What can my tundra haul!?
Discussion in 'Towing & Hauling' started by Ubc2361, Jun 1, 2016.
  1. Jun 1, 2016 at 5:32 PM
    Ubc2361
    Ubc2361 [OP] New Member
    Tony
    Los Angeles
    Tundra crewmax 5.7 4x4
    Ok guys went to pismo beach for memorial day and i was almost the only tundra there. But i did pretty well i went in the dunes and didnt get stuck. But what i really want to know is what kind of toy hauler can i buy. I dont want to trade my tundra in but i want a trailer thats not laughfable. Also i want a polaris 1000 in the toyhauler. Is this realistic or am i dreaming.
    ColoradoTJ likes this.
  2. Jun 1, 2016 at 5:56 PM
    15whtrd
    15whtrd Mr. Blonde
    10,000 lbs give or take.look for toy hauler that you like, check the weight, Find out how much all your gear plus water will weigh and go from there. Weight distribution hitch and sway control will definitely help keep it all tame.
    zcarpenter92 likes this.
  3. Jun 1, 2016 at 6:00 PM
    Ass. It can haul ass.
  4. Jun 1, 2016 at 6:00 PM
    Ubc2361
    Tony
    Los Angeles
    Yeah the 10,000 but when they start talking gvw, dry , etc i get lost. Plus trailer weight number of axels. Very confused i juz want like a cheat sheet.
  5. Jun 1, 2016 at 6:08 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    There is no cheat sheet. It all depends on your truck. Is it a single cab? Double cab? Crew Max? Is it lifted? What motor? What rear end?
    All these will affect your towing capacity.
  6. Jun 1, 2016 at 6:19 PM
    Ubc2361
    Tony
    Los Angeles
    Cremax, leveling kit, 2015, 35" tires. Im just frustrated at what i read in the web. Just confuses me, maybe what do you guys tow. Any crewmaxs out there towing trailers
  7. Jun 1, 2016 at 8:03 PM
    RockLbstr2011
    RockLbstr2011 New Member
    2011 Crewmax
    This...
    image.jpg10k is about what I've towed.
  8. Jun 1, 2016 at 8:07 PM
    14limited
    14limited Diehard Florida State fan
    Matthew
    14 limited 4wd
    3" OME magnum front bumper and steps spyder headlights MB TKO wheels
    Beat me to it space shuttle
  9. Jun 1, 2016 at 8:26 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I've pulled up to 12k with a DC (wouldn't recommend doing that regularly). The tow rating isn't off too much between the DC and CM if I remember correctly.
  10. Jun 2, 2016 at 3:59 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  11. Jun 4, 2016 at 6:37 PM
    oldschoolhdmike
    oldschoolhdmike New Member
    mike
    2007 tundra crew max 5.7
    not much
    we bought a 2016 travel trailer that has a dry weight of 4400 lbs. we were using my wifes 2007 pathfinder (tow rating 6k) to pull it but even with a weight dist hitch and airbags i still didnt like towing it. it is 26' long. so i bought my tundra. the day i brought it home my wife started looking at bigger campers :) but my next one will be a fifth wheel.....
    Ubc2361[OP] likes this.
  12. Jun 4, 2016 at 9:27 PM
    Toyhaulers are probably out of your reach with a CM Tundra. If you can find a stripped down version, no generator, fuel station, etc. We looked at the TH for camping and empty they were getting up past my tow rating from my CM (9004 lbs).
    Wind resistance is also an ass kicker.
    This was around 8K lbs or less, most likely 7800 lbs.
    69539CA6-A444-4913-88D2-65FFD95C4FF6_zps_b1e110db7e67d0c8b525fcec66c192ef4a22b504.jpg
    This was considerably more...
    AB145BE9-9ADD-45DD-BFF6-D4014438DB40_zps_2f4a6913cf6e43f7e199dfcc6c266c3f6402ef9c.jpg
    The load of wood was so much easier to tow than the 1903 mile trip I just took with the camper. I would suggest airbags and a really good Load Distribution Hitch.
    Ubc2361[QUOTED][OP] likes this.
  13. Jun 4, 2016 at 10:02 PM
    Ubc2361
    Tony
    Los Angeles
    Been reading a lot here n there. But it doesnt look good. :ballchain: guess ill juz settle for just quads and a hotel.
