What are you using to add transmission fluid after drain??
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodm1, Sep 14, 2023.
  1. Sep 14, 2023 at 5:01 PM
    rodm1
    rodm1 [OP] New Member
    It looks like a pain to get at the fill plug I'm thinking a large SYRINGE 1.5L would work best. What have you found that works well on the Tundra?
  2. Sep 14, 2023 at 5:06 PM
    AZBoatHauler
    So.Arizona
    Run vinyl tubing from the engine bay to the fill port. Attach funnel to tubing.
  3. Sep 14, 2023 at 5:12 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yup. 5/8" O.D. 6' long piece. Presto.
    Once you get the tube routed (drivers side) it is useful to get it nicely positioned in the engine bay for adding fluid then tape it into position so it doesn't move. And cause I don't take chances on spills I tape it secure also down at the transmission.
    rodm1[OP] likes this.
  4. Sep 14, 2023 at 5:14 PM
    737fixer
    737fixer New Member
    Exactly on both previous. Exactly.
    schleinj likes this.
  5. Sep 14, 2023 at 5:15 PM
    rodm1
    I did that with the front dif other then the tube kinking it worked good thanks.
  6. Sep 14, 2023 at 5:17 PM
    Retired...finally
    Worked for me
  7. Sep 14, 2023 at 5:47 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I use a slippery pete pump on my transmission, diffs and tcase. It works great and no needing to snake tubes from above.
    https://a.co/d/9Y0DPwC
    Jbehredt and Mike59 like this.
  8. Sep 15, 2023 at 6:11 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    I use $10 pump up sprayer from Home Depot, remove nozzle and heat and bend wand to a hook.
    Bill3648 likes this.
  9. Sep 15, 2023 at 6:59 AM
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
    This^^^
    Built these from pump sprayers and 3/8ID tubing. 3D printed the yellow stoppers
    Big one is for differentials just used the smaller for the transfer case.
    rodm1[OP] and Reddawg1100 like this.
  10. Sep 16, 2023 at 3:00 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Same .easy
