What am I going to get myself into?
Discussion in 'General Tundra Discussion' started by Outbound, Aug 13, 2018.
  1. Aug 13, 2018 at 4:33 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Of course while I'm planning to do my shocks and ball joints, a lovely squeaky noise starts up. Guess I can add one more thing to the repair list. Only problem is, I'm not a mechanic so diagnosing this is beyond me. I can't seem to chase this squeak down. It happens when the truck is bounced, either while driving or when someone gets in/out. I first thought shocks, but when I slid underneath, the squeak sounds more central.
    Here's a vid of my mystery noise.
    Any ideas?
    ColoradoTJ likes this.
  2. Aug 14, 2018 at 3:39 PM
    Outbound
    Aaron
    Northern Alberta
    No ideas eh? LOL.
    I'm still stumped. Nothing appears to be broken. I'm wondering if it's bushings, maybe on the lower control arm?
    Could be rack and pinion too I suppose.
  3. Aug 14, 2018 at 3:43 PM
    Upper ball joint?
  4. Aug 14, 2018 at 3:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Free bump hoping someone has a good idea.
    Outbound[OP] likes this.
  5. Aug 14, 2018 at 3:45 PM
    TheBeast The Beach
    sounds like a squeaky bed at the motel 6....
  6. Aug 14, 2018 at 3:47 PM
    Professional Hand Model
    Hand Protectors
    Bushings probs have mud cack in them. Rinse with water and then spray some liquid degreaser mixed in water on all your bushing areas, then rinse again. I had that same squeak and what I described worked. Ultimately, I ended up having a mechanic redo the entire front when I had new shocks put on (Billy 5100’s).
  7. Aug 14, 2018 at 3:55 PM
    Outbound
    Aaron
    Northern Alberta
    The seem to be ok, and when I slide under the truck to listen to the noise, it's definitely coming from lower down and more centrally located.
    I'll give that a try, thanks! I'm starting to think more seriously about having the front end completely redone by a mechanic along with the 5100s. Considering upper/lower ball joints, tie rod ends, maybe control arm bushings, rack/pinion bushings and the 5100's all around. I'd like to avoid fully replacing control arms if I can due to cost.
    I could try to do it myself but I need about $300 in new tools, plus I've never done anything so involved. With the Tundra our only vehicle I can't really afford to have it up on jackstands for multiple days while I bumble my way through it. A mechanic could probably have it all done in a day. Going to call around for some quotes this week.
  8. Aug 14, 2018 at 3:57 PM
    Blueknights75
    Ron
    Clayton, NC
    Have you checked body mounts possibly??
  9. Aug 14, 2018 at 3:59 PM
    Outbound
    Aaron
    Northern Alberta
    I have not. I'll add that to the list to check.
  10. Aug 14, 2018 at 4:08 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Giggity
    15whtrd, TheBeast, Black Wolf and 2 others like this.
  11. Aug 14, 2018 at 4:23 PM
    :anonymous::spy:
    Black Wolf likes this.
  12. Aug 14, 2018 at 5:24 PM
    Outbound
    Aaron
    Northern Alberta
    D'oh! This is brilliant and would totally satisfy my methodical semi-OCD system of diagnosis. Thanks!
    Black Wolf, Sunnier and driverdog like this.
  13. Aug 15, 2018 at 3:12 PM
    Outbound
    Aaron
    Northern Alberta
    Well, it must have been dirt or grit lodged somewhere. I haven't had a chance to really look at it yet and the squeak has disappeaed. :notsure:
    No complaints here. LOL. Now I get to chase down the rattle that happens everytime I apply the brakes at low speed. :frusty:Thinking that may have something to do with the calipers.
    driverdog likes this.
  14. Aug 15, 2018 at 3:48 PM
    Hand Protectors
    Think your wife worked it out with all that rockin’?