  14. Jun 4, 2016 at 10:27 PM
  15. Jun 5, 2016 at 10:28 AM
    Ubc2361
    Tony
    Los Angeles
    Those are pretty sweet, deffinetly going to look into those. Just wish they were more luxurious. I know soud like a douche dont I
  16. Jun 5, 2016 at 12:58 PM
    No, I get what you're saying. That is most likely why we don't own one.
    -expensive
    -heavy
    -cost vs value
    Tough call on what to do. Personally, I could not imagine towing over 6k with a Tundra, lift and 35's without a huffer under the hood.
  17. Jun 5, 2016 at 2:01 PM
    LightSpeedTony
    LightSpeedTony New Member
    Tony
    Pittsburg, CA
    2013 MGM Tundra Rock Warrior
    4" side steps, line-x, trifold bed cover
    I am currently looking for a toy hauler for my 1900lb race car and I found a company called Forrest river rv. They have a work & play line that will work out for you. As far as the ratings just focus on the gvwr my 13 cm has a 9000lb rating so look at the dry weight plus your toy plus any fluids. Keep it under your trucks gvwr. Also if you get into an accident and you are above your gvwr your insurance won't be there for you.
    Ubc2361[OP] and ColoradoTJ like this.
  18. Jun 5, 2016 at 6:14 PM
    oldschoolhdmike
    mike
    not much
    i have a forest river, (not toy hauler) and love it. it was by far the cheapest one we looked at but it has been a great camper....not as nice as some of the others but literally 10k less than the next one we looked at
  19. Jun 5, 2016 at 6:18 PM
  20. Jun 5, 2016 at 7:05 PM
    Those are pretty awesome TH's. I have a couple buddies with the 38' Gooseneck models.
    Not sure what kind of race car you own, how long it is, or anything other than it is 1900 lbs. So take this with a grain of salt and I will show you the problems I had, which might not be an issue for you. I am just assuming here, but guessing you need 13'x6.5' cargo space.
    If this is even close, you would be looking at a W&P 25WAB
    http://forestriverinc.com/product-details.aspx?LineID=166&Image=5096&ModelID=1909#Main
    25WAB
    • 11356 lbs. GVWR (This is over your 9000 lb tow rating, but you are not in commerce, another assumption)
    • 1196 lbs. HITCH WEIGHT
    • 7486 lbs. UNLOADED VEHICLE WEIGHT (7486+1900=9386 lbs. over weight without any food, clothing, water)
    • 3811 lbs.CARGO CAPACITY (3811-1900=1911-917=994. With full water and food, car you are good to go on the trailer weight)
    • 30' 0"
    • 11' 5"
    • 102"
    • 110 gal.917.4 LBS IF FULL
    As you can see, the hitch weight is way too much, trailer is too much, and is just not advised to look at purchasing.
    Here is the link I posted earlier in this thread. The weights are very similar to the camper I own. Soon we are ordering air bags for my CM, and if this doesn't satisfy our safety concerns, another 1 ton truck will be purchased. My CM is the first truck I have owned without airbags, so I am really hoping that this really stabilizes out my rear axle
    http://www.jayco.com/products/toy-haulers/2016-octane-super-lite/222/
  21. Jun 5, 2016 at 7:23 PM
    On more thing to touch on. The Unloaded Vehicle Weight is with no options what so ever.
    I figured mine would be just fine with a 6600 lbs dry weight rating. I towed it down to my work site and it weighed ~7200 lbs empty, and that was without propane (bottles were mostly empty). So you can imagine how my surprise was when I put 2 large dogs, family of 4, supplies, water (my tank is in the rear, so that is awesome in taking tongue weight off). When I was all said and done, pretty close to GCWR of the trailer, and hell, I didn't even have a 800 lb quad inside the front. I also call bullshit on the 725 lbs hitch weight. That must be with no propane tanks, full water in the back. I had 2500 lb overloads on my truck and had the LDH at max (1000 lb bars) and the truck still squatted pretty good.
    Price
    MSRP
    $34,548
    MSRP + Destination
    $34,548
    Basic Warranty (Months)
    12
    Structure Warranty (Months)
    12
    Roof Warranty (Years)
    12
    Dimensions
    Length
    32.08 ft. (385 in.)
    Width
    8 ft. (96 in.)
    Height
    10.92 ft. (131 in.)
    Weight
    Dry Weight
    6,597 lbs.
    Payload Capacity
    1,603 lbs.
    GVWR
    8,200 lbs.
    Hitch Weight
    725 lbs.
