What exactly are bump stops?
Discussion in '2.5 Gen Tundras (2014-2021)' started by yoneytan, Aug 6, 2018.
  1. Aug 6, 2018 at 8:44 AM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    Sorry for the silly question but can anyone tell me exactly what bump stops are and what they do?
  2. Aug 6, 2018 at 9:02 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Rubber or synthetic square or round shaped “puck” that prohibits suspension travel beyond its design limits.
    TXMiamiFan likes this.
  3. Aug 6, 2018 at 9:07 AM
    yoneytan
    Asi
    14 CM
    I have a 14 CM with 3/1 pro comp and sometimes when I hit certain bumps on the road I feel a weird shake at the steering, kid of like a loose shake if that makes any sense. Its not on big bumps just on hard bumps. Hard to explain but could bump stops be of any help?
  4. Aug 6, 2018 at 9:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No. Bump stops won’t help that. Your issue might be bump steer.
  5. Aug 6, 2018 at 10:16 AM
    Tierhog
    Tierhog SIG-AHOLIC
    Correct. Sometimes a steering stabilizer helps. Make sure steering geometry is acceptable (likely ok but not ideal, which is stock)and everything is tightened to spec.
  6. Aug 6, 2018 at 10:29 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Wheeler’s SuperBumps in action:
    Stock bumpstops feel like smacking rocks.
    Rica25, 16cmt, TheBeast and 1 other person like this.
  7. Aug 6, 2018 at 11:27 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I've been meaning to post up some videos of the super bumps as well...once I find my sd card lol
  8. Aug 6, 2018 at 11:51 AM
    Tierhog
    Tierhog SIG-AHOLIC
    First time I've ever heard of comfortable bump stops... I guess I've always seen them as a simple means to protect suspension components in the event I go over a bump too large or quick.
    15whtrd likes this.
  9. Aug 6, 2018 at 11:57 AM
    15whtrd
    15whtrd Mr. Blonde
    Next step would be hydraulic bump stops.
    Tierhog[QUOTED] likes this.
  10. Aug 6, 2018 at 12:08 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Had wife and I laughing at that one.. Hysterical.
    Goofy concept.. These super stops. I mean... Too much cushion, extended compression and suspension damage. Oversized stops, less travel. What are they hoping to accomplish here... Oh wait I know.
    Folks... In the name of all things holy, polyurethane stops last longer than rubber and come in all kinds of colors for the sake of fashion and color matching. Rubber holds its own and is relatively cheap, but comes in black.
    You want a more comfortable ride? Less aggressive tires, different shocks, and if your really picky, change out your springs.
    If it rides like a 20 foot Cadillac and drags it's ass because you have groceries in the back, don't blame Toyota .. Lol
    SuperStops... LMAO
  11. Aug 6, 2018 at 12:18 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I hear you. I do have super bumps. They do work rather well. I don’t think they limit travel much as they compress the same amount as the stock bump. It just slows it down so it’s not as harsh when it does bottom out. I’ve actually been thinking of taking them out as I recently upgraded to the pro suspension which has internal bump stops built into the shock.
    Also extending your bump stops is what some people have to do if they don’t lift their truck properly. Or at least they did it cheap. If they don’t extend their bump stops the shock will bottom out and destroy itself before the bump stops even hit.
    I have been thinking of adding super bumps to the rear of my truck as I can feel it bottomed out harsh at times. I think it just leads to less wear and tear on everything if it’s a progressive stop. Now hydraulic bump stops have their place in serious Offroad rides. I look at it like this. It balances out your set up. Yes you can go with more travel shocks but then you end up with the skyhigh Offroad rig. What this does is lets you set the ride height you’re looking for with your shocks and this is just an added safety feature so that you don’t totally bottom them out and break suspension parts as well as your back.
    @ColoradoTJ
    Sunnier and JoshuaA like this.
