What brakes? Pad / rotors?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Dec 15, 2019.
  1. Dec 15, 2019 at 1:45 AM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    My factory front rotors warped badly @ 30,000 miles, (I'm at almost 61,000 miles). I had them successfully turned @ Brakes plus for $40 (They did all the work,I just took my truck in), advanced auto / napa / o'reilly employees refused pretty much immediately.
    I WAS going to go with Power stop, but after reading MANY reviews I'm not going to be going that rout.
    I've been looking on Amazon, They're all over the place in prices / reviews.
    I don't tow anything. I do haul, about 500-1200lbs a day.
    Brakes plus wanted about $1000 for a set of 4 "premium ceramic" rotors / pads. (I'll do them myself.)
    What do you use? What should I look into? I'd prefer a low dust option.
  2. Dec 15, 2019 at 2:06 AM
    GNTundra
    Gino
    2013 White
    Check out Powerstop! :thumbsup:
    15Yota and Prostar 190 like this.
  3. Dec 15, 2019 at 4:46 AM
    classiccat
    classiccat New Member
    2017 Tundra Limited SuperWhite
    I'm also curious what folks are using.
    That said, I've always been happy with Wagner rotors and either Wagner or Raybestos ceramic pads on both an an '01 1/2 ton chevy as well as my wife's '09 Matrix/Corolla. My Tundra's brakes are still all stock.
  4. Dec 15, 2019 at 5:11 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I have been a fan of Hawk, and have raced with Hawk pads for years. Hawk can help you with the proper pad material for your application.
    Does Toyota make a TRD pad for the Tundra? You may want to consider that too.
    Medic343 likes this.
  5. Dec 15, 2019 at 5:15 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    I've been happy with Brembo blank rotors and Akebono Ceramic Pads on my cars. My Tundra still has the factory OEM pads.
    Bigbird57 and jtwags like this.
  6. Dec 15, 2019 at 5:21 AM
    I've been running the power stop z36 front and rear for two to three years with zero problems I would buy them again.
    GNTundra and Doylfish like this.
  7. Dec 15, 2019 at 5:41 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    BTW: Know what your priority is. Low dust? High bite? You have to know what you want the pads to do over and above the Toyota brakes for worth while advice.
  8. Dec 15, 2019 at 7:15 AM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Stoptech slotted rotors
  9. Dec 15, 2019 at 8:11 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    blizz86 and Ajkkane like this.
  10. Dec 15, 2019 at 8:38 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Do not buy Napa.com premiums.
    I'm sure they aren't your list but they case rubbing in the rear between the dust shield/parking brake holder.
    Wore a groove in my dust shields, caused noise, caused sticking/rubbing at starts and stops.
    I spend hours a few nights ago fixing the rotors so that doesn't happen anymore. Way to much work for a in-correctly machined/test design.
    Good luck.
    (i did put on LTS Hawks) they have a good amount of dust but improved brake feel.
  11. Dec 15, 2019 at 8:56 AM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    EBC also makes good pads and rotors pricey but worth
  12. Dec 15, 2019 at 9:21 AM
    black240ct
    black240ct New Member
    I went with EBC, I am liking them over the power stop I used to have.
    Ajkkane likes this.
  13. Dec 15, 2019 at 9:51 AM
    Erick
    Erick
    Thornton Colorado.
    That's two for ebc. I'll be looking into them.
    Thanks guys.
    In looking for more bite with as little dust as possible. I know I can't have my cake and eat it. I understand that. Haha.
    r4z0r51o likes this.
  14. Dec 15, 2019 at 11:43 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I went with EBC stage 5 rotor and pad combo ...
    Awaiting when my current pads are worn for the swap out.
    TRDblvd and Flyinryank like this.
  15. Dec 15, 2019 at 11:46 AM
    timsp8
    NY
    I used power stop before and now have a set in my garage waiting to install. Got a good deal around Black Friday. I’m at about 24k miles and mine shake really bad when they get heated up.
  16. Dec 15, 2019 at 11:57 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    What color pads did you go with?
  17. Dec 15, 2019 at 12:04 PM
    r4z0r51o
    Dave
    Yellow (probably overkill, but I’ve added enough weight with my bumpers that I decided to do so)
    smslavin likes this.
  18. Dec 15, 2019 at 3:39 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I did Power Stop Z36 Pads and rotors on the front. The pads were quiet and low dust but when hot they didn’t seem to stop as good as OE. I do not tow and I very seldom haul heavy loads. After 2000-3000 miles I took the pads off and i put on EBC Extra Duty pads, kept the Power Stop rotors and wow what a difference! The pads are about $180.00 but they stop so much better then OE and Z36.
  19. Dec 15, 2019 at 9:32 PM
    ski
    ski New Member
    When my wife got her Venza the brakes were horrible from the beginning and couldn't wait to get them off. I put Wagner Thermo quiet on with economical rotors. That was about 20k miles ago. The difference was night and day.
    The one thing when I was looking at buying a Tundra was dreading Toyota brakes but from the start and after 12k they still feel pretty good. When they go I'll put economical rotors on as they are disposable and Wagner Thermo quiet pads as I always had good luck with them on my vehicles and I'm tough on brakes.
  20. Dec 16, 2019 at 4:39 AM
    I need rotors and pads myself. I am having issues with my Powerstops. Did you get them directly from EBC?
  21. Dec 16, 2019 at 6:03 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I run Raybestos EHT pads and rotors on everything. Need those coated rotors living in the rust belt.
    nowayout likes this.
  22. Dec 16, 2019 at 6:31 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    I just bought Raybestos EHT pads a couple of days ago, no need for rotors yet. Never ran them on the Tundra but have on past vehicles.
  23. Dec 16, 2019 at 6:53 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Just bought a set of stock rotors and TRD pads to replace my OEM 82K set. Can't go wrong with OEM Toyota!
    hth,
    B
    Oey12 likes this.
  24. Dec 16, 2019 at 6:57 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I put these on for 50 bucks. They work fine and I tow regularly. The only reason I chose Napa is because they are the closest to my house ! Lol
    Prostar 190 likes this.
  25. Dec 16, 2019 at 7:00 AM
    I put those on my daily drivers boy where they a dirty brake pad. After 6,000 miles I took them off and put on Wagner thermal quiets.
    jeremyd[QUOTED] likes this.
  26. Dec 16, 2019 at 7:02 AM
    Have you noticed the dust yet?
  27. Dec 16, 2019 at 7:03 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    yes, definitely some dust.
  28. Dec 16, 2019 at 7:12 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i have the yellow pads with ebc's slotted/drilled rotors. will buy the combo again when needed. the yellow pads are dusty. much dustier than the green.
  29. Dec 16, 2019 at 9:34 AM
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Raybestos element3 EHT have been great on at least a dozen different vehicle brakes I have done. I just ordered front pads, and their coated rotors for my truck. Less than $300 for all pads and 4 rotors.
    Whatever you end up getting, just make sure you break them in properly. Heat those suckers up and let them cool on a good highway drive. Most people complaining about their brakes never bedded them in properly.
    WFD473 and nowayout like this.
  30. Dec 16, 2019 at 10:53 AM
    r4z0r51o
    Dave
    No, got them off of Amazon