    Holding Tanks
    Number Of Fresh Water Holding Tanks
    Total Fresh Water Tank Capacity
    43 gal.
    Number Of Gray Water Holding Tanks
    Total Gray Water Tank Capacity
    60 gal.
    Number Of Black Water Holding Tanks
    Total Black Water Tank Capacity
    30 gal.
    Propane Tank(s)
    Number Of Propane Tanks
    2
    Total Propane Tank Capacity
    14 gal.
    60 lbs.
    Construction
    Body Material
    Aluminum
    Sidewall Construction
    Aluminum
    Doors
    Number of Doors
    2
    Sliding Glass Door
    No
    Slideouts
    Number of Slideouts
    Power Retractable Slideout
    Yes
    Expandable Bunk
    Expandable Bunk Material
    Hard Shell
    Awning
    Number of Awnings
    Power Retractable Awning
    Yes
    Screened Room
    No
    Leveling Jacks
    Leveling Jack Type
    Front Manual / Rear Manual
    Kitchen / Living Area
    Kitchen / Living Area Flooring Type
    Vinyl
    Kitchen Table Configuration
    U-shaped Dinette
    Kitchen Location
    Center
    Living Area Location
    Center
    Oven / Stove
    Layout
    Oven / Stove
    Number Of Oven Burners
    3
    Overhead Fan
    Yes
    Refrigerator
    Refrigerator Size
    Mid-Size
    Refrigerator Power Mode
    Electric / Propane
    Sofa
    Number Of Sofas
    Sofa Material
    Cloth
    Recliners / Rockers
    Number Of Recliner / Rockers
    Beds
    Max Sleeping Count
    8
    Number Of Bunk Beds
    2
    Number Of Double Beds
    Number Of Full Size Beds
    Number Of Queen Size Beds
    Number Of King Size Beds
    Number Of Convertible / Sofa Beds
    2
    Master Bedroom
    Bunkhouse
    No
    Bathroom
    Number Of Bathrooms
    Bathroom Flooring Type
    Vinyl
    Bathroom Location
    Center
    Toilet
    Toilet Type
    Porcelain
    Shower
    Door Type
    Curtain
    Cargo Area Dimensions
    Cargo Area Flooring Type
    Rubber
    Cargo Area Side Door
    Cargo Area Side Door Style
    Ramp Door
    Wheels
    Wheels Composition
    Aluminum
    Number Of Axles
    2
    Tires
    Rear Tire (Full Spec)
    225/75R 15D
    Spare Tire
    Spare Tire Location
    Exterior Mounted
    Brakes
    Front Brake Type
    Not Applicable
    Rear Brake Type
    Electric Drum
    Battery
    Battery Power Converter
    Yes
    Battery Converter Amps
    55
    Prewiring
    Air Conditioning Prewiring
    Yes
    Cable Prewiring
    Yes
    Phone Prewiring
    No
    Heat Prewiring
    Yes
    TV Antenna Prewiring
    Yes
    Satellite Prewiring
    Yes
    Washer / Dryer Prewiring
    No
    Air Conditioning
    Air Conditioning Type
    Automatic
    Air Conditioning
    13,500 BTUs
    Heater
    Heater Type
    Automatic
    Heater
    30,000 BTUs
    Water Heater Tank
    Water Heater Tank Capacity
    6 g
    Water Heater Pump Power Mode
    Electrical / Propane
    Water Heater Tank Bypass
    Yes
    Speakers
    Speaker Location(s)
    Interior / Exterior
    Television
    Number Of Televisions
    Paint
    Primary Color
    White
    Secondary Color
    Brown
    Metallic
    No
    Interior Decor
    Wallpaper
    Yes
    Interior Wood Finish
    Yes
  22. Jun 5, 2016 at 8:31 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    My wife and I are looking at the 222 and 272 of the superlight model. Says even fully loaded with all dealer options and all fluids weight is right at 9995 for the 272. Need a deployment in order to get it though haha.
  23. Jun 5, 2016 at 8:36 PM
    Ubc2361
    Tony
    Los Angeles
    Im really lovin the xlr hyperlite by forest river. Thanks for all the very usefull info. I think the smallest one they have will be just fine for me. Its no 5th wheel but i think me n my fam will have lots of fun still. Ima start shoping around soon.
  24. Jun 5, 2016 at 9:52 PM
    Hell, even the 24HFS would be a good fit instead of the 18' one.
