What do you think about running your truck on propane? (pics on pg 2)
Discussion in 'General Tundra Discussion' started by DawgGam, Sep 13, 2015.
  1. Sep 13, 2015 at 2:01 PM
    DawgGam
    DawgGam [OP] New Member
    Kevin
    Hamiton Ont
    2011 Black Tundra Dbl SR5TRD
    (included in purchase) LineX nerf bars Extang Solid Fold tonneau Weather Tech mats Tow Mirrors (future improvements) Autogas (propane) tint ventshades (Oct 10) back up camera Leer work cap (thinking about keeping the tonneau cover) bed-slide rear 'helper bags'
    I've been running my old truck (93 Silverado 2x4 5.0) on propane for about two years and noticed no ill effects to engine parts or sensors. My oil changes were further apart (about 700 miles further) and the oil was cleaner (using 5 30 regular oil)
    Granted it is better to tow and haul stuff using gas and the fuel economy on propane is lessened (mine was 13% more propane to go the same distance as gas using the antiquated tbi). But ya can't beat the prices 1.58 a gal for propane compared to 4.50 a gal for gas.
    I will be running propane through this truck also, my propane installer said the Toyota 5.7 takes to propane as well if not better than my old Chevy 5.0.
    All that being said... has anyone any thoughts about this?
    GNTundra likes this.
  2. Sep 13, 2015 at 3:49 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Interested in responses
  3. Sep 13, 2015 at 4:06 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Know about propane only conversion on the smaller Toyota pickups and tacomas in the rock crawling sport but have not heard of this on full size trucks. Interested in responses as well and your build.
  4. Sep 13, 2015 at 4:23 PM
    Mike Tread lightly.
    south carolina
    Propane has been done for years like 30 plus to years in gasoline engines not to add to it but turbines engines too.
    Propane is a cleaner burning fuel than ron fuel (gasoline). The only down side is the btu are less and propane is used abit more but thats a offset.
    As for propane running on the 5.7 it will run just fine. Dont expect big hp gains its not going to happen.
    Oil changes(dino oil) and injectors life increases by 2 to 4 times longer do to the cleaner burning fuel. Look at the forklifts for example.
    The only thing I recommended and I strongly about this only use AIRCRAFT propane tanks or hot air ballon ones ONLY. Yes they are big but if you get into a accident and the rear gets hit the tank is deisgned to keep propane under pressure. I know all about propane and 3 degree cold burns or worst exploding tanks. I just to haul it and know the dangers of it but it is safe if you know what your doing.
  5. Sep 13, 2015 at 4:25 PM
    DawgGam
    Kevin
    Hamiton Ont
    I will be getting the propane installed by a reputable company that will provide the proper certification as is required by the Ontario Ministry of Transportation. This will be happening by the middle of *October.
    This will be a "dual fuel" conversion which means I will have the means to run either gas or propane. I hope I can have the same switch enabling me to choose one or the other as I do in my current truck, but that remains to be seen.
    I am also very interested in comments.
    (edited; incorrect month, the conversion will happen by the middle of October not march)
    Backslider and corc305 like this.
  6. Sep 13, 2015 at 4:31 PM
    Mike Tread lightly.
    south carolina
    As for your duel fuel system.
    They work very good. Rare you have problems with them.
    Side note since you are up north make sure the fittings not the tank side but vehicle side they are covered so salt doesnt eat into it... fyi.
  7. Sep 13, 2015 at 4:54 PM
    DawgGam
    Kevin
    Hamiton Ont
    As I stated, the install was done professionally and I have had zero problems throughout last winter. ;)
    I have had no problems at all with the dual fuel system, in fact if I had any control over it I would make it mandatory for all vehicles to use propane rather than gasoline as it puts far less toxins into the atmosphere... but then propane would not be nearly as cheap at the pump as it is.
    I noticed that they used copper as the fuel line and the fittings are similar to those found in compressed air systems.
    edit: If you choose to install a system yourself DO NOT use bbq tanks, invest a few bucks and get the proper tanks for this purpose... that being said.... I strongly recommend getting the system installed professionally.
  8. Sep 13, 2015 at 6:31 PM
    csuviper
    Broomfield, CO
    What is the cost of this conversion?
  9. Sep 13, 2015 at 6:53 PM
    Slapps truck is running propane...but he so manages at a propane company..."and propane accessories." ;)
    Backslider and PapaGrizz like this.
  10. Sep 13, 2015 at 7:08 PM
    csuviper
    Broomfield, CO
    Oh really, didn't know that
  11. Sep 13, 2015 at 7:19 PM
    Yep.
  12. Sep 14, 2015 at 3:12 PM
    DawgGam
    Kevin
    Hamiton Ont
    The costs will differ from region to region I am sure... the cost to put the system in my Silverado was 3250 (tbi).... the cost to install a new system in the Tundra is going to be about 5600 (sfi). Lucky it isn't DI because that would tack on another 2500.
    The Tundra's propane system will break even in two years, but I put on a lot of miles.
    I am surprised that there are so few that have this in their truck... the "at the pump" cost is typically more than 50% savings and that is factoring in the cost of install... after the "payback" period it's closer to 65% savings at the pump. This may vary also, these are my numbers so far.
    But the real benefit is - oh oh here comes the 'tree huggin' side of me - the environment. I feel just fine driving my gas guzzlin' beast knowing I am pumping less than half the toxins running on propane than my gas guzzlin' beast brothers and sisters running theirs on gas.
