What does offset / backspace mean when considering aftermarket wheels?
Discussion in 'Wheels & Tires' started by T-Rex266, May 13, 2021.
  1. May 13, 2021 at 6:59 PM
    T-Rex266 [OP] Fuck Cancer Staff Member
  2. May 13, 2021 at 8:00 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And wheel width makes zero difference in how much your tires poke out. A 10” wide wheel and an 8” wide wheel with the same offset and tire width, will poke out exactly the same. Only the tire width and offset determine the poke. I repeat... A wider wheel WILL NOT make your stance more aggressive nor will it make you rub more. Been reading a lot of misinformation about it lately. Only exception is if your wheels and tires look like this....
  3. May 13, 2021 at 8:13 PM
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    I’m not 100% sure but I’ll try to give you an example. When I changed the wheels on my truck, my previous wheels had a backspacing of -12. The new wheels had a backspacing of -60. In order for me to change them I needed a 2” spacer which put the backspace to about 10 which made the wheels stick out further towards another car or an “aggressive stance”. If I hadn’t used the 2” spacers, the new wheels would have been too close to all the equipment like the coilover or control arms.
    Edit: oh this post is about what it means lmao oops
    joonbug likes this.
  4. May 13, 2021 at 8:15 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Um.....I'm about 98% sure that it does make a difference since the offset is measured from the middle of the wheel. So a 12" wide wheel and a 10" wide wheel have a 1" difference in their starting point making it about 25mm offset difference.....right? Not trying to be argumentative, just thinking logically (or as close to it as I can). Its kinda hard to put into words without drawing it lol.
    Edit: this is assuming the tire is the same width on both wheels(let's say a 12.5" wide tire on both 10" and 12" wide wheels)
  5. May 13, 2021 at 8:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ok imagine your 10” and 12” wide wheels. We’ll start with a 0 offset to make the math easier. It will mount to your hub exactly in the center of the wheel. Now put a 13” wide tire on either wheel. The tire will be centered on both wheels and 6.5” of the tire will poke out from where the hub is. They’re exactly the same. Now if you add positive offset to either wheel, say +60 like our stock wheels, both wheels will be moved inward 60mm’s. Same with negative offset. It’ll move both wheels outward by the same amount.
  6. May 13, 2021 at 8:28 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Your wheels, from 12 to 10" still have the same center, 1" in and 1" out difference. The wheel got wider but the tire didn't so it's still in the same place it started.
    sr5shark, GodlessPro and joonbug like this.
  7. May 13, 2021 at 8:28 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Wrong. You are taking 1" from the outside and 1" from the inside, the centerline doesn't move sot the tire will be in the same place. The only way to change the tire poke is with a change to the offset.
    Joon knows three things and one of them is wheel offset.
  8. May 13, 2021 at 8:30 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :rofl: I don't wanna know what the other 2 things are.
  9. May 13, 2021 at 8:36 PM
    GodlessPro
    Matthew
    NorCal
    He'll gladly tell you about about them, but maybe not here.
  10. May 13, 2021 at 8:38 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    As for rim width and poke....all of the "will it" calculators are wrong then.
    According to most, wheel width DOES affect rim poke. Overall stance and poke of the tires stays the same but the rim pokes out more. wheelimage.gif
  11. May 13, 2021 at 8:42 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Yea I started rethinking it after I said about being the same tire. Lol. There's the 2% I left available haha
    joonbug and 831Tun like this.
  12. May 13, 2021 at 8:44 PM
    GodlessPro
    Matthew
    NorCal
    Yes the rim will poke out more but the question is about the tire. Unless the rim is wider than the tire, the rim poke doesn't mean much.
  13. May 13, 2021 at 10:27 PM
    Kanobi13
    Kanobi13 New Member
    So its safe to say side wall poke then?
    SAGE63 and BravoDeltaRomeo like this.
  14. May 14, 2021 at 6:48 AM
    GodlessPro
    Matthew
    NorCal
    Yes
    SAGE63, BravoDeltaRomeo and sr5shark like this.
  15. May 14, 2021 at 8:00 AM
    Kanobi13
    Kanobi13 New Member
    Nice good ole glory hole :rofl:
  16. May 19, 2021 at 7:51 PM
    Marine1
    Marine1 New Member
    Fair Lawn, NJ
    3rd Gen... 2014 Tundra SR5
    K&N filter, LED interior light kit, Rhino Liner, LED head&driving lights, Rough Country Tri fold Tonneau cover. LED Brake, Turn & Back Up Strip
    Ok so I need a negative offset that's fer sure..... Got a massive steal on a set of 33/12.5 R18s, mounted them, they are too close to the ball joint/control arm area and do touch the rock guard underneath at full turn. Going to get rims..... how much offset do I need? Only need about a half inch outwards to clear everythig!20210518_181805~2.jpg
  17. Jan 14, 2024 at 9:12 AM
    SRQRUSTY
    SRQRUSTY New Member
    Bone stock 2018 Tundra 4X4
    Soooo, will a +20 offset stick out further than a +18 offset???
  18. Jan 14, 2024 at 9:21 AM
    Tom
    Tom New Member
  19. Jan 14, 2024 at 9:30 AM
    SAGE63
    San Diego County
    the other way around the closer to 0 or negative the more poke there will be. Also +15 <> +25 is the sweet spot for our 2.5 gen tundras possibly the 2.0 also.
    TOYOTARIG and SRQRUSTY[QUOTED] like this.
