  1. Oct 3, 2020 at 7:28 PM
    TundrasseeMan
    TundrasseeMan New Member
    Ryan
    Nashville, TN
    2020 Cavalry Blue Tundra
    It’s hard to tell online videos just how sweet it is. Just get you one if you’re considering it.
    Bama and GODZILLA like this.
  2. Oct 3, 2020 at 7:29 PM
    TundrasseeMan
    Ryan
    Nashville, TN
    Thanks man!
  3. Oct 3, 2020 at 7:29 PM
    TundrasseeMan
    Ryan
    Nashville, TN
  4. Oct 3, 2020 at 8:47 PM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    My thought on this is the distance from the bottom of the strut to the top does not change; the stroke remains the same regardless of where you put the clip. This theory would only apply if someone used a spacer at the top of the strut. My guess is Bilstein includes the spacers/shims because the coils might touch each other at full compression.
    Rica25 likes this.
  5. Oct 3, 2020 at 9:13 PM
    00PS
    00PS New Member
    300 mile update. It is still a huge difference between with and without the resonator. Wife approves riding in the truck again and with the weather being so good in Texas right now, with the windows down it almost sounds the same. I will say it is nice to have a quieter cabin for the longer stretches. I do miss the rumble in the cab, but I think the resonator is staying on.
    GiantWinston, HaveFun and Rica25 like this.
  6. Oct 3, 2020 at 10:06 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    That’s my happy place man, I’m up there every year!...been going up for the last 25 years straight, would love to get together...I actually hosted a get together for a bunch of guys in a Nitro bass boats forum, it was a blast
    Rica25 and Major[QUOTED] like this.
  7. Oct 3, 2020 at 11:38 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    So your saying if I cut the “GREEN” wire and cap it. The image will be correct? Did you do this and it worked?
  8. Oct 4, 2020 at 4:59 AM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Am I tripping or does your nipple look different than mine? Is it simply for the "faster flow"?
  9. Oct 4, 2020 at 5:34 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    There are 2 versions....one with a longer nipple and one shorter
    Major[QUOTED], ElNopal and GODZILLA like this.
  10. Oct 4, 2020 at 5:42 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    Drivers side grab handle mod is done. Should've done it months ago. Super easy.
    AggiePhil likes this.
  11. Oct 4, 2020 at 6:13 AM
    2020Platinum
    Patrick
    Northeast PA
    Hey Paul, cutting one of the wires will correct the image, cutting the other will get rid of the “distance lines”...if you watch my video, at the 27 minute and 8 second mark I talk about those wires...they do this because most people use these cameras on the back of the truck so you would want the image mirrored...but when mounted on the front, you have to cut the wire to “fix” the image...cameras are different though, your instructions should have told ya what one to cut for image and what one for lines...hope that helps!
    https://youtu.be/7Axamo4_nlE
  12. Oct 4, 2020 at 6:19 AM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    Looking to purchase soon and was wondering if there is a reason to choose one over the other. I see on there website that you can get a cap for the long nipple and they have kits for both but looks like Amazon is a little cheaper on the valve itself.
  13. Oct 4, 2020 at 6:43 AM
    2020Platinum
    Patrick
    Northeast PA
    It’s kinda personal preference but some say the shorter is better on certain trucks just because it doesn’t hang as low (bigger deal if you rock crawl or off-road a lot)...I went with the shorter one just to be on the safer side but not sure it matters as much on our tundras, maybe someone else can jump in...you can also use that cap for the shorter nipple, I just trimmed mine slightly...you have to use an adapter on the shorter one as well, where as the longer one you just pop the drain hose directly on it...no biggie, the adapter pops right on and off...can’t remember if mine came with adapter or if I had to buy separately, it’s just a little plastic piece (can get a straight one or a 90 degree angled one)...bought mine a couple weeks ago and sounds crazy, but I’m thinking about changing my oil early just to put it on :rofl:
    Major, ElNopal and NewImprovedRon like this.
  14. Oct 4, 2020 at 6:49 AM
    jrquist
    Carlton, Minnesota
    I just hit 4000 miles and want to change my oil soon and plan on adding the Fumoto valve when I do. I don't do any rock crawling but might run into deep slushy snow if that could be a concern. Think I will just go with the short nipple and get the hose kit.
    2020Platinum and ElNopal like this.
  15. Oct 4, 2020 at 7:08 AM
    phi482
    phi482 New Member
    KY
    2020 Cement Limited TRD Off-road
    Looks really good! I would love to this as it’s a pain finding things in the dark with the cover down. I don’t need all the rope lighting from the other mod, just need a little light like this.
  16. Oct 4, 2020 at 7:16 AM
    jrquist
    Carlton, Minnesota
    Just checked and found that there is a upgraded version so instead of the F103 S or N there is now a F133 S or N which is to allow for faster draining.
  17. Oct 4, 2020 at 7:42 AM
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    Thanks for this feedback. I'll definitely be using the resonator with mine.
  18. Oct 4, 2020 at 7:48 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Yes, that is what I found too. The F133’s (N or S) are supposedly 60% larger body for a faster drain flow. I went with the F133N because I am not “lifted” yet... and was not sure about clearance.
    GAknight, Major and NewImprovedRon like this.
  19. Oct 4, 2020 at 7:50 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    My Re-gear is finally broken in with 550 miles. I went to change the diff fluids and found the shop that re-geared it stripped the drain plug.
    C6632B67-66BD-4673-AB3A-1EDAFBA5E618.jpg D41B9C0B-61D7-40AA-B7CB-BC331F8D2211.jpg 51713389-37E5-4EC7-AF43-A00104EDFF15.jpg
  20. Oct 4, 2020 at 7:56 AM
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    Very nifty.
    Would still give them an earful
  21. Oct 4, 2020 at 8:11 AM
    PeakIT
    PeakIT Old Member
    Utah
    The day I got it home it had an axle leak and they wanted me to leave it 3 weeks until they had an open spot. I pulled the axle and did it myself. I’m done with them and told all my friends in the industry and car / truck groups about their integrity.
    NewImprovedRon likes this.
  22. Oct 4, 2020 at 9:42 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Chris - not sure where in Utah you live but also being here I would like to know who did it to add to my list of "do not use".
    Long Duck Dink likes this.
  23. Oct 4, 2020 at 9:52 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Just ordered an aftermarket Pro grill with the sensor garnish for less than $300 shipped :bananadance:
  24. Oct 4, 2020 at 10:16 AM
    Elfine
    Elfine Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    Decided to check out some post Sally trails. They are definitely different then before.
  25. Oct 4, 2020 at 10:57 AM
    biebs96
    PA
    ...and done!
    I’m sure it would have never been a problem long term, but all it would take would be that one hard bump to cause everything to bottom out.
  26. Oct 4, 2020 at 11:35 AM
    Vuducrumax
    Vuducrumax New Member
  27. Oct 4, 2020 at 12:40 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Son bought me a mini dvr for my birthday. Just got done doing a test drive.
    I have it set up so that anytime I toggle a camera on to my display it records. It could be done different but it would complicate the install so I went the path of least resistance.
    https://youtu.be/jLKbt2a-lEo
  28. Oct 4, 2020 at 12:46 PM
    French Avocado
    Utah / Wyo
    Really like the install. You should do a write up.
  29. Oct 4, 2020 at 1:52 PM
    PeakIT
    PeakIT Old Member
    Utah
    Six States SLC
  30. Oct 4, 2020 at 2:01 PM
    Also added front and rear footwell lights.
    Scary dash removal but very easy to do.
