What are your favorite mods/improvements?
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Jan 14, 2021.
  1. Jan 14, 2021 at 1:52 PM
    FirstGenVol
    FirstGenVol [OP] Recovering mangler
    East TN
    2002 AC TRD 4x4 V8
    What are your favorite mods, upgrades, or improvements that you have done to your 1st gen? It could be ones you've found most useful or ones that have improved the truck in some way.
    I'll list mine:
    • 285/70/17 BFG's with SCS wheels. Our trucks just look better with bigger tires.
    • ARE Camper shell. This made camping with the dogs so much easier.
    • Natika backup camera. Helped fix my lost visibility that the shell created.
    • White Knuckle sliders which look good and make a great step for reaching the roof and getting into the truck.
    • Honorable mention goes to to the interior LED lighting upgrades. Those original cluster bulbs were terrible.
    MS22, 1lowlife, Sunnier and 2 others like this.
  2. Jan 14, 2021 at 2:10 PM
    ezdog
    ezdog New Member
    Gateway To The West
    My favorite I think was putting Strut in the Bed to be able to really attach crap back there without having to give it a second thought!
    Close behind for me is the Shell for sure though they really work together too.
    When I realized how nice the French Doors made it easier to reach farther into the bed and the Windoors took over from there I knew that my truck would just be the Work Truck that I had always wanted for working on the road far from home.
    T4RFL, alb1k, MS22 and 7 others like this.
  3. Jan 14, 2021 at 2:29 PM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    Was the Strut a DYI thing? That looks pretty cool.
  4. Jan 14, 2021 at 2:31 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Of course!
    Strut is my life
  5. Jan 14, 2021 at 2:32 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    • Leer Camper Shell & Bed Carpet: Without a doubt I have received the most benefit from this mod over any others. This has been on the truck for pretty much its whole life and I have never taken it off.
    • Four sheets of 33"x12" 5/8" plywood; misc wood blocks: Use as traction boards, leveling boards, or to bridge tough spots.
    • Custom Bed Box: Built to my own personal specs to maximize storage potential and minimize amount of unpacking needed. I sleep on top of it.
    • Full size shovel
    • 285/75/16 KO2 E-rated tires and the ride height my current suspension provides
    alb1k, MS22, Sunnier and 4 others like this.
  6. Jan 14, 2021 at 2:38 PM
    des2mtn
    SW
    Tonto cover
    Also removing my backseat was a good idea. More room for my fridge and now people can't beg me for rides.
    Hamster14, alb1k, Hooptytrix and 4 others like this.
  7. Jan 14, 2021 at 2:44 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I guess mine would be one of 2 things. Either the frame repair stiffeners that I fabricated to replace the crappy factory ones that were completely rusted out:
    Or the other mod/improvement would be the leveling kit. It just makes the truck look good.
    Or maybe the backup camera...
    alb1k, MS22, WILLINH and 6 others like this.
  8. Jan 14, 2021 at 2:47 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Gears and speedo correction for me.
    alb1k, two2cal, Hooptytrix and 4 others like this.
  9. Jan 14, 2021 at 2:50 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    That's something I'd like to look into... Speedo correction.
  10. Jan 14, 2021 at 2:59 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its very easy for a 2001 model.
    N84434[QUOTED] likes this.
  11. Jan 14, 2021 at 3:10 PM
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    • RetraxPRO XR bed cover (been wanting one since my 2010)
    • Console charging tray (no brainer...phone stays in it)
    • Nextbase dashcam (too many times I've said "I need a dashcam")
    That's basically all I've done so far, but if we're going with favorites, this must be them because that's what I went with first. The rest of the "to get" list is long...
    alb1k likes this.
  12. Jan 14, 2021 at 6:07 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    tacoguybill, alb1k, two2cal and 6 others like this.
  13. Jan 14, 2021 at 6:15 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Are you a sparky?
    I like the strut idea, spring nuts and all the bracketree are usually easy to come by in the shop.
    How many anchor points do you have on the length of those?
  14. Jan 14, 2021 at 7:12 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    I also have to say my best one was the RetraxPro. Pricey but I expect to have my Tundra long term so worth it.
  15. Jan 14, 2021 at 8:30 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I made my boat rack out of unistrut. 20200818_163811.jpg 20201025_120409.jpg
    My favorite mods in order.
    6in RCD lift.
    Custom leaf packs.
    35 inch Duratrack.
    4.88 gears.
    ARB rear locker.
    Air compressor.
    Boat rack.
    Sway bar quick disconnect.
    Black oak led ditch light.
    alb1k, two2cal, MS22 and 17 others like this.
