What fuse can I tap into to have switched power for a dash cam 2019
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Oct 17, 2021.
  1. Oct 17, 2021 at 10:00 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am wanting to add my dash cam to my new to me 2019 SR5. What fuse can I tap into to have switched power and will a tap a fuse fit behind the panel.
    Is there an easier adapter or harness for the doing it in the rear view mirror ? My cam is just a power wire, a ground wire and another wire for parking mode but I am just wanting to use it when the truck is switched on.
    Thanks
  2. Oct 17, 2021 at 10:10 AM
    timsp8
    NY
  3. Oct 17, 2021 at 10:12 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I think that this is going to give you full time power (the Tundra mirror isn’t switched). But it’s still the route I would go.
  4. Oct 17, 2021 at 10:21 AM
    timsp8
    NY
    Maybe tap it off the 12v power outlet?
  5. Oct 17, 2021 at 10:28 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I tapped into wires going to the mirror for my camera & radar detector. I think light blue & purple (switched & not) the camera wants a second always on power source for accident recording while parked on my 2010 Crew max & 2013 Sequoia.
  6. Oct 17, 2021 at 10:33 AM
    AZBoatHauler
    So.Arizona
    This is what I did for power to my front cam.
  7. Oct 17, 2021 at 11:39 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I used this. Turns off after my truck powers down.
    Hands down the easiest way to do this.
    IowaGuy[OP] likes this.
