What causes the brakes to feel firmer at the pedal?
Discussion in '1st Gen Tundras (2000-2006)' started by JQ3, Nov 16, 2019.
  1. Nov 16, 2019 at 8:40 AM
    JQ3
    JQ3 [OP] 2005 XSP rwd
    We all know that the 1st gen Tundra/Sequoia brakes leave a lot to be desired. I own a ‘05 Tundra and a ‘05 Sequoia, last week I had new brakes put on the Tundra because they were squeaking really bad after sitting for a few hours, but would stop after a few minutes of use. The mechanic told me that the squeaking was coming from the front brakes, there was still about 20% pad left. I had him replace the front brakes and that did stop the squeaking. The ‘05 Sequoia, which we rarely drive, has a much firmer brake feel than my Tundra with new brakes. The only difference between the two brake-wise is that I added slotted rotors to the Sequoia about 3 years ago. What would cause the brakes to have a more firmer feel at the brake pedal?
    Thanks!
  2. Nov 16, 2019 at 10:40 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Rear shoe adjustment makes a huge difference.
    That and bleeding the brakes
    Aerindel likes this.
  3. Nov 16, 2019 at 11:28 AM
    Professional Hand Model
    Hand Protectors
    Stay tuned for the ‘Shim Wow! Sham Pow! Mod’ feed back which may be the magic fix to 1st Gen ‘soft pedal’.
    Did your new pads have built in shims? If so, what type?
    My braking greatly improve on the 2002 when I discover the LSBP valve was bottomed out from factory. I adjust the nuts up and much better braking as the rear shoes are involved a little bit now. I also turned by star adjust a couple clicks at a time on the rears through the slot to adjust the shoes closer to the drum. The parking brake is ‘supposed’ to do this but it doesn’t work as it should. I think due to the drums being original and the slot has formed inside my theory in practice is manually turning the star a 2 clicks at a time until you feel the quicker response. Do not over adjust!
    Overall, the truck has always had ‘soft pedal’ compared to other vehicles. The truck has always stopped fairly well its the pedal has to travel farther. The above recco’d adjustments have helped optimize things, but its not a race car.
    theblurry1, bmf4069 and FrenchToasty like this.
  4. Nov 16, 2019 at 1:16 PM
    JQ3
    I don’t know. I had the brakes done by a trusted mechanic. I’ll give the LSBP valve an adjustment a try when the weather is better...thanks!
  5. Nov 16, 2019 at 1:16 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    The Sequoia is 4 wheel disc that's the main reason it will a firmer pedal and better braking than a Tundra with rear drum brakes.
  6. Nov 16, 2019 at 1:20 PM
    Hand Protectors
    I recently saw an 03-04’ AC Tundra with a rear disc mod performed on it. It can be done. Only one I’ve ever seen and it wasn’t here on the internet.
  7. Nov 16, 2019 at 1:34 PM
    JQ3
    Oooooh OK! Thanks that answers that question! Makes me wonder now, why Toyota didn’t do the same on the Tundra? Well, the brakes are my only complaint with my Tundra...
  8. Nov 16, 2019 at 1:48 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    I looked into doing the disc brake mod a while back and it was close to 2k using Sequoia parts. Decided my brakes don't bother me that bad.
  9. Nov 16, 2019 at 1:53 PM
    Aerindel
    Aerindel New Member
    Montana
    Its all in the rear drum brake adjustment....
    Well, its all in the parking brake adjustment which in turn is responsible for adjusting the rear drum brakes.
  10. Nov 16, 2019 at 3:23 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Had brake work done yesterday along with drain/fill of Fnt/Rear Differential, Transfer Case and Transmission fluids. After back and forth discussing with Master Tech, chose not to add the shims. Rear shoes and wheel cylinder still good and had him simply clean things up. Once recouped from knee surgery, will want to replace rear shoes myself next spring....thickness were only 5-6 mm after 75K miles since last they were worked on.
  11. Nov 19, 2019 at 6:39 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, I didnt get to it this weekend. Even when I do, my results may not be adequate since my seals are leaking again and my drums are probably full of diff juice again. Maybe this long break over turkey day will give me time to do both.
  12. Nov 19, 2019 at 7:38 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    One component that can have a big effect on how firm the brake pedal feels is the power brake booster.
    You can test this by applying the brakes before you start the engine; the pedal will be high and hard if the system is properly adjusted and bled. When the engine is started, vacuum is generated for the booster, and the pedal will sink deeper even with your foot firmly on the pedal. One might mistake this for "softer pedal", but it's actually because the booster is generating far more actuation force than your foot alone.
    I don't know the specific cause for the difference you're observing, but the boosters of the two vehicles may have different capacity. I'm sure OEMs try to engineer vehicle power brake systems to the same standards and for same feel, but maybe the Tundra booster is slightly oversized compared to the Sequoias. Just saying. Probably a theory to be tested by more research on the booster specs, weights of the two vehicles, etc. :notsure:
    TX-TRD1stGEN likes this.
  13. Nov 19, 2019 at 10:45 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    IIRC, the tundras is smaller. You have to put the sequoia one in if you do rear disks since the tundra one doesn't have enough pressure. I think.
