech Mats (black)
    Quick question,do I need a diff drop kit for a front only 2.5" leveling kit for a 4x4 2015? Im in the supreme suspension website and they offer both,one with and one without diff drop kit,but have no idea what is it or if I needed.
  2. Oct 25, 2015 at 8:40 AM
    For a 2.5" drop, you do not really need a diff drop. I advise using a diff drop. It will maintain suspension geometry close to factory and will make for a much better alignment IMO. @LOTSOFTOYS installs a lot of aftermarket kits and does a ton of alignments and he can give you the best answer on this topic.
    Ttprodr[OP] likes this.
  3. Oct 25, 2015 at 8:56 AM
    Ttprodr
    15 CM 4X4 Tundra
    Im trying to do a front 2.5" lift instead of a drop.
  4. Oct 25, 2015 at 9:00 AM
    I made a typo. I meant 2.5" lift. oops. Everything I said still applies. Diff drops are fairly easy to install and cost about $30 or so.
    Ttprodr[QUOTED][OP] likes this.
  5. Oct 25, 2015 at 9:09 AM
    Ttprodr
    15 CM 4X4 Tundra
    Ok thank you,
    Any inputs on this brand?
    Fairly all good reviews on Amazon,some guys have upload theyre tundras pictures after the application and is exactly the stance im looking for.
  6. Oct 25, 2015 at 9:13 AM
    ToyTec (Toyota suspension experts and reasonably priced. Tundras.com discount too!):
    T-Rex266 and Ttprodr[QUOTED][OP] like this.
  7. Oct 25, 2015 at 11:17 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    A diff drop does absolutely nothing for your alignment. It just drops your differential a touch so the axles don't have such a steep angle to them. It'll save the cv boots a little longer.
    Sefferston, T-Rex266 and Ttprodr[OP] like this.
  8. Oct 25, 2015 at 11:27 AM
    I knew you would have better info. heh heh. The SPC UCAs would help with alignment/geometry for my 3" setup right? You would do a dead nuts alignment for me once I get them per your recommendation.
  9. Oct 25, 2015 at 11:51 AM
    15whtrd
    15whtrd Mr. Blonde
    I wonder if the TRD pro would benefit from a diff drop?
  10. Oct 25, 2015 at 11:54 AM
    I don't know for sure but I would assume the Pro suspension is very finely tuned already and no doubt engineered quite well to perform pretty good "out of the box".
  11. Oct 25, 2015 at 11:57 AM
    15whtrd
    15whtrd Mr. Blonde
    I was just thinking more along the lines of the CV boot. Basically why I was bringing up the question is, when I go in to the dealer when my lease to own is up, I plan on having the dealer do a pro lift installation rolled into my financing.
  12. Oct 25, 2015 at 12:10 PM
    I had a brain fart about the diff drop. Won't be the last. That's why it's good to have @LOTSOFTOYS here. Too high an angle puts a lot of stress on the CV joint and can cause premature failure (always not good. hehheh) You could probably swing a good deal for the Pro lift install at end of lease which will not be cheap but no warranty issues either. Sounds like a good plan to me. Some here will say to save some money and go aftermarket which is very wise but your idea sounds good too.
    15whtrd[QUOTED] and Ttprodr[OP] like this.
  13. Oct 25, 2015 at 1:03 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes spc for your setup would be awesome.
    As for diff drops. Anything over 2 inches up front I'd do it... it's cheap and could help.
    Did someone say they wanted pro suspension???
    Please don't waste your money.... buy a real lift kit
  14. Oct 25, 2015 at 1:14 PM
    It will be done (SPC's that is). Before next spring.
  15. Oct 25, 2015 at 1:16 PM
    You should check out ToyTec lifts before you do the Pro suspension. Quite possible to still work out financing at end of lease time
    15whtrd[QUOTED] and T-Rex266 like this.
  16. Oct 25, 2015 at 2:07 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    That and a 1/3 of the price
    T-Rex266 likes this.
  17. Oct 25, 2015 at 2:31 PM
    15whtrd
    15whtrd Mr. Blonde
    The only reason I was going pro suspension is, I was under the assumption that it was fine tuned for the Toyota and superior over other lifts in ride quality. Not so generic. And i was hoping less issues with other supporting suspension mods to get it right. Im wanting the longevity of oem suspension and ball joints. Im trying not to increase service intervals. I guess i could do do 2" spacers and 2" diff drop... Not really gaining much other than ride height. I guess thats ok with some decent reservoir shocks.
  18. Oct 25, 2015 at 2:53 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Do some more research man. But the pro suspension is crazy over priced
  19. Oct 25, 2015 at 2:54 PM
    If u want to spend that much on a lift, just go with Toytec BOSS lift ...they're coming out with rear resevioirs for the Tundra too.
