What do your tires measure after being installed?
Discussion in 'General Tundra Discussion' started by Jackstraw, Aug 7, 2021.
  1. Aug 7, 2021 at 3:00 AM
    Jackstraw
    Jackstraw [OP] New Member
    2020 DC TRD Off Road
    Hey all, hope everyone is doing good. My question is, “What do your tires measure on your truck?” About 3 months ago I went from 275/70/18 (33.23”) Cooper Discover AT3 XLTs to the 285/75/18s (34.84) in the same tire. Overall I’m pleased with the tires, but the new tires only measure 33 1/2”, not the 35” they’re advertised as. For about the past month this has really started to bother me. Don’t get me wrong - I’ve lied about something being an inch bigger than what it really is :spy:, but now that it’s happened to me and involves my tires I’m pissed.
    A couple of days ago I stopped by Discount Tires and the tech rolled out a Toyo AT2 for comparison. Sure enough the tire was noticeably larger, but the tech said once it was inflated and installed with the weight of the truck the difference wouldn’t be as noticeable. Fair enough, and I do understand that manufacturers of all things fudge their numbers a bit, but I’m still annoyed.
    Any thoughts?
  2. Aug 7, 2021 at 3:27 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Jack up your truck and measure a tire without any weight on it.
    WILLINH and Jackstraw[OP] like this.
  3. Aug 7, 2021 at 3:37 AM
    Jackstraw
    Hadn’t thought of that. I guess I can measure the spare under the truck, as well.
    ATV25[QUOTED] likes this.
  4. Aug 7, 2021 at 4:20 AM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    You just out smarted a smart ass !!! :rofl:
    Cruzer and Jackstraw[OP] like this.
  5. Aug 7, 2021 at 5:13 AM
    Tires are always listed with measurements before inflation and mounting with weight on them.
    Jackstraw[OP] and omgboost like this.
  6. Aug 7, 2021 at 5:50 AM
    Jackstraw
    So losing some size is normal then?
    Does it stand to reason that if I want the tires to measure 35” installed then I’d order 37s?
    Also, I can see why the front tires might lose a bit with the weight of the engine but the rear tires have significantly less weight.
  7. Aug 7, 2021 at 5:53 AM
    timsp8
    NY
    Mine are the same. About 1” - 1 1/2” less than the advertised size when measured on the truck.
    Jackstraw[OP] likes this.
  8. Aug 7, 2021 at 6:03 AM
    Jackstraw
    That’s good to know. I’m glad I asked because I needed some closure. Like I said, I like the tires and they look good on the truck but it’s been sticking in my craw for a bit that there’s an 1 1/2” difference. My coworker has an F250 diesel with 35 x 12.5 x 20s and his look like a true 35
    Oey12, ATV25 and timsp8[QUOTED] like this.
  9. Aug 7, 2021 at 6:05 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    same with mine. i have 295/60/20 ridge grapplers. they should be 34", but at 32 psi, they measured 33". now, i keep them at 40 psi and they measure 33.5".
    Jackstraw[QUOTED][OP] likes this.
  10. Aug 7, 2021 at 6:16 AM
    Yes that is normal. Most sites will list the unmounted measurements.
  11. Aug 7, 2021 at 8:02 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Too small!!
  12. Aug 8, 2021 at 11:43 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    It is simple, when the tires are mounted and inflated, the side walls expand out which pulls the tread side in. This causes the overall diameter to be reduced.
    Jackstraw[OP] and ATV25 like this.