  12. Aug 6, 2018 at 12:26 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Ok. I can see it I guess. We used to rock crawl Jeep CJ,TJ,& JK and knew the minute we started lifting them and placing aftermarket suspension and Kevlar 37s etc., the comfort was gone and would never return. I understand the harsh “correction” can be undesirable. If folks are bottoming out, you need more spring, air bags for load..something.
    I guess I struggle with trying to get my head around the idea as a product. Oh well. If it works and people like em, so be it.
    15whtrd likes this.
  13. Aug 6, 2018 at 12:44 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    pieces of rubber
    Tierhog likes this.
  14. Nov 26, 2018 at 5:19 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    I have been looking into the super bumps from wheelers and I see that we can add it to the front but is there anything similar or the same for the rear? I don't need hydraulic bumps for what I do with the truck that's why but all I can find for the rear are $200+ hydraulic stops.
    I quoted your post because I see you were thinking of adding super bumps to your rear
  15. Nov 26, 2018 at 5:51 PM
    15whtrd
    15whtrd Mr. Blonde
    I think it’s the Tacoma ones. Your best bet would be to call them. But I know I read it around here and I think it is universal between th Taco and Tundra.
    Sunnier likes this.
  16. Nov 26, 2018 at 6:08 PM
    iamsmokey
    Oahu, HI
    Oh okay okay I see. Can you send over a link to those?
  17. Nov 26, 2018 at 6:27 PM
    15whtrd
    15whtrd Mr. Blonde
    I will look into it more after I cook dinner. I asked this question a while ago and I’m forgetting the exact answer. I’ll try to find it.
  18. Nov 26, 2018 at 6:29 PM
    iamsmokey
    Oahu, HI
    Thanks for all the help. I’ll try and do some research as well. I’ll wait on your reply my dude
    15whtrd[QUOTED] likes this.
  19. Nov 26, 2018 at 6:41 PM
    15whtrd
    15whtrd Mr. Blonde
    TheBeast and 14burrito like this.
  20. Nov 26, 2018 at 6:47 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Love em!
    15whtrd likes this.
  21. Nov 26, 2018 at 6:51 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Tacoma ones linked above work for the rear, pic below of that bump installed
    16cmt, Tacotundra and 15whtrd like this.
  22. Nov 26, 2018 at 7:00 PM
    TheBeast The Beach
    15whtrd and Tacotundra like this.
  23. Nov 26, 2018 at 7:07 PM
    TheBeast The Beach
    install them at the same time you are doing rear leaf pack
  24. Nov 26, 2018 at 7:08 PM
    TheBeast The Beach
  25. Nov 22, 2020 at 10:45 PM
    16cmt
    16cmt New Member
    Portland Oregon
    2016 Sr5 Crewmax
    i need these. do they cost a lot and will they screw right in without having to make new thread the hole?
  26. Nov 23, 2020 at 7:31 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Uses existing bolt threads, check Wheeler's site for current price
    16cmt[QUOTED] likes this.
  27. Nov 23, 2020 at 7:54 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Tierhog for normal daily driving bump stop upgrades don't make much sense. If you start going off road with any sort of speed, something like the superbumps helps ease the harsh jolts of bottoming out. Adding a stronger spring isn't the answer unless you want that harsher ride 24/7. Putting in a bump stop with flexibility solves the problem without altering the ride.
    If you're jumping a truck, thats where hydraulic stops would come into play (hopefully in conjunction with bypass shocks) but by then you're $5k+ into suspension for the front end alone and far from getting a use out of stock bump stops.
    (That might be my longest sentence ever)
    Sunnier, joonbug and JoshuaA like this.
  28. Nov 23, 2020 at 8:48 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  29. Nov 23, 2020 at 9:15 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If those were available for first gens when I needed them I would have went that route. My superbumps are a bit tall and engage a little early, thats what I get for mixing Taco parts with a First gen Tundra.
    joonbug[QUOTED] likes this.
  30. Nov 23, 2020 at 11:16 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Don't confuse this thread even more, you DO have bump stops :rolleyes::D