    15whtrd likes this.
  20. Oct 25, 2015 at 3:19 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes definitely was going to do a lot more research before I do anything. I have plenty of time before I'm actually going to do this. I just saw the thread and figured I'd bring up the topic. Sorry to jack your thread Op
  21. Oct 25, 2015 at 4:09 PM
    chphilo
    chphilo Tundra addict
    Western PA
    There's a vendor on TurdraTalk who completely took apart pro suspension. He was quite impressed with the design and quality. Guys who have Pro or have installed Pro suspension seem to be extremely happy with the ride. I haven't read a single regret or complaint (except from pro-King/Fox/Icon group).
    If I were to do another build, I would go with this one, OME BP-51. It's not available for Tundra yet, but it's coming. OME has developed this for the last four years. I am sold on OME quality and this is exciting development.
    https://www.youtube.com/watch?v=DxfOlbRNpbM
    Black Wolf likes this.
  22. Oct 25, 2015 at 6:16 PM
    Stay away from spacers if you can. A Pro suspension is a long way from spacers. Call the guys at ToyTec at least. Can't hurt. As far as reservoir shocks: total complete over kill unless you plan on serious 4 wheeling in hot climes and/or long distance pre-runs. I saw some serious bad ass 4X4s in AK without reservoirs. No need for reservoir /re-build-able shocks in that climate or even here in CO. I'm excluding rock crawlers. (It can get pretty hot here in the summer) My OME shocks ,for example are "real" shocks. Just like ToyTec Boss shocks are "real" shocks. My OME's were custom engineered for my /our Tundras by Aussie engineers. While "someone" here is re-valving "real" shocks , I'm out 4 wheeling in bad ass places (for decades without "real" shocks apparently) and not at home twiddling my thumbs "re-building/valving " my "real" shocks.Give me a break!! Bring it on!! I'm waiting for clarification on what a "real" shock is. If you can't reach me, I'm out 4 wheeling with my "not real" shocks. You can always catch up with me after re-valving your shocks. Don't expect me to wait while you catch up. :oldglory:
    TruckLife900 and 15whtrd[QUOTED] like this.
  23. Oct 25, 2015 at 6:44 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I wasn't really liking the idea of spacers either. My plan was to run a slightly larger tire with a 2-2 1/2" lift up front and 1.75- 2" CB shackle. I want to do a little bit of crawling, "nothing too crazy" some 40 to 50 miles of fire road/trail/desert and have the ability to hit those at decent speeds. I guess you could call it some pre-running. No Baja 500 LOL. Maybe I'll try to get a few inches of air!! HA!! Of course I'd love to make it ridiculous but it's just not practical for me, it's a daily driver.
  24. Oct 25, 2015 at 6:50 PM
    IMO, I prefer the rear add a leaf over shackles. Shackles would be my second choice over a simple block. If you want air ,you definitely do not want spacers. You need a lift that will allow you to do that without breaking something.
    15whtrd[QUOTED] likes this.
  25. Oct 25, 2015 at 6:55 PM
    Sean,
    The guys at ToyTec will not only listen to you, but will recommend to you what you actually need for what your needs are. Their goal is not only to make a profit but most importantly to satisfy you, like they did to me. Two Sean's here now. Could get confusing. heh heh
    rons23, T-Rex266 and 15whtrd[QUOTED] like this.
  26. Oct 25, 2015 at 6:58 PM
    15whtrd
    15whtrd Mr. Blonde
    I definitely don't want blocks. I'm going to check out Toytec
  27. Oct 25, 2015 at 7:02 PM
    Another good reason to talk to ToyTec is to see if your requirements necessitate a reservoir shock setup. Shackles can give you lift but can have a negative affect on the leafs under load, like a trailer, or slide in camper which will fit with your 6.5' bed. Shackles ,IMO, should only be used on 2WDs at best, maybe. Shackles look better on 65 Nova's. A shackle will never see my truck.
  28. Oct 25, 2015 at 7:31 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No need for shackles on these trucks. Aal or leaf pack. Sounds like a full ome kit would fit u well. If u have some more coin, go boss front coilovers and some ucas and boss rear shocks. I'm a big fan of the Dakar leaf packs. They do great
    T-Rex266, 15whtrd and Black Wolf like this.
  29. Oct 25, 2015 at 7:34 PM
    By the way, I want the Dakars too, along with the SPC's. I know you can do the SPC labor at Stevenson's, but can you install the Dakars too?
  30. Oct 25, 2015 at 7:36 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Nope too hard, that's where I draw the line of my mechanic skills :stirthepot:
