What am I missing here?
Discussion in 'Towing & Hauling' started by Ruggybuggy, Jan 23, 2020.
  1. Jan 23, 2020 at 6:38 AM
    Ruggybuggy
    Ruggybuggy [OP] Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The Ford Ranger has a payload of 1354lbs. My 2020 Tundra SX double cab has a payload of 1300lbs.
    How does the payload number get determined? I use to have a 2010 Silverado which had one piston caliper brakes and small rotors. My new Tundra has 4 piston caliper with larger rotors and it has lower payload and tow numbers. When I pulled my 21' boat with the Silverado it had scary long stopping distances but my Tundra is much better.
    focal likes this.
  2. Feb 11, 2020 at 2:39 PM
    awq735
    awq735 New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    How much did your previous vehicles weigh? I believe the tundra's curb weight us around 5800 pounds with a max gvwr of 7100
  3. Feb 11, 2020 at 9:29 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Curb weight of the Silverado was around 5400lbs.
    SR5 4x4 has a curb weight is around 5470lbs.
  4. Feb 11, 2020 at 9:35 PM
    SAE J2807 standards is how everything is determined.
    The Ford Ranger also cannot pull 9500lbs either.
    My Kubota RTV1100 side by side at work has a 1635 lb payload. Can’t say this would be a better tow rig.
    15whtrd and Ruggybuggy[OP] like this.
  5. Feb 19, 2020 at 4:20 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Look guys, you are not going to transform a Tundra into something that it is not meant to be. Tundra payload ratings are somewhat poor. It is a fine balancing act between payload and towing capacity. I have come to the conclusion that my Tundra is ok for trips to Home Depot and towing a moderate utility trailer. If I was to get a camper it would need to be a relatively small one in order to stay within the Tundra's payload limitations. I love this truck and it does everything I need it to for my current lifestyle but I sometimes wish I would have kept my 2500 Duramax.
    ColoradoTJ and ScottsTundra like this.
  6. Feb 19, 2020 at 4:39 AM
    FULL-THROTTLE
    FULL-THROTTLE New Member
    2018 Tundra TRD
    none
    What's going on everybody, I just put down a deposit on a 7000 pound 5th wheel trailer knowing I would be well within my towing capacity, THEN I come here for advice ( I know Im a dumbass) and realize the payload won't handle it ,SH!T, how is everyone doing this? they must be way out of spec.
  7. Feb 19, 2020 at 4:53 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    I never had any issue towing heavy loads with a first gen. Second gen shouldn't be too much difference, same 4.7. The boat seen is the heaviest, and did ok over 2 big bridges. There comes a point were it could be too much, for instance if your towing a excavator or a huge back hoe then Diesel power would be the way to go and now you have to buy American. Something with a Cummins Diesel is my choice.
  8. Feb 19, 2020 at 5:49 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What's the pin weight of the trailer? What is the total weight you will have in the truck? Total weight would be people, cargo, and any accessories you added? Did you add a lift and bigger tires? Figure out the total then check the decal on the door which will give you the payload.
  9. Feb 19, 2020 at 6:22 AM
    FULL-THROTTLE
    2018 Tundra TRD
    none
    I have the same as you 1320, I guess I screwed the pooch on this one. The good news, I get to go shopping again for a tow trailer instead of a 5th wheel.
    ColoradoTJ likes this.
  10. Feb 19, 2020 at 6:26 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I think your being a little conservative on what the Tundra can tow. Keeping in range of the payload number you could tow up to 7K trailer. Let's say the tongue weight of 800lbs. That leaves 520lbs of payload left. Two normal weight people at 350lbs leaves 170lbs left of payload. A 7K TT is actually a pretty large trailer and would be in the range of 25' to 29'.
    This 25' Coachman can be easily towed by almost any Tundra.
    15whtrd likes this.
  11. Feb 19, 2020 at 6:30 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Add air bags
    Boerseun likes this.
  12. Feb 19, 2020 at 6:46 AM
    plumber802
    Andy
    Vermont
    There's more to it than that...
    Ruggybuggy[OP] likes this.
  13. Feb 19, 2020 at 7:00 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Yeah I realize that, but it was a brief suggestion that was much less expensive than a new truck. A good air bag kit and E rated tires on a Tundra goes a long way as far as payload capacity.
    Boerseun, focal and KMG like this.
  14. Feb 19, 2020 at 7:27 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There are some forum members that tow 5th wheels. Do the math and it might be close that you may want to consider the 5th wheel. The 5th wheel is a more stable platform to tow and the overall length is shorter for the same length floor plan.
  15. Feb 19, 2020 at 9:20 AM
    liquid_g
    liquid_g New Member
    Grantham, New Hampshire
    2018 Tundra Platinum
    Maybe I'm wrong here, but airbags are just going to lift up the back end / or prevent squatting of the rear end.
