What do I buy for my foam cannon?
Discussion in 'Detailing' started by joem1cha3l, Jul 17, 2018.
  1. Jul 17, 2018 at 5:17 PM
    joem1cha3l
    joem1cha3l [OP] New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Ok fellas. I bought my pressure washer from lowes on sale and my foam cannon off of Amazon. Im just about ready to start trying this out....
    What soap do I buy for the best results? I dont know much about this stuff
  2. Jul 17, 2018 at 5:21 PM
    Chemical Guys and Adams Polishes are fewer. I’ve been using Adams, but tempted to buy CG to try.
    I also use Adams Car Shampoo prior to the foam soap.
    nk1794 and kodiak like this.
  3. Jul 17, 2018 at 5:24 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I've had great luck with the Chemical Guys soaps I've used. I bought one of their foam cannons and used the citrus wash and gloss in it with awesome results!
    nk1794 likes this.
  4. Jul 17, 2018 at 5:52 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    I used meguiars ultimate first with surprising amount of foam. Using Mr. Pink from chemical guys now. Works well. Researching a spotless DI cartridge for future washes.
    HecticEnergy likes this.
  5. Jul 17, 2018 at 11:25 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    Chemical guys extreme body wash .
    I also modded a second pressure washer spray gun to shorten up where the cannon attaches. Much easier to use 8F27F52D-AFB9-41CE-807F-5CA40D2DCC7C.jpg
    Toyotoholic, 1UPPER, Merlin and 3 others like this.
  6. Jul 18, 2018 at 12:12 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Chemical guys is good stuff. A little on the expensive side. Especially if you wash the truck as much as I do. I use a similar pressure washer and a foam cannon from Amazon. Wash my truck and wife's Highlander every Sunday. I've had good results with Mothers in the cannon. upload_2018-7-18_0-11-35.jpg
    MotoTundra likes this.
  7. Jul 18, 2018 at 4:22 AM
    War Machine
    War Machine SSEM # 5 3MW
    Another vote for CG Honeydew Snow foam and warm water. Listen to @SouthBoundSteve . He’s learned a lot from me.
    classiccat and HecticEnergy like this.
  8. Jul 18, 2018 at 4:44 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    What ratio do you all use for soap/water in the canister?
    SouthBoundSteve likes this.
  9. Jul 18, 2018 at 4:46 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I need to buy a foam cannon. Please let us know how you like it.
  10. Jul 18, 2018 at 4:53 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
  11. Jul 18, 2018 at 4:57 AM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    I plan to use Mr Pink from chemical guys. I think I saw 1-1 mix for the foam canon container.... seems excessive. Be sure and put water in and add soap second or you’ll get suds in your container...
    Correction: mix ratio suggested by chemical guys for Mr Pink is 16:1 water:soap for their Torq cannon. I'm sure nozzle and psi strongly influence the mix that works best.
  12. Jul 18, 2018 at 5:07 AM
    4Runner
    4Runner New Member
    Columbia, SC
    Another technique if you add soap first is to simply submerge the bottle in your rinse bucket. It will fill it up without suds. I prefer going to my sink as I use warm water to fill up the bottle...seems to dissolve the soap better.
    HecticEnergy[QUOTED] likes this.
  13. Jul 18, 2018 at 5:09 AM
    briarpatch
    briarpatch New Member
    Chemical Guys Honeydew, Mastersons Snow Foam or McKees Extreme Foam will give you excellent results. Meguiars Gold Class also foams well, but it dissipates quickly. Try and remember that it's not necessarily about having tons of 'shaving cream' consistency foam on your vehicle...think about why you're using soap in the first place. It needs to have good cleaning power, and sufficient lubricity to mitigate the damage to your paint while washing.
    I've settled on a 7:1 water to soap ratio....tried 10:1...too runny for me...5:1 too expensive. Is your power washer gas or electric?
  14. Jul 18, 2018 at 6:21 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Alright I'm buying a foam cannon today... Haha
    SouthBoundSteve and HecticEnergy like this.
  15. Jul 18, 2018 at 6:24 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Tundras.com makes another sale LOL
  16. Jul 18, 2018 at 6:28 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Yup...
  17. Jul 18, 2018 at 9:04 AM
    mgh-pa
    mgh-pa Perpetually a New Member.
    2016 Tundra DC SR5
    Darn you. Just bought a foam cannon after reading about them on here for the last few months.
  18. Jul 18, 2018 at 9:32 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    It's been on my list for a while too, finally pulled the trigger.. hopefully it's all it's cracked up to be..
  19. Jul 18, 2018 at 9:45 AM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    U have a link for that?
  20. Jul 18, 2018 at 10:25 AM
    LEKS
    Makaha
    I pieced it together, it’s an MTM hydro spray gun and I just bought the fittings that fit my foam cannon and pressure washer
  21. Jul 18, 2018 at 6:30 PM
    Antlers
    Antlers New Member
    Alaska
    2018 SR5 TRD Cement
    Now that's a tip I wasn't aware of.....thanks and War Eagle!
  22. Jul 18, 2018 at 6:32 PM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
  23. Jul 31, 2018 at 8:47 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Got her today. Went with a short nozzle too.
  24. Aug 19, 2018 at 11:16 AM
    Merlin
    Merlin New Member
    Sunny South Florida
    Yepper, the first thing I did was ditch the long stick.
    I purchased a short gun handle. Much easier to use!
    Having a little fun...foam soap dye...
    Pink
    Orange
    Yellow
    I've become a big fan of the Poorboy's Super Slick & Foam Soap Pre-Soak Shampoo for the foam cannon
    cjmay13 likes this.
  25. Aug 19, 2018 at 12:51 PM
    Punisher17
    Punisher17 New Member
    Where do you get the pink soap from?
    What I've really been wanting is a rainbow color but don't know how to get that with the foam cannon and can't find any rainbow color soap online..
  26. Aug 19, 2018 at 12:58 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
  27. Aug 19, 2018 at 1:38 PM
    Merlin
    Merlin New Member
    Sunny South Florida
    It is actually the same Poorboy's Super Slick & Foam Soap Pre-Soak Shampoo.
    Notice the position of the car/camera tripod etc. for the different videos.
    The color comes from an industrial car wash shampoo dye added in the bottle.
    If it were me I would not try it. It took weeks to get that colored soap out of all the cracks.
  28. Nov 11, 2018 at 6:52 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    Is there a particular foam cannon I should get? There are so many options on Amazon at varying prices.
  29. Nov 11, 2018 at 7:15 PM
    War Machine
    I use this one. I think a few other guys here do also. Don’t drop money on an expensive one. There’s little if any difference.
    MATCC Adjustable Foam Cannon 1 Liter Bottle Snow Foam Lance With 1/4" Quick Connector Foam Blaster for Pressure Washer Gun https://www.amazon.com/dp/B01CE78VO8/ref=cm_sw_r_cp_tai_Rap6BbJKQ71BY
    Pudge and Degausser[QUOTED] like this.
  30. Nov 11, 2018 at 7:20 PM
    Degausser
    Kevin
    GA
    2024 LR SR5
    Perfect. Also, how nice of a pressure washer do I need to get if my truck is the only thing I really plan on using it for?
