What are your suggestions on brakes and rotors
Discussion in '2nd Gen Tundras (2007-2013)' started by Jon1979, Jun 3, 2020.
  1. Jun 3, 2020 at 2:53 AM
    Jon1979
    Jon1979 [OP] New Member
    Jon
    Upstate NY
    2011 Gray Tundra SR5 4.6L V8
    Hello everyone
    I am getting some pulsing and shimming on the 2011 SR5 and I know the rear brakes are getting close to needed a change. Has anyone used the Power Stop K2813-36 on their trucks?
    What might be a other brands that are good? This is my daily driver and I live in upstate NY so coating is a plus.
    Thanks.
  2. Jun 3, 2020 at 5:13 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I’m following. I’ve not really found great Aftermarket rotor/pads that I’ve been happy with. I put some Powerstops on my old F-150 and wasn’t crazy about them. I put some Bosch pads and rotors on my Lexus RX350 and they’re OK, have a slight vibration when stopping.
  3. Jun 3, 2020 at 5:31 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i put powerstops (drilled) on my wife's car. they're great. for the truck, i went with ebc slotted/drilled rotors and yellow stuff pads. huge improvement over stock. the yellow pads are a bit dusty so if that bothers you, go with the green pads.
  4. Jun 3, 2020 at 6:04 AM
    TONKA TUNDRA
    TONKA TUNDRA HULK SMASH!!
    KY
    2014 DC Magnetic Grey
    I used them on a 2010 Tundra. Went to those as a heavier option when I upgraded to larger tires. Worked well for me but I only had them for roughly 10k miles before the truck was totaled so I can't speak to longevity
  5. Jun 3, 2020 at 6:48 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Where are you located? My current go to are Raybestos EHT3 pads and rotors. Need those coated rotors for the rust belt. I put them on every car that rolls into my home garage (including 3 Tundras).
  6. Jun 3, 2020 at 6:55 AM
    Stoptech Sport slotted rotors
    Tundyfundy likes this.
  7. Jun 3, 2020 at 11:44 AM
    Dr_Al
    Dr_Al New Member
    Al
    What is your goal? Just a good replacement or better performance. I put powerstop rotors and pads on the wife's Rav4, the coated original replacement style. But she's unlikely to "drive it to the max", lol. They seamed fine 25k miles later when she traded it in. Not really a Tundra but I did occasionally tow a trailer with 1000 lbs + on it and didn't notice any lake of braking. If you run larger tires, tow often, or just like stronger brakes then maybe the slotted and drilled rotors would help get rid of the heat.
  8. Jun 3, 2020 at 12:15 PM
    I run the Power Stop Z36 and have been very happy.
  9. Jun 3, 2020 at 12:43 PM
    Jon1979
    Jon
    Upstate NY
    Anyone ever try the Detroit Axle rotors and brakes?
  10. Jun 3, 2020 at 6:27 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Those are ebay specials. Now found on Amazon too. I'd pay up for brakes. At least shoot for mid grade.
  11. Jun 7, 2020 at 10:23 PM
    GuppyWN
    GuppyWN New Member
    Stoptech and Hawk pads.
  12. Jun 9, 2020 at 10:56 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    As a friend told me once: The wife will howl before the tires do.:mudding:
  13. Jun 9, 2020 at 11:38 AM
    Jon1979
    Jon
    Upstate NY
    I do tow a trailer here an there and I have been hauling lumber lately. I might tryout the power stop drilled and slotted. I ran Cardones on my old Rav4 and there worn really well but that is a smaller car verses the Tundra.
  14. Jun 10, 2020 at 5:29 PM
    Bpowa
    Bpowa New Member
    I always used cheap; probably the cheapest rotors with midgrade ceramic pads. I never had an issue with regular driving. Sure the inner casting is rough, but it is for regular driving. I had over 40 vehicles, and it works fine for all of them. I don't cheap out on motorcycles and sporty cars, because they are for the intended use. I have an extra set of spare tundra rotors for the front just in case my rotors are warped. Its been 20k miles so far and no issues. They are cheap enough just to replace and slap on new pads. I guarantee you it is what independence shops use unless requested otherwise. Unless you tow or loaded all the time its the least costly option. Id would say 85% of light truck drivers, including myself don't need performance brakes.
  15. Jun 11, 2020 at 6:33 AM
    Jon1979
    Jon
    Upstate NY
    I would defiantly agree wit you Bpowa about not needing to waste money on performance brakes for regular drivers. I am leery about the cheapest rotors however. I have had cheap ones warp after a short time and the pain of having to change them out to me is worth paying the extra for a good mid grade rotor. That and if you bought two sets of cheap rotors wouldn't it be the same as getting a good mid grade set? With that said I am probably going to go with the standard power stop rotors and ceramic pads. They are about $200 for both axle verse the almost $400 for the performance ones, that and Power stop seems to have a good reputation and other members have had good luck with them
    Thanks to you all for the advise.
    losfirstduty likes this.
  16. Jun 11, 2020 at 7:36 AM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    For those that have the Power Stop, are the edges and “hat” painted black?
  17. Jun 13, 2020 at 1:47 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    i'd recommend the Stop Tech kit. as the full kit includes every thing. pretty sure from a TRD break Thread that Stop Tech makes the TRD brake kit. so it would be a OEM + with out the the price . only around $100 more than the Power Stop kit . i regret my purchase of Black Hart rotors n pads.
  18. Jun 13, 2020 at 10:01 PM
    Punisher17
    Punisher17 New Member
    I have researched this because believe it or not they say no brake rotors are made in the USA anymore!? That sounds dumb. Chinese steel is kinda notorious for being a very soft sub par steel which has made it affordable for sure. In my research EBC says that their rotors can be made in the USA or the UK now I feel like this steel will be a lot better quality. Even the OEM Toyota rotors you get from the dealer will be made in China. I don’t know if there is a way to know exactly where they are made from by the rotor markings maybe? Anyway I swear by those rotors with the combo of the Toyota OEM brake pads which are made from organic material. IMO cheap Chinese steel rotors plus hard ceramic brake pads will result in warping! My .02, 2 cents, $0.02
  19. Jun 14, 2020 at 2:15 PM
    Calnole
    Calnole New Member
    So on the powerstop would you go with the evolution or the extreme?
    My Tundra isn't a daily driver, we don't do a ton of towing with it.
  20. Jun 16, 2020 at 7:42 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Has anyone mess with WP Pro Brake kit .?
  21. Jun 17, 2020 at 11:56 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I have centric rotors with wagner pads on my Tundra. Stops good but got some vibration now. I put OEM toyota rotors with wagner pads on my Sequoia, still smooth.