    If you're towing something that heavy that is causing you to think you need airbags, wouldn't a proper Weight Distribution Hitch be a better/safer thing to do?
    Tracy Perry and ColoradoTJ like this.
  16. Feb 19, 2020 at 9:42 AM
    Tundrius
    Tundrius New Member
    Jonah
    08 tundra, matching 10 prius!
    If I was better with this forum I would link to a towing thread from a while ago. Guy was showing off how he could pull a 37 foot bumper pull that was 10k gvr. He had it all specked out to handle the hitch/tongue weight and GVR, etc.... I pull a 27ft bumper with a GVR of 7200 and I load my bed with generators, bikes, etc.... prior to that I owned a 9100lb fifth wheel. I have pulled these trailers literally thousands of miles. Most recently over i70 through the Eisenhower tunnel with no issues. These trucks can handle plenty.
  17. Feb 19, 2020 at 9:49 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Not missing anything, OP. Tundra payload numbers are a joke.
    Now to everybody that just says "oh they can handle much more".....you guys are missing something.
  18. Feb 19, 2020 at 9:57 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Air bags help to keep your truck level when there is a load on the rear, but there are other factors to increasing your payload capacity, like E rated tires and larger brakes. A weight distribution hitch will definitely help but is not an end all/be all for the extra tongue weight of the camper the OP is purchasing.
  19. Feb 19, 2020 at 10:57 AM
    Htrailblazer
    Htrailblazer New Member
    2018 CM TRD Blazin Blue
    I may be mistaken but I don't think you have to include driver weight when adding up numbers for payload.
  20. Feb 19, 2020 at 11:15 AM
    Atomic City Tundra
    Devin
    New Mexico
    Yes you do.
    Your GVWR is what it is. You can't be over it. Whatever you throw in/on the truck is considered payload.
    There seems to be mass confusion over this because of the SAE standard used for towing capacity. That one allows for two 150 lb occupants and some allowance for trailering gear. That is for towing. It doesn't mean squat for payload - there is not "hidden bonus" that bumps up your GVWR.
  21. Feb 19, 2020 at 11:27 AM
    timsp8
    NY
    Airbags also just put more weight on your rear axle. They do level the truck but don’t really distribute the weight.
    Atomic City Tundra likes this.
  22. Feb 19, 2020 at 11:35 AM
    Atomic City Tundra
    Devin
    New Mexico
    Yep. Adding airbags actually reduces the amount of payload you can carry.
  23. Feb 19, 2020 at 11:46 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
  24. Feb 19, 2020 at 12:43 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I only use airbags to help support the rear springs so as to not have permanent sag when not towing. Also makes the ride a lot smoother, nothing worse than hitting those bump stops.
  25. Feb 19, 2020 at 12:53 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    My 6500 lb 5th wheel has a hitch weight of 1100. I'm gonna help myself out by ditching my rear hitch which I've heard is around 80 lbs, only filling my gas tank to approx 2/3 to gain back the 80 lbs lost due to the larger tank plus use an ultimate hitch that weighs in at 40 lb vs the usual 120 or more.
    Figure by the time I'm on the road I'll be about 100 over which doesn't concern me one bit.o_O
    I'm a heck of lot more concerned about the lack of a trans cooler. I'm still trying to decide what to do with that issue.:monocle:
  26. Feb 19, 2020 at 1:04 PM
    Installing airbags does not add payload capacity.
    NewImprovedRon likes this.
  27. Feb 19, 2020 at 1:12 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
  28. Feb 19, 2020 at 2:06 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do nothing and don't worry about it. The 19 and 20 DO have a trans cooler. It's a oil to coolant heat exchanger which is actually more efficient. Do you think Toyota didn't test the result of the change? They aren't going to risk their reputation because of failed transmissions.
    WNY PAT likes this.
  29. Feb 19, 2020 at 2:20 PM
    timsp8
    NY
    I don’t think a heat exchanger is more efficient than the actual atf flowing through a cooler. That part was called a warmer a few years ago. There is a thread on here discussing the reasons why it was removed, but no one outside Toyota knows for sure. Could be cause it didn’t need it, but it could also be some other reason we don’t know and Toyota is taking its chances with the probably less than 10% who actually tow.
  30. Feb 19, 2020 at 2:34 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Toyota doesn't take chances when it comes to reputation. An oil to coolant exchange is more efficient than an oil to air. You can make the heat exchanger smaller. An oil to coolant heat exchanger acts as a warmer when the trans temp is colder then the coolant. After the trans warms up and its temperature is above the coolant temp it is now a heat exchanger.
