What Am I Missing?
Discussion in '1st Gen Tundras (2000-2006)' started by jpink, Nov 26, 2020.
  1. Nov 26, 2020 at 8:19 PM
    jpink
    jpink [OP] Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    So first time doing brakes. The passenger side went amazingly well compared to my driver side experience. No matter what I do the shoes seem to rub even when at zero with the self adjuster.
    I took the driver side back apart. I compared to passenger side. I looked at my starting picture. I did different springs for the heck of it. I can’t figure it out.
    I need smart eyeballs. The part numbers on the pads match both sides. They all looked the same.
    The biggest difference I found was that the self adjusters from Raybestos, despite ordering same kit, one was silver/gold and the other was gold/gold.
    The silver/gold one is on driver side. No matter how I seem to position, or whether I use green or yellow spring, and no matter how I position the spring. It rubs. I feel like this is it but I’ve now spent three dumb hours on this one side.
    Driver shoes so tight that couldn’t slide drum on. Backplate had a pinch in one spot that you might see in photos. I did bend that outward so that’s not the issue. This is for sure shoe rubbing/blocking before I can even slide the drum all the way on.
    Driver Before:
    Driver Now:
    Happy Passenger?:
  2. Nov 26, 2020 at 8:29 PM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Swap adjusters and see if the problem follows.
    Or put old adjuster back in to see if it works. Compare them side by side. This should eliminate the adjuster if you have the same results.
    Old or new drums?
    If new swap drums and confirm if both do not fit on the driver side. If one does and the other doesn't you have the wrong drum for the driver.
  3. Nov 26, 2020 at 8:35 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Are those different cylinders? Looks wider?
  4. Nov 26, 2020 at 9:09 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    If all else fails, sandpaper can be your friend on those drum brake shoes. Man I hate drum brakes.
    GIN•OKUMA, artsr2002 and Tundra2 like this.
  5. Nov 26, 2020 at 10:58 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    There is a rear disc brake conversion kit.
    Tundra2 likes this.
  6. Nov 27, 2020 at 4:26 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Agreed!
    Tundra2 likes this.
  7. Nov 27, 2020 at 5:23 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Hmm. I like puzzles. Can't you spin the star adjuster and back the shoes off a bit? I know that's only part of your issue but I'm curious.
  8. Nov 27, 2020 at 5:31 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Check your Bell Crank adjustment. In fact, maybe even unclip the parking brake cables altoghther 'til you get the brakes adjusted right, and then follow the FSM procedure to adjust the parking brake.
    I had a similar experience recently when I did mine, and it turned out that the top spring had come unhooked behind the parking brake lever where I couldn't see it, allowing the shoes to open more than they should have
  9. Nov 27, 2020 at 5:56 AM
    w666
    Maryland
    Also, change out the adjuster to the original one to see if it makes a difference.
    It may be the camera angle/distortion, but it looks like the backing plate might bent in spots (did you try to pry the drums off?). Check that the drums aren't rubbing on the backing plate.
  10. Nov 27, 2020 at 5:58 AM
    Professional Hand Model
    Hand Protectors
    The Star Adjusters are specific to each side as they have different threads. One is a left hand thread and the other a right which probably is why they are color coded.
    I did my drums one side at time and reused my old adjuster as they were in good shape. Lubed them up nicely.
    We had one member who did his drums simultaneously and got the parts mixed up. He ended up mixing the Star Adjusts on the wrong sides during put back. After a few days of driving his drums were locking and smoking. Unsure what he did he was perplexed. Ended up he finally figured it out.
    The Star Adjust is a self adjusting drum brake device. It should only adjust one way by itself with A PROPERLY ADJUSTED PARKING CABLE. Every pin, clip, arm, cable connection, and turnbuckle is a lever point. Make sure everything is unsiezed and then lube the crap out of it. Leave a wad of grease on everything. MolyB on the metal and Silglyde on the rubber.
    The fix here? Depending on the condition of the old Star Adjusters, I’d consider putting them back on as they are very specific in design. Figuring out the placement is up to the user. I believe the driver side is clockwise and pass side is counter clockwise TO TIGHTEN (when looking from front to back). Reverse to loosen.
