WHAT GRADE FUEL ARE YOU BURNING????
Discussion in '2.5 Gen Tundras (2014-2021)' started by CJ21, Aug 22, 2017.
  1. Aug 22, 2017 at 4:23 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
  2. Aug 22, 2017 at 4:41 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I use 87 in the Tundra. I tried a higher octane and it didn't seem to make a difference with mpg or anything noticeable so 87 it is.
    In my small engine stuff I use the highest octane I can find locally at a pump without ethanol.
  3. Aug 22, 2017 at 4:45 AM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    I use 87 Octane. The majority of the gas station around where I live have up to 10 Ethanol.
    Kurt
  4. Aug 22, 2017 at 5:00 AM
    15whtrd
    15whtrd Mr. Blonde
    87 but 91 smells better
  5. Aug 22, 2017 at 5:08 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    The cheapest, cleanest, 87 I can find. I never top off when a gas tanker is refilling below ground station tanks. A friend in the gas biz says, you don't want the swirling juice at the bottom of the keg :rofl:just motor on to another station where the sediment has settled. FWIW..
    Spyker, MillMatter, iHacker and 15 others like this.
  6. Aug 22, 2017 at 5:12 AM
    Hasteen
    Hasteen To be continued...
    Justin
    Providence, RI
    2004 DC SR5 Texas edition 2016 CM 1794 edition
    1ST GEN Toytec 3/1 lift kenda 33s on 17x9 RockTrix RT107 BruteForceFab front bumper ----------------------------------- 3RD GEN rough country 6" Toyo 35's on 22x10 Fuel Assault TRDPro Grille
    85 or 91
  7. Aug 22, 2017 at 5:21 AM
    Toyota calls for 87 octane, so that is what is used. At my elevation, that is mid-grade.
    Wvmoonshiner and PermaFrostTRD like this.
  8. Aug 22, 2017 at 5:26 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
  9. Aug 22, 2017 at 5:26 AM
    I'm lucky enough to be able to get pure 87 dino with no ethanol @ $2.49 a gallon locally now. I have the non flex 5.7L.
  10. Aug 22, 2017 at 5:27 AM
    Patriot
    Patriot Member
    Same here, but I don't buy it. 2.12 for 87 oct. If I could notice the difference in performance I would be the Dino, I have and did not notice any difference. I do use it in my generator, and yard equipment.
  11. Aug 22, 2017 at 5:31 AM
    10% Ethanol 87 goes for around $2.19 give or take. I don't mind paying the extra cost to keep from using that water absorbing corn juice when I can.
    Wynnded likes this.
  12. Aug 22, 2017 at 6:31 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    On the factory tune I tested both 87 and 91 octane. I personally notice no change in performance or fuel efficiency. I also tracked ignition timing and i saw notiming advance for running the higher octane fuel.
    Now that I'm running a tune im using 91 octane.
    Black Wolf likes this.
  13. Aug 22, 2017 at 8:14 AM
    Miront
    Miront New Member
    Jordan
    Danville, CA
    2013 Silver Tundra Platinum
    Flowmaster Exhaust, XD Wheels
    I envy your fuel prices. I think I am paying $3.19/gal here in NorCal for 87.
    SuperSilverTundra likes this.
  14. Aug 22, 2017 at 8:14 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Share location?
  15. Aug 22, 2017 at 8:44 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    89 octane. The station I go to has 89 with no ethanol at $2.75 a gallon.
  16. Aug 22, 2017 at 8:44 AM
    Jagamov
    Jagamov New Member
    Greg
    2017 White Tundra Platinum
    87 here. No benefit to running any higher.
    Buy mine at Costco most of the time.
  17. Aug 22, 2017 at 8:55 AM
    CaptObvious
    CaptObvious New Member
    Patrick
    2015 Black Tundra SR5 Crewmax TRD
    WaWa is where its at....I miss having them around in MS.
    SouthBoundSteve likes this.
  18. Aug 22, 2017 at 9:13 AM
    Any of the new Maverick Gas Stations here in Denver/Aurora area.......yeah...
    JH5370 and Wynnded[QUOTED] like this.
  19. Aug 22, 2017 at 9:15 AM
    TheBeast The Beach
    costco 91
  20. Aug 22, 2017 at 9:18 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Always 87, always from Shell.
    Ike74, Y0TA PR0 and Black Wolf like this.
  21. Aug 22, 2017 at 9:36 AM
    Patriot
    Patriot Member
    Wally World -2.14 a gal for the 87 oct part corn on the cobb juice cheap stuff, that I buy.:rofl:
    Black Wolf and SouthBoundSteve like this.
  22. Aug 22, 2017 at 12:48 PM
    906UP
    906UP New Member
    Usually fill at a Shell, BP or Sunoco. We avoid Holiday....mpg drops by 2-3 points. No Wal-Mart's around us UP here, when we lived in down state my wife would fill her Envoy at Wal-Mart and it would always make the CEL come on for an O2 sensor.
    Always run 87 in the cars/trucks. 91 non-ethanol is what we put in the quads & sleds.
  23. Aug 22, 2017 at 12:49 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    87 all the time.
    Paid $2.35 a gallon yesterday at Costco who only sells 91 or 87.
  24. Aug 22, 2017 at 2:52 PM
    Berettafan
    Berettafan New Member
    2017 CM
    Royal farms by me has 89 ethanol free and I buy that often. When not using that I'll put shell or Exxon 87 or 89 in. Def better mileage with non corn on trips.
  25. Aug 22, 2017 at 2:52 PM
    Berettafan
    2017 CM
    And fuck the corn lobby, EPA and ethanol fuel.
  26. Aug 22, 2017 at 3:22 PM
    PermaFrostTRD
    Northern NY
    Manual says 87 so that's what I run.
  27. Aug 22, 2017 at 3:25 PM
    PermaFrostTRD
    Northern NY
    Just noticed your black rifle coffee tag line. Any affiliation with it, or just a fan?
    KEG89 and ColoradoTJ[QUOTED] like this.
  28. Aug 22, 2017 at 3:26 PM
    Just a Veteran supporter and enjoy damn good coffee. :D
  29. Aug 22, 2017 at 3:27 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Looks like everyone uses 87 ,
  30. Aug 22, 2017 at 3:27 PM
    PermaFrostTRD
    Northern NY
    Hooah! And thank you. :cheers:
