what causes a bypass shock to "twist"?
Discussion in 'Suspension' started by Tundra9831, Jun 26, 2020.
  1. Jun 26, 2020 at 4:58 PM
    Tundra9831
    Tundra9831 [OP] New Member
    I've read the threads about ADS rear bypasses occasionally twisting or coming loose and causing some clearance issues on the passenger side. What exactly causes this issue? Is it only the top nut coming loose, then the shock rotates slightly throughout the suspension travel or is it something else as well? Do King bypasses have the same issue? Do other rear shocks with remote reservoirs come loose too, but don't cause an issue because there is more space for clearance with suspension and brake components?
  2. Jun 27, 2020 at 9:56 AM
    Tundra9831
    informal poll...please chime in if you have either ADS or King bypasses and let me know if you've had them come loose or not...thanks!