  15. Aug 15, 2018 at 4:46 PM
    Outbound
    Aaron
    Northern Alberta
    Doubt it. It was still squeaking last night and we had't done anything more than typical driving. Dunno when it stopped. I wasn't really pay attention this morning on the way to work due to my pre-coffee haze.
  16. Aug 15, 2018 at 5:16 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Check the skid plate rubbing on something. Sounds like then metal
  17. Aug 15, 2018 at 5:26 PM
    Hand Protectors
    It was probably mud cack in the bushing. Degreaser helps, but in this case his went away on its own. Mine had this same squeak as the OP video. It would come and go (usually winter coldness time). One day I had an idea and used liquid degreaser mixed in water and sprayed things down. Squeak never came back. Bushings were still old, but squeak went away.
  18. Aug 15, 2018 at 5:27 PM
    Twinky
    07 double cab work horse
    Kinda sounded like metal to me too.
    But while your down there you can check your sway bar end links and bushings.
  19. Aug 15, 2018 at 6:11 PM
    Outbound
    Aaron
    Northern Alberta
    Here's the latest noise I'm trying to chase down. Only happen when I apply the brakes at low speed.
  20. Aug 15, 2018 at 6:14 PM
    Hand Protectors
    Never heard that one before althought video noise can be deceiving. Maybe ABS sensor disconnected? Brakes work fine, but just noise? Could be brake pads need replaced?
    15whtrd likes this.
  21. Aug 15, 2018 at 6:45 PM
    Outbound
    Aaron
    Northern Alberta
    Video noise is pretty much spot on. Brakes work perfectly, just the noise. No warning lights or anything. Doesn't seem to be anything disconnected that I can tell without pulling off the wheels. I'm going to pull wheels off this weekend to have a look at it but last check about 4 months ago had the pads at 70%.
  22. Aug 15, 2018 at 7:43 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    You got a gremlin problem man.
    Outbound[QUOTED][OP] likes this.
  23. Aug 15, 2018 at 7:55 PM
    That sir is your backing plate rubbing the rotor. You just need to bend it out a little. Only happens when turning right?
    15whtrd and 831Tun like this.
  24. Aug 15, 2018 at 7:58 PM
    Great. I had this turned up and the wife thought I was watching porn. She wanted to watch and was left disappointed.
    Guess we will have to go make our own squeaking noise now.
    Guess no more internet for me tonight....pffft!
  25. Aug 15, 2018 at 8:03 PM
    Outbound
    Aaron
    Northern Alberta
    It'll happen when going straight as well. I just happened to remember to film when I turned into the drive.
    You're welcome? :D
  26. Aug 15, 2018 at 9:55 PM
    I would bet it is still the backing plate. If the wheels have been removed lately and this happened all of a sudden, this is what happened to my Tundra.
    Thank you sir!
    The squeaking sure sounds like bushings. Like others have said, use some penetration oil. Makes me wonder if it isn’t the shock bushings on the lower control arm.
  27. Aug 15, 2018 at 10:35 PM
    Twinky
    The original noise, does it squeak regaurdless of what kinda of movement your front end makes?
    When parked with the truck running does rotating the steering wheel one direction and then all the way back the other direction cause a constant type of squeak/skawk/squeal/ other various onomatopoeias?
    Or was the way you originally showed us pretty much it?
    The brakes, i think Mr. ColoradoTJ may have nailed that one. If not, then probably another thin flimsy piece of metal similar to it.
    Makes sense as to why its most noticeable when theres not a lot of force transferring to the front.
    Thats about a one beer fix.
  28. Aug 16, 2018 at 5:05 AM
    Outbound
    Aaron
    Northern Alberta
    I'll check the backing plate when I'm under there. I cant remember when it started but I did have the new wheels put on couple months ago. That may have been it.
  29. Aug 16, 2018 at 5:06 AM
    Outbound
    Aaron
    Northern Alberta
    The original noise is only whe bouncing like in the videos. I did check for onomatopoeias while turning the wheel and all is quiet then.
