What fuel grade for 5.7?
Discussion in 'Performance and Tuning' started by Xcumminsguy, Oct 16, 2023.
  1. Oct 16, 2023 at 6:09 AM
    Xcumminsguy
    Xcumminsguy [OP] New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Picking up my lightly used ‘21 TRD Pro Crew Max next Sat and I’m just wondering what fuel grade Toyota recommends for the truck? Do you deviate from that recommendation? Thanks all.
  2. Oct 16, 2023 at 6:33 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Consensus on the forum is 87. You won't see any issues with it. Anything higher is overkill and just money dumping down the drain.
    ejes, IsaiahCanada, rockmup and 5 others like this.
  3. Oct 16, 2023 at 6:37 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Unless you are blown, no reason to go up past 87.
  4. Oct 16, 2023 at 6:39 AM
    Recently filled up with ethanol free regular (87 or 89 not sure). Truck is getting 19.3mpg average when I usually get more like 16.8mpg. Quite the difference!
  5. Oct 16, 2023 at 6:51 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    What was the price difference between the EF and regular 87?
  6. Oct 16, 2023 at 6:53 AM
  7. Oct 16, 2023 at 6:59 AM
    Ethanol free and 87 octane or better. I'll pay a little extra for no corn in the tank, even if the MPG savings don't cover the cost, for 2 reasons.
    1. Ethanol is hygroscopic, meaning it pulls water from the air. Not good for a vehicle, and especially bad if it sits for days at a time or makes frequent short trips.
    2. Ethanol has been shown to not "save the environment" as it had been pitched. It's a net negative on the "green" front, unless that green is lining slimy pockets. I'll pay more to give them less.
  8. Oct 16, 2023 at 7:00 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
  9. Oct 16, 2023 at 7:12 AM
    Yup. That ethanol comes from corn. Fields prepped, planted, maintained and harvested by diesel powered farm equipment. Then transported by a diesel big rig to process at a plant that’s likely fossil fuel powered to turn it into ethanol that is then transported by diesel to the gas station. Then you put it into your car and get worse gas mileage thus burning more fuel than if you didn’t use ethanol. But 10% of the US gas consumption is a big number. It has an impact on our need for foreign oil. That’s the real purpose, not emissions or being green or anything. Was also supposed to be a good use of surplus corn, except that farmers stopped farming food crop and started farming corn for ethanol. So you also get a drop in food crop that may make us more dependent on foreign sources of food or grain, like the wheat we import.
    Lovetrucks, Skaufma0, TWJLee and 3 others like this.
  10. Oct 16, 2023 at 7:14 AM
    The solution to foreign oil dependence is local oil production. Doesn't change my stance, and they did pitch it as being green.
    Rob's Inferno and PRNDS like this.
  11. Oct 16, 2023 at 7:16 AM
    Yes they did. Like electric cars. If you get into a gas car or an electric car and drive it 200 miles, the electric car is a greener solution. But how did your electric car get here? What’s it made of? Where did that electricity come from? It’s a shell game. Green is rarely green without a cost. Often negating any perceived advantages.
    majbjb, WFD473, Skaufma0 and 3 others like this.
  12. Oct 16, 2023 at 7:17 AM
    Yup.
  13. Oct 16, 2023 at 7:43 AM
    Xcumminsguy
    Good to know. Thanks guys, 87 it is! Going to save me a ton of $$ over the 4.50+ I’ve been paying for diesel.
    Jaypown likes this.
  14. Oct 16, 2023 at 8:03 AM
    SD Surfer
    Bruce
    So Cal
    That'd be worth springing for premium. :rolleyes:
    Gene_in_FL and Xcumminsguy[OP] like this.
  15. Oct 16, 2023 at 9:21 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Here in Pa. ethanol free last week was 4.94/gallon. About a buck per gallon more than unleaded. Don't waste the money go with 87 you'll be fine.
    Joe333x and Xcumminsguy[OP] like this.
  16. Oct 16, 2023 at 5:47 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    I put diesel in mine :bananadance:
    IsaiahCanada likes this.