  16. Jan 14, 2021 at 9:48 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Audio upgrades (Kenwood double din Android Auto, amplifiers, sub box) and comfy seat covers for me.
    BlueRibbon4x4 likes this.
  17. Jan 14, 2021 at 10:26 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Happen to have pics of your sway bar quick disconnect? From your other mods, I assume it’s fabbed by you?
    Sunnier likes this.
  18. Jan 14, 2021 at 11:55 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Fixing the previous owners small dent
    2019 86 radio, adding factory power options and keyless entry... loving this shit
    alb1k, abcinv, MS22 and 12 others like this.
  19. Jan 15, 2021 at 12:11 AM
    empty_lord
    05 rollover special
    They made a rubber mat for the 8 ft??? Fuck I need to find one
  20. Jan 15, 2021 at 12:24 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    My favorite is being able to drive past the 2nd n 3rd gens sitting in driveways while I back into my garage :)
  21. Jan 15, 2021 at 5:04 AM
    ezdog
    ezdog New Member
    Gateway To The West
    More of a LV "Commie" but the stuff is often the same!
    So each vertical stick is attached with 3 5/8 Rivnuts so that I could find flat spots to mount them blind and then the horizontal long section blind nuts to those. I can then of course move the horizontal stick up or down as needed on the vertical sticks and I can always add to any of it too.
    Yeah I just used stuff that I already had laying around at the time.
    Sunnier and FrenchToasty[QUOTED] like this.
  22. Jan 15, 2021 at 5:06 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I love that thing,and I bet you know which one I mean!
    Brown Bear[QUOTED] likes this.
  23. Jan 15, 2021 at 5:07 AM
    ezdog
    ezdog New Member
    Gateway To The West
    "We can fix that,My Dad has an Awesome set of tools"
  24. Jan 15, 2021 at 5:21 AM
    Outbound
    Aaron
    Northern Alberta
    My fav mods in order:
    - LED headlights
    - Thule TracRac SR and Truxedo tonneau combo
    - TRD SEMA wheels with Cooper ST Maxx tires
    - Bilstein 5100s
    - LED interior lights
    alb1k, MS22 and BlueRibbon4x4 like this.
  25. Jan 15, 2021 at 5:49 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have owned this '02 since '03...
    • TRD off road front coil springs
    • JBA short tube headers to replace cracked manifolds
    • LED headlight bulbs
    • Wet Okole seat covers
    • Hellwig rear anti-roll bar
    • TRD/Kazuma LSD
    • Bilstein Yellow 4600 series shocks
    • Michelin tires
    • Line-X on multiple surfaces
    • 2005 taillights
    • ARE commercial high wedge cap
    • Ceramic tint, front & sides
    I am considering those fancy fuel injectors.
    https://www.tundras.com/threads/2002-sr5-4wd.70271/
    Haggis777, 1lowlife, saybng and 4 others like this.
  26. Jan 15, 2021 at 9:20 AM
    TheBlackPearl
    La Gulf Coast
    My bad...didn’t realize you couldn’t post in certain subs unless you had specific years. :(
    alb1k, MS22, Darkness and 2 others like this.
  27. Jan 15, 2021 at 10:19 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    By far my favorite, Replacing the heater control bulbs with led!
    Stereo upgrades, HID headlights and 4runner trail rims
    N84434 likes this.
  28. Jan 15, 2021 at 10:19 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I've kept my 06 DC stock as much as possible, except for a few 'add-ons'.
    #1. Snug Top 'Super Sport' shell. Dig the frameless window and rear pop-out.
    #2. 3M Crystalline window/full windshield tint. I went light for safer night driving, but man what a difference!
    #3. Weather Tech Floor mats front and back . . . they're killer.
    'On Order'- Full set front and back Carhartt Precision Fit Seat covers in grey.
    MS22 likes this.
  29. Jan 15, 2021 at 10:29 AM
    artsr2002
    'Yonder
    HID retrofit for me also. :D
  30. Jan 15, 2021 at 11:07 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    A rubber mat in the bed and new strut assemblies and shocks, the first set since new, almost 20 years now. This is the longest I've had a vehicle. Still only at 95K miles. I ride motorcycles most of the time, and for a long time I had a Suzuki Swift 3 cylinder mileage maker. Had it for 15 years. Hard to beat Japanese cars. I bought the Suzuki with 50K miles on it used, and it had over 240K miles when I sold it. Still running fine and using zero oil. It just got so cosmetically challenged I was embarrassed to drive it.:thumbsup:
    N84434 and HBTundra like this.