    I bought NAPA Kit to do my drums and only used the horseshoe clip and big tension shoe spring. Everything else looked inferior and slightly different. I learned most all of this from reading. Rest of the stuff my Golden Hands showed me.
  11. Nov 27, 2020 at 6:54 AM
    jpink
    Knoxville
    I volunteered to work today, so some answers now and some attempts later.
    New Toyota drums. Which claim to not be side dependent. Also, what was on there does not seem to have been Toyota drums.
    Adjuster seems to be same size as what was there. But was too hungry and tired last night to attempt to swap. Will attempt a legit swap over lunch.
    I did the Raybestos WC37690 which claim to be a fit for the 05 DC Tundra, and do look like same size. Everything did line up but will examine closer if SA swap later doesn’t do it.
    It’s bottomed out right now. Can’t go any less.
    I will inspect this closer this afternoon when attempting SA swap. Right now the cable is fairly loose and isn’t engaged. Either way I need to adjust it because it doesn’t work currently so won’t be any harm in disconnecting entirely for now.
    Not the camera angle, it was bent prior to me starting this. I did bend it back out in one spot. When I removed the old drum it slid off no issue so I’m not sure how it got bent but was prior to the work I did. AngelEmoji.jpg
    Past JPink knew enough to order correctly, Present JPink had just enough dumb luck to associate properly. Silver/Gold is Raybestos H12584 which is Rear, Left side.
    I ordered two of the Raybestos H17343 hardware kits which don’t seem to be side specific. It might not hurt to acquire the Toyota one from dealer, if they have some on hand, and just compare.
    Thanks all! I’m going to try and attempt some of this over lunch and the rest tonight.
  12. Nov 27, 2020 at 7:16 PM
    jpink
    Knoxville
    As an update....
    3 minutes into revisiting this I tapped the shoes upwards and solved it. Somehow I apparently had not positioned these right. Multiple times. Seemed to solve it before the pizza even arrived tonight.
    Takeaways: definitely should’ve revisited my parts ahead of this. Lucked out getting the SA on the correct side. Should’ve stopped for a dinner break on Thanksgiving instead of telling myself, “I can eat after I get the face greased up like PHM.” and spiraling into madness.
    If I could buy a round of beers for you all, I would.
  13. Nov 27, 2020 at 7:26 PM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Glad you got it solved
  14. Nov 28, 2020 at 5:44 AM
    Hand Protectors
    Nice! What you did was align the Mojo.
    Stuck in the '00s likes this.
  15. Nov 29, 2020 at 2:33 PM
    Hand Protectors
    Looks like you forgot the Silglyde on the contact points where the shoes meet the drum backer. Should be 4-5 contact points (bump outs) on the backer plate. Also, Silglyde the contacts where the shoe meets the cylinder plunger (12 o’clock) and the bracket contact at 6 o’clock. Make a huge difference in quietness as well as performance feel.
  16. Nov 29, 2020 at 2:36 PM
    Hand Protectors
  17. Nov 29, 2020 at 3:00 PM
    jpink
    Knoxville
    Interesting. I did put it in the backing plate and hub but not elsewhere.
  18. Dec 5, 2020 at 5:28 PM
    jpink
    Knoxville
    @Professional Hand Model pulled everything off and added in some grease on the points you highlighted.
    How we feeling?
  19. Dec 5, 2020 at 6:21 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    If you ever watch an old fart doing his umpteenth drum brake job, you'd see him give both shoes a good open-palm heel whack a few times and watch him smile if the assembly makes a sproing-click sound.
    Lil Steve and jpink[OP] like this.
  20. Dec 5, 2020 at 6:28 PM
    jpink
    Knoxville
    Smack it into submission!
  21. Dec 5, 2020 at 6:58 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    jpink[QUOTED][OP] likes this.
  22. Dec 6, 2020 at 5:16 AM
    Hand Protectors
    Looking good! Should be a quiet rear brake system especially in reverse. Had brake service done about 8 years ago and the guy didn’t use grease. Squealed from the very first back up and every time thereafter when backing up.
  23. Dec 6, 2020 at 6:43 AM
    jpink
    Knoxville
    I’ve had squeaky brakes in the past and I wish I would’ve been smart/brave/empowered enough to investigate the issue myself.
    Now to just bleed them. Again. Thanks for having an Eagle Eye PHM!
