  1. May 23, 2021 at 9:45 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    oh, y’all are just a couple of cheech and chongs. :rofl:
  2. May 23, 2021 at 9:49 AM
    BlueRibbon4x4
    Geno
    Looks great! I’d strap that sucker down, like others have suggested. Just an idea for a mounting spot:
    Wallygator, Fotnot, YotaBro and 7 others like this.
  3. May 23, 2021 at 9:55 AM
    Orracle
    Orracle New Member
    Canton, GA
  4. May 23, 2021 at 10:15 AM
    18" TRD Off Road Wheels
    Nothing but painted metal. Stock photo from the google machine to illustrate.
    Tundrastruck91 and mgm16trdpro like this.
  5. May 23, 2021 at 10:15 AM
    Orracle
    Orracle New Member
    Canton, GA
    Its just flat. The letters are just stuck on. Can be remove with a heat gun
  6. May 23, 2021 at 10:22 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Put on my 1.25" Bora spacers yesterday. Also let the axle droop and sprayed with compressed air and lube in an attempt to fix a squeak I've been having. Only to have the bright idea to grab and shake my spare tire to find the culprit. Dropped it, wiped everything down and sprayed some lube in the lifting mechanism, lifted the tire back up making sure it was tight and no more squeak.
    No rubbing anywhere, especially on the LCA skid (main reason I got them). I tell you what I was over it by the time I finished the 5 mile test run they recommend, then had to take all 4 wheels off again to check torque. Just had to be the hottest day of the year so far :rolleyes:. Had to wire brush the wheel interface, the hubs, the base of the studs before being able to install them.
    Btw I know the wheel key is on the wheel still in one of the photos, I grabbed it after.
    Astom22, Wallygator, Jpd0144 and 11 others like this.
  7. May 23, 2021 at 10:26 AM
    Newey
    Newey New Member
    Bill
    2021 Lunar Rock TRD Pro, 2016 Tundra TRD CM, 2010 Tundra SR5
    Rough country 30"....
    Taco-Spike[QUOTED] likes this.
  8. May 23, 2021 at 10:31 AM
    Newey
    Newey New Member
    Bill
    Where were you able to get the emblem cover since AJT is no longer selling them?
  9. May 23, 2021 at 10:40 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Bill I got mine off EBay. And fit fine and the finish is nice on it. What 30 inch light bar did you add?
  10. May 23, 2021 at 10:42 AM
    Newey
    Newey New Member
    Bill
    Don, it's the rough country 30", and man is it bright. They told me after the install that I may get ticketed, LOL
    RusPro21[QUOTED] likes this.
  11. May 23, 2021 at 10:43 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Looks good! It’s going to be a while until I can get rid of all the exterior chrome. It’s on the list though.
    MatD13[QUOTED] likes this.
  12. May 23, 2021 at 10:43 AM
    RusPro21
    Don
    Pa.
    Thank you I had the 20 inch Bajadesigns on my 4runner Pro and sold it cause I traded my 4runner in. I plan on adding another to my tundra.
  13. May 23, 2021 at 10:45 AM
    RusPro21
    Don
    Pa.
    I forgot to ask what did you do with adding the switch inside. I removed a blank spot in my 4runner and adding onboard switch. I plan to do the same.
  14. May 23, 2021 at 10:47 AM
    JC21Tundra
    JC21Tundra If I'm not here, I'm somewhere else...
    Jeff
    St L Missouri
    2021 MGM Tundra Crew Cab TRD Sport 4x4
    Bed rails installed, it can be done after the Toyota spray in bed liner, just need to find the holes and clean out for the bolts.
    Wallygator, Jpd0144, Ostrich and 8 others like this.
  15. May 23, 2021 at 10:52 AM
    Newey
    Newey New Member
    Bill
    They added a switch to the left of the steering, never asked where I wanted, and I never thought about it.IMG_2748.jpg
  16. May 23, 2021 at 10:54 AM
    Newey
    Newey New Member
    Bill
    Just ordered mine....Thx for the info.
  17. May 23, 2021 at 10:55 AM
    Newey
    Newey New Member
    Bill
  18. May 23, 2021 at 11:41 AM
    Cthulhu
    Great idea, though I do have 3 people in the backseat often. I was thinking about another post I saw where someone mounted it to a SwingCase, but I’m worried about having it exposed to the elements since I don’t have a bed cover. Might just go ahead and use an aluminum bar to mount to the front seat bolts, or, drop the coin on the Desert Does It setup.
  19. May 23, 2021 at 11:42 AM
    Pulled my lights and sprayed them with Raptor Liner.
    Wallygator, Jpd0144, Ostrich and 19 others like this.
  20. May 23, 2021 at 11:57 AM
    Redacted
    Redacted New Member
    MA
    2014 SR5 TRD
    3" level kit
  21. May 23, 2021 at 12:01 PM
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    Decided to do something different on the grille badge placement and I had my tow hooks painted. What do y’all think?
  22. May 23, 2021 at 12:07 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Looks good!! I basically did the same thing.
    The Towse Tundra 2.0 likes this.
  23. May 23, 2021 at 12:30 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Swapped my mis-matched sub (box was too small and sub was 8-ohm) with a secondhand James Tech12Volts special. Sounds soooo much better. Also added sound deadening since I had to pull the factory carpet/curtain thing.
  24. May 23, 2021 at 12:41 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Different grill, but same vintage colors.
    Wallygator, Jpd0144, Ostrich and 7 others like this.
  25. May 23, 2021 at 12:50 PM
    Doccountry69
    Doccountry69 New Member
    Mark
    Little Elm
    2020 Tundra Voodoo Blue
    So, how'd it go? I Just bought a Toy hauler, I probably need bags, etc
  26. May 23, 2021 at 12:52 PM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    I have the Air Lift bags on mine... Can be a bit rough even at 5 PSI as the back-end is SOLID. Tows great though, no sag whatsoever.
  27. May 23, 2021 at 12:53 PM
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    2016 Magnetic Gunmetal Metallic Platinum
    Tinted Windows, Baja Designs LED Fog Lights, EGR Matte Black Bug Guard, SCS SR8 Gunmetal wheels, 295/70/18 Nitto Ridge Grapplers, 3/1" Readylift Kit, Morimoto XB Headlights, Viper Smartstart Remote Start, Kobalt Low-Profile Toolbox, Husky X-Act Contour Floor Mats
    Prototyping a 3D printed overlay for the steering wheel, if I can get it all dialed in I'll paint match it MGM.
    Astom22, junior, SpooledReel and 15 others like this.
  28. May 23, 2021 at 12:57 PM
    Cfincke
    San Antonio
    Start with a WDH to transfer some of the weight to the front axle and back to the trailer.
    I did bags because my leafs are starting to flatten out since my truck has extra weight - rock sliders, 46 gallon tank, full size 37" spare, bed cover. I run at 5psi for daily driving and the rear has a bit more bounce, but was good when towing with 22psi.
    Watch your payload on the truck, most toy haulers transfer a lot more hitch weigh than a standard travel trailer.
    Wallygator and GODZILLA like this.
  29. May 23, 2021 at 1:18 PM
    BlueRibbon4x4
    Geno
    Ah, nice idea.
  30. May 23, 2021 at 1:27 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    The backseat is actually not that bad. ( I heard from a friend.) :rofl::rofl::rofl:
