What do you guys think about the Truck/Bed tent?
Discussion in 'Outdoors' started by FlipMonkey21, Sep 12, 2019.
  1. Sep 12, 2019 at 2:23 PM
    FlipMonkey21
    FlipMonkey21 [OP] New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
  2. Sep 12, 2019 at 2:26 PM
    I'd pay extra to not buy from dick's sporting goods. Just my OP.
    Rugerla1, hitech, Bakershack and 17 others like this.
  3. Sep 12, 2019 at 2:28 PM
    FlipMonkey21
    Mark
    SoCal Glendale
    I know just showing the style here LOL
    Rica25 and GODZILLA[QUOTED] like this.
  4. Sep 12, 2019 at 2:31 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got that same tent minus the little awning. It’s pretty good, easy to set up, holds up really well in bad weather.
    Rica25 and FlipMonkey21[OP] like this.
  5. Sep 12, 2019 at 2:49 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    The Guide Gear one is pretty good. Tons of room and under $100 on Amazon.
  6. Sep 13, 2019 at 11:13 AM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    I have one like that too, but it was an Amazon one, can't remember the name. It does setup quickly and seems to hold up. My wife hates it because she has to climb up onto the tailgate to get in, so we usually use our ground tent when she comes along.
  7. Sep 13, 2019 at 5:07 PM
    Dank1296
    Dank1296 New Member
    JC
    2015 Grey Tundra SR5
    Nerf Bars
    Have the guide gear works well
  8. Sep 13, 2019 at 5:12 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  9. Sep 13, 2019 at 6:00 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  10. Sep 13, 2019 at 6:02 PM
    csuviper
    Broomfield, CO
  11. Sep 13, 2019 at 6:07 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I think you have to completely empty your truck bed before you can set it up. This seems like a lot of extra work.
    GODZILLA and joonbug like this.
  12. Sep 13, 2019 at 7:44 PM
    csuviper
    Broomfield, CO
    Yes you do. Not bad because everything you bring should be useful and pulled out to use or you shouldn’t have brought it.
  13. Sep 13, 2019 at 8:19 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I bring guns, fishing gear, ice chests, shovels, and lots of stuff I use and don’t want to unload it just to set up a tent
    GODZILLA likes this.
  14. Sep 13, 2019 at 8:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wonder how well those tents would work with a decked system
  15. Sep 13, 2019 at 9:20 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Nope. Nothing beats a stand alone tent.
    Plus you'd have to remove all your gear, wood, axes, fishing gear and anything else you are hauling.
    If your in Canada pick up an MEC tent. In the US, grab an REI. Both make fantastic tents for the price. We use both currently.
  16. Sep 13, 2019 at 9:32 PM
    15whtrd
    15whtrd Mr. Blonde
    I always liked the way those tents looked. But what I can’t stand is the straps rub the side of the bed. Add to that, most likely your truck is filthy before doing so. I can’t imagine the paint coming out unscathed.
    GODZILLA, Kerch71, JH5370 and 2 others like this.
  17. Sep 17, 2019 at 5:59 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I don’t have a picture of mine, but I measured and cut up some PVC pipe to make frame and then put a big tarp over it. I put the PVC into the 4 bed corner holes and connected everything using PVC joints and T-joints. I didn’t have to empty the bed to set it up, but I did have to empty it to sleep in it.
    I’m including a pic I found online of the concept. It’s not my truck, but it should give an idea of what I’m talking about. Mine wasn’t as tall, though. It worked great the few times I used it, and it was a cheap and easy DIY option. It also took about the same time, if not less, to set up and dismantle as my ground tents.
  18. Sep 17, 2019 at 6:02 PM
    equin
    Ed
    DFW, TX
    Forgot to add, I didn’t have to use straps on the fenderwells. I used a big tarp and rope tied the tarp’s corners to stakes on the ground without the tarp even touching the fenders or bedsides. It also rained on me one time and the tarp kept the rain out.
    kevine0001 and 15whtrd like this.
  19. Sep 17, 2019 at 6:15 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Can't beat the flexibility of PVC and tarps. Had a similar design that protected my bikes at my old apartment. Called it my redneck lean-to. :thumbsup:
    jewsNbrews and equin like this.
  20. Sep 17, 2019 at 6:33 PM
    Ditto^^^^^^I won't step one foot into a Dick's non sporting goods
  21. Sep 17, 2019 at 7:59 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    I like my Napier tent and the straps have padding to help prevent scratches. The straps to go between the tailgate sucks to strap it down and removing everything before setting up. Other than that, I like it. Get a truck airbedz and you’re set. Got my tent from Amazon
    HazMatt and equin like this.
  22. Sep 18, 2019 at 1:23 PM
    DECKEDUSA
    DECKEDUSA New Member Vendor
    We'd be interested to see as well.
  23. Sep 18, 2019 at 1:35 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Send a decked drawer my way and ill send pictures of it :p:p
    HazMatt, GODZILLA and Explorer like this.
  24. Sep 18, 2019 at 1:54 PM
    DECKEDUSA
    Just dm your CC information and we will get one coming your way as soon as tomorrow. ;)
  25. Sep 25, 2019 at 1:58 PM
    swamper
    swamper New Member
    Joe
    Southern nj
    2011 sr5 trd
    Not sure yet.
  26. Oct 8, 2019 at 1:30 PM
    HazMatt
    HazMatt Go go gadget thingamajigger
    2019 MGM Tundra TRD Sport
    Toytec Boss Coilover suspension, JBAOffroad UCAs, Black Rhino Fury Gunmetal 18x9.5, Nitto Ridge Grappler 295/70R18, Access Vanish bed cover, spray-in liner, running boards, wind deflectors, Borla exhaust, Bedrug liner, rear floor storage, LED front turn signal bulbs, LED interior lights, TOGUARD dash cam, Yaesu FTM-400XDR HAM radio, Victory 4x4 18” modular bed rack, Tepui Autana 3 RTT
    What size Airbedz did you go with? I’m 6 foot so my feet will stick out on to the tailgate and I’m trying to account for that lol.
  27. Oct 8, 2019 at 6:44 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    I have the 5.5’ bed. There’s still room in the tent to go with a bigger bed. The tailgate has to be dropped when you put the tent on.
    HazMatt likes this.
  28. Oct 8, 2019 at 6:48 PM
    HazMatt
    Okay, thanks for the info!
  29. Dec 3, 2019 at 1:36 PM
    fliberto38
    fliberto38 New Member
    Ft. Worth, Texas
    2019 Silver Tundra TSS Off-Road
    Toytec/Radflo coil overs, SPC UCAs, Diff drop, Toytec/Deaver AAL, Toytec Boss rear shocks
    Has anyone tried the ones from Rightline Gear? They look like they could be used without having to take everything out of the bed. Looks like it just sits over your bed rails and doesn't have a floor inside the bed.
  30. Dec 3, 2019 at 1:40 PM
    HazMatt
    I don't recall for sure, but one reason why I chose the Napier Sportz version was that it had a pass-through to the back window of the truck. I ended up getting a RTT for my truck, but that was one of the key differences that I don't believe the Rightline had. Not having a floor though like in the Rightline is nice if you have accessories tied to the track system or bed lighting etc that would be covered by the floor. Just my thoughts anyway.
    fliberto38[QUOTED] likes this.
