  1. Apr 30, 2019 at 5:17 PM
    AZTundra
    Paul
    Phoenix, AZ
    Must be the under seat storage?....image on box gave it away. :thumbsup:
    Paulskie and Deafmate like this.
  2. Apr 30, 2019 at 5:17 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    What is it?
    Deafmate likes this.
  3. Apr 30, 2019 at 5:41 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Installed white mirror caps. Thanks Toyota Cool Springs!
    GAknight, aperezsh, Deafmate and 7 others like this.
  4. Apr 30, 2019 at 5:42 PM
    PNW-Tundra
    PNW-Tundra New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    Yep, the plastic under seat storage. :thumbsup:
    TokerJoker likes this.
  5. Apr 30, 2019 at 5:42 PM
    PNW-Tundra
    Brent
    Washington
    ESP Storage for under the rear seat.
    TokerJoker and Omohundro[QUOTED] like this.
  6. Apr 30, 2019 at 6:07 PM
    Myhobbes25
    Myhobbes25 New Member
    Jeffery
    Western Washington
    2014 Toyota Tundra Platinum
    Rigid fog Lights, 35x12.50x20 BF Goodrich KO2 Tires, 20x9 Fuel Trophy Wheels, Pro Comp Stage 2 Full Suspension Lift 6 inches, K&N Intake, Magnaflow Muffler, Husky X Contour Floor mats, Pina Colada Scented Tree
    Replaced my cut fender Liners
    GAknight, Deafmate, Ostrich and 2 others like this.
  7. Apr 30, 2019 at 6:15 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Where did you get those from sir. Thank you.
  8. Apr 30, 2019 at 6:19 PM
    Myhobbes25
    Jeffery
    Western Washington
  9. Apr 30, 2019 at 6:32 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
  10. Apr 30, 2019 at 6:38 PM
    Myhobbes25
    Jeffery
    Western Washington
    KELZ84[QUOTED] likes this.
  11. Apr 30, 2019 at 6:49 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I found these. I do not have myself. My question is do these allow for fitting larger tires or just replace the same size I already cut up to fit my tires?
    Fits 14-18 Tundra P/U Front Splash Shield Inner Fender Liner Left Right SET PAIR https://www.amazon.com/dp/B07DNK4MT5/ref=cm_sw_r_cp_apa_i_7PpYCbH6W79VZ
    Major[QUOTED] and KELZ84[QUOTED] like this.
  12. Apr 30, 2019 at 6:52 PM
    Myhobbes25
    Jeffery
    Western Washington
    They are factory size. I was able to replace my cut ones because I went to a smaller tire than the previous owner.
    mgm16trdpro[QUOTED] likes this.
  13. Apr 30, 2019 at 6:53 PM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
  14. Apr 30, 2019 at 7:19 PM
    mgm16trdpro
    Northern NJ
    Gotcha tnx. That's what I thought. I was figuring they were about the same and there was some extraordinary circumstances that made u able to replace and use.
  15. Apr 30, 2019 at 7:23 PM
    CaliforniaComanche
    CaliforniaComanche New Member
    2016 White Tundra 4.6l
    DE5B5598-E594-43C3-A476-069BFBED4000.jpg BF610D38-95F5-4BFD-A386-DFCFB69BA598.jpg B5A00354-4C07-47E5-823A-775D67FC2B47.jpg
    Finally got my bora 2.5 inch spacers on !!
  16. Apr 30, 2019 at 7:25 PM
    Blueknights75
    Ron
    Clayton, NC
    One of the best mods!
  17. Apr 30, 2019 at 8:34 PM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Anyone know Where can get those U clip nut?
  18. May 1, 2019 at 5:59 AM
    bhuff92
    bhuff92 “Hi, I’m Rod and I like to party”
    Ben
    Columbus, Ohio
    2018 Charcoal Tundra SR5 Crewmax
    Iron Cross Front Bumper with Grille/Brush Guard.
    Be sure to let us know how the install goes...heard it was relatively easy.
  19. May 1, 2019 at 6:10 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    The dealership told me that yesterday, when I took mine in for the ToyotaCare free oil change. I'm going to contact the dealer that I bought the truck from today and see how they are going to handle it, they had a DSI conversion done on the truck before I bought it, which comes with a 3 year/36K warranty.
  20. May 1, 2019 at 6:33 AM
    bhuff92
    Ben
    Columbus, Ohio
    Amazon has a small phone magnet that works out really well. https://www.amazon.com/gp/product/B07BLYSVK2/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
    It comes with two magnets. I think one would work just fine, so you can give the other to a friend or spouse. But since no one else drives my truck, I put both of them on my phone case so I can use it in both horizontal and vertical orientations. Vertical is mainly for storage or plugged into the usb charger. The horizontal orientation is great for maps! Snug as a bug, has never dropped off for me.
    I also added another magnet, but this is for a Glock or a square like slide for any handgun. I'm sure most of you have seen these before. This magnet has never dropped my firearm or even wiggled. Yes I hated drilling into the dash but was totally worth it.
    No, I am not affiliated with Amazon or these magnets, just passing along the info.
    Deafmate and mgm16trdpro like this.
  21. May 1, 2019 at 8:41 AM
    tundradownsouth
    tundradownsouth New Member
    New Orleans
    19 tundra crewmax
    Another member had use these so I followed suit. dechromed the grille with sprayable vinyl from superwrap. Not as glossy as I hope but it works. maybe after a wash it’ll match better
    GAknight, Nebz, monaco730 and 10 others like this.
  22. May 1, 2019 at 10:29 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    How did you like using that stuff? I'm debating trying their "wheel kit".
  23. May 1, 2019 at 10:54 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Did you have to prepare the chrome in any way before applying? How does it appear to be bonding to the chrome?
  24. May 1, 2019 at 11:36 AM
    PNW-Tundra
    Brent
    Washington
    Husky X-Act Liners in front and rear (yes, my truck is filthy).
    JoshuaA, aperezsh, TokerJoker and 3 others like this.
  25. May 1, 2019 at 11:36 AM
    PNW-Tundra
    Brent
    Washington
    Will do. Plan on doing it tomorrow or Friday.
  26. May 1, 2019 at 11:54 AM
    Long awaited overdue, reflective vinyl, special thanks to @DecalsByDesign your the sheeeeznit!!!
    Night shot later on
    GAknight, JoshuaA, bhuff92 and 8 others like this.
  27. May 1, 2019 at 12:36 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    Is it night time yet?
  28. May 1, 2019 at 12:38 PM
    Ibanez6224
    Ibanez6224 New Member
    2019 TRD OR
    Great looking truck! What kind of lift you got on there? I'm struggling picking between sticking with an 18" or 20" wheel. I'm currently on 18". Really like the gloss black wheel look on yours.
  29. May 1, 2019 at 12:46 PM
  30. May 1, 2019 at 1:12 PM
    Blueknights75
    Ron
    Clayton, NC
    @Roman
    Roman likes this.