  13. Oct 1, 2015 at 5:19 PM
    DawgGam
    Kevin
    Hamiton Ont
    To anyone that cares... I will have my system installed in three to four weeks... I will be certain to take a bunch of pics.
    jtwags likes this.
  14. Oct 2, 2015 at 6:18 AM
    csuviper
    Broomfield, CO
    Yes, very interested. Pics would be great.
  15. Oct 2, 2015 at 6:26 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Does anyone have the link to a reputable company that does this conversion?
  16. Oct 2, 2015 at 7:17 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
  17. Oct 2, 2015 at 2:27 PM
    DawgGam
    Kevin
    Hamiton Ont
    Both links are very good indeed... unless I am mistaken, CNG is as good for the environment and engine as LPG, and the install costs are virtually the same. I chose LPG primarily because of greater access to fill stations across the regions that I travel.
    (rant start) I find it ludicrous that the US gov would put more restrictions on LPG. I fail to understand why it is so difficult to do something that will serve 3 main purposes, help the small business that wants to install the system, help the end users save money on fuel costs... and.... the big one in my opinion... do something positive about the environment without restricting vehicle use. (rant over) :)
    I will definitely get 'before' and 'after' pics... and I will try to get some 'during' pics, but no promises.
  18. Oct 9, 2015 at 4:46 PM
    DawgGam
    Kevin
    Hamiton Ont
    update ... I have an appointment with the installers and will have the propane system in my truck by Oct 29th.
    T-Rex266 likes this.
  19. Oct 9, 2015 at 8:32 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    2014 double cab TRD off road
  20. Oct 10, 2015 at 9:42 PM
    DawgGam
    Kevin
    Hamiton Ont
    waitaminit.... o_O ...... for real?!?
    ..... well then .......
    :yay: Bring on dem bitches :yay:
  21. Oct 14, 2015 at 9:01 AM
    DawgGam
    Kevin
    Hamiton Ont
    :tumbleweed:
    :anonymous: this thread is f***ing boring :bored:... yea, like so what, you pay 50% or less per gal, big whoop... most of us are looking for mods that are useful and look cool, you know like big ass lift kits and well designed tires that help us climb a wall and do stuff like :mudding: or light bars that are as bright as a collapsed sun... wtf noob... does having propane do anything cool?
    (me) ...er... maybe?!?... this system can travel a little over 600 miles (1000 k) on a combined single fill .... um... right... not so cool... ok point taken :rolleyes:
    Backslider likes this.
  22. Oct 14, 2015 at 9:17 AM
    csuviper
    Broomfield, CO
    Then spice it up a bit with some install pics and information.
    Interest in the ROI in miles if gas price stays around where it is currently.
  23. Oct 14, 2015 at 9:17 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Patiently awaiting pics... :popcorn:
  24. Oct 14, 2015 at 5:59 PM
    DawgGam
    Kevin
    Hamiton Ont
    "Before" and "After" pics will be posted after the system is installed, which has been bumped up to next week... meaning I will be driving on propane by the 23rd
    I have been told by the installer that because this engine is SFI I will notice a slight bump in HP/TQ. Not that I doubt their word but I will look into possibly getting it dyno'd on gas and again on propane so I can say definitively one way or the other.
  25. Oct 14, 2015 at 7:13 PM
    DawgGam
    Kevin
    Hamiton Ont
    Damn... forgot about the ROI question. I am using US gallons for expediency sake.
    hhmmm.... based on the 27.9 gal tank of propane I am getting then use my avg of 15mpg and factor in a 5% loss in economy. This equates to 390 miles per tank of propane.
    Now the avg price of gasoline is $4.03/gal and the avg price of propane is $1.72/gal. So we subtract $1.72 from $4.03 and your net savings is $2.31/gal.
    The gas tank in my Tundra is 26.4 gal, so we multiply $4.03 and we get $106.39
    Multiply $1.72 by 27.9 gal propane tank and we get $47.98
    Subtract the cost of gas by the cost of propane and you get a savings of $58.41 per tank of propane.
    Now we can divide that $58.41 into the cost of install which is about $5750 giving a sum of 98.44 tanks of propane.
    And finally we take the 98.44 tanks and multiply by the 390 miles/tank of propane and you get 38,391.6 miles.
    So unless I did this wrong (which is very possible) the ROI should break even at the 38,391.6 miles.
    I would appreciate someone re doing this calculation if they so desire.
  26. Oct 22, 2015 at 7:19 AM
    DawgGam
    Kevin
    Hamiton Ont
    Just a quick update... took the truck in for installation on Monday (Oct 19th) with a pick up date of Monday (Oct 26th).
    They gave me an 05 Cavalier loaner for the interim, it runs very well indeed.
    I realized I forgot to get "before" pics when I got home... but we all know what the truck bed and engine bay looks like... I will take "after" pics when I pick it up.
  27. Oct 22, 2015 at 9:39 AM
    Jack Burton
    Little China
    2013 DC 5.7L TRD/OR
    Standing by...
  28. Oct 22, 2015 at 6:01 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    I filled up with gasoline today for $1.69 a gallon...
  29. Oct 22, 2015 at 6:02 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    1.69, where are you from
  30. Oct 22, 2015 at 6:03 PM
    mdavis
    Michael
    Rock Hill, SC
    Rock Hill, SC
