WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Jul 8, 2022 at 5:54 PM
    #781
    Outbound
    Aaron
    Northern Alberta
    I ordered a Diamondback SE and CrossBin 8. My truck should be here at the end of the month. :D
    StrikeZone and Ray D like this.
  2. Jul 8, 2022 at 7:45 PM
    #782
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    will have to keep my eye out… ordered one a few weeks back on Amazon and it looked like a good fit but the tape was too deep into the emblem and wouldn’t grab onto the factory one… ended up throwing it in the wife’s Corolla…
  3. Jul 8, 2022 at 10:19 PM
    #783
    saleen079
    saleen079 New Member
    22 Tundra Limited TRD
    Lots of DIY stuff
    Just finished the rotopax Mounts. Ordered some timbrens today as well. Gotta keep my ass from sagging when pulling the camper so I can save on gas.
  4. Jul 10, 2022 at 1:05 PM
    #784
    murtro
    murtro Life is unpredictable. Eat dessert first!
    Alberta
    Upgraded the QI wireless charger by adding 2 of these and running the wiring under the console = clean! I drilled a 3/4 hole through the coin slot on the left to bring the wires into the console.
    This is the best and cleanest way I know of for wireless charging that works on iPhone 13 for now - until someone customizes a replacement piece for the OEM one.
    I made a small notch in the trim under the chargers so the wires are not pinched. There is a rubber overlay on top so you don't even see the wires or the notch.
    This is the video for how to get access to run your wires underneath, I couldn't get the shifter off but you really don't need to:
    https://youtu.be/YIQKJ8wqjmw
    Wildcat80236, DBamaC, KClav and 9 others like this.
  5. Jul 10, 2022 at 1:39 PM
    #785
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Well done
    murtro[QUOTED] likes this.
  6. Jul 10, 2022 at 4:39 PM
    #786
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    Very nice!! May I ask, what's wrong with the stock one?
  7. Jul 10, 2022 at 4:51 PM
    #787
    murtro
    Alberta
    The stock QI charger will not charge an iphone 13. Like at all. It'll connect for 15 seconds max and then disconnect. Some people say its the case - but I've tried a few different cases as well as no case at all. Others have said it's because the camera sticks out further than other phones and creates a gap between the weak QI charger and the phone - to me this seems to be the correct reason.
    Regardless, it just doesn't work for me, so for now at least this is the best and cleanest (hate wires going everywhere) solution. I tried just running the wire under the trim on the side of the console but my OCD was still bothering me. This new solution is much better.
    Tundra'25[QUOTED] likes this.
  8. Jul 10, 2022 at 5:56 PM
    #788
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Can I ask how hot it was when your iPhone charged then disconnected? I have a Samsung and mine will do the same thing when the phone is hot or the truck is hot from sitting in the sun. Once the cab cools down, my phone charges fine.
  9. Jul 10, 2022 at 7:20 PM
    #789
    murtro
    Alberta
    Interesting. I don’t think heat was an issue with my iPhone 13. I got the truck in late May and live in Canada….so maybe 65 degree days and I tried it several times under normal phone use or just charging on a longer trip. It’s been an issue since day 1. There are many posts on here about the OEM charger being weak for those that get it to work at all and I haven’t seen anyone say they get it to work properly with an iPhone 13. Idk?
  10. Jul 10, 2022 at 7:28 PM
    #790
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    My iphone 13 pro max charges perfect on it. All I have on it is an Apple silicone case. I wouldnt imagine anything any thicker than that would work well. And anything any slicker probably wouldnt stay in place well enough.
    murtro likes this.
  11. Jul 10, 2022 at 7:38 PM
    #791
    murtro
    Alberta
    Oh really! That’s what I have for a case. Ok now I’m going to do more testing.
  12. Jul 10, 2022 at 7:45 PM
    #792
    murtro
    Alberta
    Is your Apple silicone case MagSafe?
  13. Jul 10, 2022 at 7:47 PM
    #793
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    For what it’s worth, I’m running an Otterbox Aneu MagSafe case on my 12 pro, and it stays connected to the OEM charger… definitely not a quick charge, but will stay connected at least… picked up for $16 on eBay
  14. Jul 10, 2022 at 7:52 PM
    #794
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    any worry of double stacking the oem charger then that one?
  15. Jul 11, 2022 at 3:00 PM
    #795
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Got Rays L42 14x1.5 lug nuts with locks delivered today for the wheels that are somewhere in Japan.
    Checking if they fit since haven’t seen anyone run these lug nuts yet.
