What do you guys think about this???
Discussion in '2.5 Gen Tundras (2014-2021)' started by Machodiver, Aug 19, 2015.
  1. Aug 19, 2015 at 12:19 AM
    Machodiver
    Machodiver [OP] New Member
    James
    2015 Black SR5 Tundra CrewMax
  2. Aug 19, 2015 at 3:37 AM
    TODDK
    TODDK New Member
    Todd
    Hibbs, PA
    2014 Tundra TRD
    6" lift sitting on 20x10x-24 wrapped with 35 MTs
    Typical spacer lift. I have put two of these on for friends, everything was good quality and bolted up correctly.
    Make sure you have the truck lined up afterwards
  3. Aug 19, 2015 at 4:55 AM
    DITTO: Pretty decent looking spacer lift/level kit. Appears to have the Diff drop parts too.
  4. Aug 19, 2015 at 6:19 AM
    Personally, I would save for a full suspension lift. That's just me though.
  5. Aug 19, 2015 at 6:52 AM
    I agree, but then I would have to get married and have my wife save up mod money for me. :cookiemonster:
  6. Aug 19, 2015 at 9:08 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Have you seen this bumper sticker? So true, haha.
    no_cash_im_married_bumper_sticker-rb5c751201a7e472a8220e0a60022f174_v9wht_8byvr_1024.jpg
  7. Aug 19, 2015 at 9:17 AM
    chphilo
    Western PA
    As far as spacer lift is concerned, this one is as good as it goes, cheap and does what it's designed to do.
    I personally would stay away from spacers. I've seen enough posts reporting broken struts just going over a pot hole.
    Case in point: truxx 3/1, going over a pot hole. Go with Bilstein 5100 (or Pro Comp Pro Runner). They aren't that much more expensive and much more reliable.
    Black Wolf likes this.
  8. Aug 19, 2015 at 9:23 AM
    That's my plan. My truck already had the spacers. Spacer are OK to a degree. A lot of trucks run with them without any issues. I go off road a lot so dumping the spacer lift would be very prudent for me.
  9. Aug 19, 2015 at 8:27 PM
    Machodiver
    James
    Thanks @chphilo I appreciate the advice. My truck is 2wd so I'm not sure about a full lift???
  10. Aug 19, 2015 at 8:29 PM
    Machodiver
    James
    Does Bilstein make a level kit for 2wd?
  11. Aug 19, 2015 at 9:01 PM
    Bilstein only makes the shocks/coil-overs. Bilstein makes height adjustable shocks, if that it what you are talking about. You have a lot of options with your 2WD version. Do you want to only level? Maybe lower? Some folks with 2WD turn their Tundra into a pre-runner which can do a lot of things a stock 4X4 can't do mainly because of major suspension upgrades and engine performance upgrades, Mickey
    Thompson Baja ATZ tires, for example. Let us know what you want to do. There are plenty of guys here from all experiences to help you. Try contacting Bilstein with your concerns too. :http://www.bilsteinus.com/
    It sounds like you want to get a major lift. If that's the case , bite the bullet and go pre-runner. Bad ass for sure. Will cost a few$$$.
  12. Aug 19, 2015 at 9:13 PM
    chphilo
    Western PA
    Bilsteins will work fine for 4x2 and 4x4. By the way, a popular option for a 4x2 is the spindle lift. From what I understand, it does not alter the suspension geometry at all and later on if you decide to go higher, you could just stack a coil-over set along with spindles.
    Unfortunately, for 4x4 guys, we don't have such an economical and sound option for lifting.
  13. Aug 19, 2015 at 9:16 PM
    What do you think about @Machodiver going the pre-runner route? Sounds like what he may be looking for.[​IMG]
    Extreme full on. heh heh version here
    Machodiver[OP] likes this.
  14. Aug 19, 2015 at 9:22 PM
    chphilo
    Western PA
    The pre-runner route will be awesome . . . but his wallet will become very much lighter, haha.
  15. Aug 19, 2015 at 9:38 PM
    Another 2WD pre-runner:
  16. Aug 19, 2015 at 9:38 PM
    Machodiver
    James
    Though I really like the pre runner, I agree with @chphilo My wallet is light as is. I just want to style it a bit.
  17. Aug 19, 2015 at 9:43 PM
    Machodiver
    James
    Any links to the Bilstein kit???
  18. Aug 19, 2015 at 9:44 PM
    Just go with that Supreme Suspension lift. Your truck will look pretty cool. Price is right. Are you going to DIY? If you do , take a lot of pics to make it easier for our fellow 2WD guys here in case they want to do the same.
  19. Aug 19, 2015 at 9:45 PM
  20. Aug 19, 2015 at 9:46 PM
    Machodiver
    James
    Probably me and a buddy. I definitely will once I get it.
  21. Aug 19, 2015 at 9:47 PM
    Sorry, got carried away. heh heh
  22. Aug 19, 2015 at 9:48 PM
    Drink the beer after you guys are finished. :cheers:
  23. Aug 20, 2015 at 12:56 AM
    Machodiver
    James
    Possibly while we are working!!! Lol
  24. Aug 20, 2015 at 4:51 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Machodiver, I have 2wd also and I bought my 2.5 leveling kit from Supreme Suspensions and have no complaints. There are well priced and solid billett aluminum. You don't need the differential drop with 2wd. The kit leveled my truck up, but still left a slight rake which is good. I don't need the rear spacer in the back. Hope this helps
  25. Aug 20, 2015 at 8:29 PM
    Machodiver
    James
    It really does help. I am currently researching the 3/1.5 kit. Know anything about it?
  26. Aug 21, 2015 at 1:52 PM
    rons23
    Ron
    Kill Devil Hills
    Hey Macho, also look at Toy Tec's 3-1 spacer lift, solid! As a forum member you get a discount. There one of Tundras.com vendors. With you not needing differential drop, that will save you about $30 + discount. Hope this helps
    Black Wolf and T-Rex266 like this.
  27. Aug 21, 2015 at 4:19 PM
    If I had no spacer lift and wanted to do the spacer lift, I would go with ToyTec. ToyTec specializes in Toyota only.
    T-Rex266 and rons23 like this.
  28. Aug 21, 2015 at 4:44 PM
    Call these guys:
  29. Aug 21, 2015 at 6:06 PM
    rons23
    Ron
    Kill Devil Hills
    Thanks Matluth for entering the link. I haven't figured out how to put a link in conversation with tap talk.:cool:
  30. Aug 21, 2015 at 7:53 PM
    I haven't used tap talk yet. Ron, you can all me Matt. Actually anyone here can.
    rons23[QUOTED] likes this.
