What’s up guys
Discussion in 'New Member Introductions' started by BlkTundra16, Dec 9, 2020.
  1. Dec 9, 2020 at 9:03 AM
    BlkTundra16
    BlkTundra16 [OP] New Member
    Frankie
    2016 black tundra
    Led hood light bar , bullbar , led head lights , blacked out led tail lights
    Guys I’m wondering if I put BillStein5100 shocks on highest setting and 1/2 inch shim on the fronts. With a 1.5 toy tech shackle in the rear will I run into any problems ?
  2. Dec 9, 2020 at 9:50 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA
    Can’t specifically answer your question but don’t think so.
    BlkTundra16[OP] likes this.
  3. Dec 9, 2020 at 9:56 AM
    Welcome from NY.
    Hopefully somebody will chime in with the answer.
  4. Dec 9, 2020 at 10:02 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  5. Dec 9, 2020 at 10:48 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Dec 9, 2020 at 10:49 AM
    chaddydubbs
    chaddydubbs New Member
    Chad
    Omaha, NE
    2017 MGM Tundra SR5 Crewmax
    Tyger running boards, black badge overlays, stubby antenna, TRD Pro grille, window tint, LED interior lights
    Welcome from Omaha!
  7. Dec 9, 2020 at 11:07 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Hi, welcome. Yes it will work. But you're starting to get into the height that might need UCA also. Check out the suspension forums, there is TONS of info about this. Start reading up and pull out your wallet!
  8. Dec 9, 2020 at 11:55 AM
  9. Dec 9, 2020 at 4:04 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  10. Dec 9, 2020 at 4:26 PM
    Blue Thunder
    Washington
    Welcome from WA. Grab a beverage and start searching
  11. Dec 9, 2020 at 7:40 PM
    Welcome from Ohio