    Also got ********** screen protector on today. Got it for anti finger print. Was hesitant at first cause of the matte finish. Prefer the factory look, didn’t have issue with glare. But matte finish isn’t too bad with the screen on. Install was easy. Was $5 cheaper on Etsy than on ********** site.
  16. Jul 11, 2022 at 9:27 PM
    #796
    murtro
    Alberta
    It doesn't seem to create any heat issues. Other than that, what's the worst that can happen - the weak / non functional OEM stops working completely? Oh the horror! However I'll keep an eye on it for the next while. :cheers:
  17. Jul 11, 2022 at 9:45 PM
    #797
    Roctane84
    Louisiana
    I looked at a couple screen protectors and considered it but then in the meantime I have noticed that there are no scratches or swirls whatsoever; and I wipe it at least twice a day with a microfiber cloth to get dust and fingerprints off of it. I don’t think its a must have like on a phone or something, but I could be wrong.
  18. Jul 15, 2022 at 9:38 PM
    #798
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Went to the full 3/1 lift today from Westcott Designs.
    A little additional height since I was only running their front level before.
    3/1" lift:
    Front level only (front preload collar with no top hat plate)
    zonehenge, BigArt, Tundra'25 and 7 others like this.
  19. Jul 16, 2022 at 11:20 AM
    #799
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    New shoes and meat…
    Black Rhino Wheels Rapids - 18x9
    Toyo Tires Open Country AT3s - 35x12.50r18
    The poke is a bit more than I wanted, but I’ll make it work… The matte bronze and Lunar Rock combo is fire…
    Westcott 3/1 is in the mail, then on to chrome delete…
  20. Jul 17, 2022 at 9:45 AM
    #800
    HeyMcFly
    HeyMcFly New Member
    2022 Tundra Platinum
    Only being able to like this post is a tragedy cause your truck looks so f’n sweeeet!
    What are the rims/tire combo? I’m a fan of the stock platinum rims but your aftermarket’s are the first I’ve really liked.
  21. Jul 17, 2022 at 10:00 AM
    #801
    HeyMcFly
    HeyMcFly New Member
    What brand are the mounts?
    Roctane84 likes this.
  22. Jul 17, 2022 at 10:28 AM
    #802
    saleen079
    Lots of DIY stuff
    These are the rubber clamps from Amazon. Had to make my own brackets. Got the track Mounts on Amazon as well. Also used them for my rotopax mounts. Hope this helps.
    https://www.amazon.com/dp/B00DEQB3TO
    https://www.amazon.com/dp/B07739WXJB
  23. Jul 17, 2022 at 10:12 PM
    #803
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I had the same initial thought on the poke also (running the Gunmettal version of those Rhinos) but after like 2 days I realized that I wouldn’t want it any other way :thumbsup:
    Medic343 and jmay86[QUOTED] like this.
  24. Jul 18, 2022 at 6:47 AM
    #804
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Yessir, they are perfect...
  25. Jul 18, 2022 at 7:23 AM
    #805
    gr8fasushi
    gr8fasushi 22 Tundra Limited TRD Off Road
    finally got all the pieces to chrome delete! Well, I'm still waiting on the moustache and the rear bumper panels. So close
    dekeman, Roctane84, =JSG= and 5 others like this.
  26. Jul 18, 2022 at 8:13 AM
    #806
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Finally added my letter inserts to tail gateD0A0DD6C-018E-4553-948F-9FB1E8ADA039.jpg75F4263F-C0AB-4154-B63B-363A7F33BF51.jpg
  27. Jul 18, 2022 at 1:55 PM
    #807
    Red13
    Red13 New Member
    2022 SR5 Crew Max TRD Off Road Army Green
    Working on adding 12v power to the bed
    mikeaesq and NCA100 like this.
  28. Jul 18, 2022 at 3:46 PM
    #808
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Westcott 3/1 finally showed up today… going to try and tackle it over next couple days after work…
    Roctane84 and Brums like this.
  29. Jul 18, 2022 at 6:08 PM
    #809
    Buellride
    Olympia
    THE BOULDER
    Fancy new packaging....better than a flat rate box
    WrapCO, GoFast157 and roboots21 like this.
  30. Jul 18, 2022 at 6:12 PM
    #810
    CamsRetriever
    CamsRetriever New Member
    Roseville, CA
    2022 Platinum CM MGM
    First wash and wax
    6C63B692-59CB-41F1-82E7-FFF9FAE7BFA6.jpg 61E3F556-4700-4FAD-9C26-26B92876829B.jpg
    truckit, Henry1jg, 9OH1 and 3 others like this.