  17. Oct 16, 2023 at 5:49 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The extra money for ethanol free really only makes sense if it's something thats sitting, like a snowblower, lawn mower, generator, weekend car. For a daily driver it's not going to make a difference, especially with something that burns fuel so quickly its going to be smoke before it has time to do any damage that ethanol causes.
    Gene_in_FL and WFD473 like this.
  18. Oct 16, 2023 at 5:50 PM
    Xcumminsguy
    @tightywhitey At 4.50+/gal here in NY it’s just one of the reasons I’g getting rid of my ‘04 Dodge CTD.
    Joe333x likes this.
  19. Oct 16, 2023 at 5:53 PM
    Joe333x
    Joe333x Member
    Boston
    The cost of diesel is whats really causing inflation. You raise the cost of diesel and the cost of everything goes up. The cost of gas doesnt have a huge impact on inflation but its what the majority of people buy so its what gets the most attention. The entire country would be better off if diesel was cheaper than gas.
    Lovetrucks likes this.
  20. Oct 17, 2023 at 4:33 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, I run ethanol free in all my small 2 cycle engines and Polaris ATV. The biggest problem with those little 2 cycles is the fuel lines. Even the ones that are rated for ethanol will get hard. I add a litle Sea Foam to the mix. Truck, boat, and lawn tractor are engineered to run on 10% ethanol and never had a problem.
  21. Oct 17, 2023 at 4:43 AM
    Kung
    KG, VA
    88.
    Because my truck runs well on it, and because it's like $0.30/gal cheaper. :D
  22. Oct 17, 2023 at 5:03 PM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    I mean, I’m pretty sure the absurd amount of money printing that has happened over the last three years is the main cause of inflation….
    GODZILLA, Gene_in_FL and WFD473 like this.
  23. Oct 17, 2023 at 5:50 PM
    Joe333x
    Joe333x Member
    Boston
    Yeah of course, Im just referring to when you see grocery store prices rise every time the price of diesel goes up. I used to be a distributor and every time diesel went up, so did our prices, the cost of fuel just gets passed onto the consumer, the company doesnt take a hit.
    WFD473 and Lovetrucks like this.
  24. Oct 17, 2023 at 6:03 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    So, are you taking the white one (with black fender flares) that got a little banged up???
  25. Oct 17, 2023 at 6:11 PM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    Ohhhh got it
  26. Oct 17, 2023 at 8:21 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I was Logistics Finance Manager for the largest tile company before retiring. Tile is expensive to ship. I tracked oil, diesel, and gasoline prices weekly. We had a table that our freight companies used to calculate a diesel surcharge. In turn we charged our customers a surcharge on their invoices. Sales requested that I track gasoline because the average consumer does not relate to diesel prices. We had some large customers that balked at the surcharge.
  27. Oct 17, 2023 at 10:20 PM
    Blue Thunder
    Washington
    I ran premium this summer as a test. I got about 0.5mpg better when towing, but didn’t see a difference in normal driving. When I went back to regular octane last month the truck felt like it lost some low end power. It felt sluggish off the line and didn’t hold 6th gear as long when climbing hills. So now I only run premium. At $8-10 more per fill up, it doesn’t pay for itself but I like the improved performance. Phuk it
    Metro14536 likes this.
  28. Oct 17, 2023 at 10:25 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Usually 87 runs ok but every now and again I'll get a tank that pings too much so I'll have to add premium to tame it down.
  29. Oct 18, 2023 at 2:00 AM
    Xcumminsguy
    Haven’t decided yet.
  30. Nov 4, 2023 at 10:18 AM
    MrAlbus
    MrAlbus New Member
    Rebuilding a 2016 co-part Double Cab. ADV Fenders
    In my experience, lowest recommended octane is fine for normal driving, but when towing I go up. I was towing a small/medium trailer up a pass and felt very down on power, found a post saying it could be motor retarding ignition to avoid detonation when pulling hard. Gassed up with high octane and problem went away. I haven’t noticed a benefit to high octane for normal driving though.
