What’s the best engine air filter?
Discussion in 'Performance and Tuning' started by gosolo, Oct 20, 2019.
  1. Oct 20, 2019 at 3:21 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    Looking for information about engine air filters.
    I know that all filters are not equal, which filter element is best for our trucks, and why?
    I don’t want a new box or intake system, just recommendation for replacement filter element in the factory box
    OR18TRD likes this.
  2. Oct 20, 2019 at 3:24 PM
    Azblue
    The Dirty T ( ^_^)_且
    I usually go with OEM or Wix.
    YardBird, Rica25 and gosolo[OP] like this.
  3. Oct 20, 2019 at 3:26 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    OEM Toyota, or find out who private labels for Toyota and buy direct.
  4. Oct 20, 2019 at 3:32 PM
    OEM paper will filter the best.
    YardBird and 15whtrd like this.
  5. Oct 20, 2019 at 3:35 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Toyota doesn't make filters. I've been in the filter business a number of years and hate to say, they're isn't dime's worth of difference from most of them as long as they are produced here. I sell a fair amount of heavy equipment filters and the brand is Baldwin. They cross a lot of filters. Most OEM filters are just private labeled at the big filter factories. Few people realize that when you change your air filter that it's a the least stage of efficiency. Most need to build a cake a little to start filtering well. The oil change guys make it a racket.
  6. Oct 20, 2019 at 3:55 PM
    neirbot
    neirbot New Member
    A clean one.
    ZappBrannigan likes this.
  7. Oct 20, 2019 at 4:34 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    You surely know why donkeys aren’t welcome at universities?
    Nobody likes a smart ass!
    Rica25, jewsNbrews, Kerch71 and 4 others like this.
  8. Oct 20, 2019 at 4:50 PM
    neirbot
    neirbot New Member
    I get that from my wife every day. But kidding aside, we're splitting hairs when it comes to different alr filter brands.
    Rica25 and gosolo[QUOTED][OP] like this.
  9. Oct 20, 2019 at 4:56 PM
    15whtrd
    15whtrd Mr. Blonde
    I’d say any paper filter. The more pleats the better. More surface area. I also believe in a slightly dirty filter is filtering the best. If you were to change your airbox, it seems that the S&B is the best filtering. I am using an afe dry filter. But when I go off road I switch it over to a paper OEM unit for the best filtration.
    Rica25 and Kerch71 like this.
  10. Oct 20, 2019 at 5:04 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Anything except for the stock paper filter will just drop your low end tq.
    Rica25 likes this.
  11. Oct 20, 2019 at 6:12 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    AFe super dry is a good one. I bought two. One I keep clean in my garage and the other on the air intake. When it's time to change, I pop the clean one in and save the dirty one to clean later and reuse.
    OR18TRD, Rica25 and omgboost like this.
  12. Oct 20, 2019 at 7:14 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Thanks for the responses, my friends.
    This is mostly as I expected.
    @15whtrd
    I’m not understanding why a dirty filter would be more efficient than a clean one. Can you explain that?
    Rica25 likes this.
  13. Oct 20, 2019 at 7:19 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    That's similar to what I do. I have the AEM dry filter and instead of buying two, I have one OEM filter that I will use when the AEM one is drying.
    619Tundra[QUOTED] likes this.
  14. Oct 20, 2019 at 7:54 PM
    15whtrd
    15whtrd Mr. Blonde
    Kind of silly but I feel like I’ve read it, and it makes sense to me. A semi clogged filter or “cake” as @7.62Tundra said, will be more restrictive but also less particulate will make it through.
  15. Oct 20, 2019 at 9:21 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    False. I enjoyed it immensely. Then again it does take one to know one so here we are.
    gosolo[QUOTED][OP] likes this.
  16. Oct 20, 2019 at 9:28 PM
    Aerindel
    Aerindel New Member
    Montana
    Pretty much anything that DOESN'T say K and N on it.
    Yota03, Hbjeff and ZappBrannigan like this.
  17. Oct 20, 2019 at 9:49 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The oe paper filter is plenty. It is a very very large filter for a small block v8. Plenty of air gets in
  18. Oct 21, 2019 at 7:00 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Here is a link that sort of shows testing. If you really want to understand the procedure it's ISO5011-2014.
    http://www.rubicon-trail.com/public/K&N filter test.html
    Basically it has been determined that particulate under 10um does not damage an engine. There has been a push over the past decade for higher efficiency fuel filters in diesels because the fuel rail pressures have come up significantly and finer particulate will erode injectors under high pressure. So many of the companies will use synthetic component in these type of filters to help increase capacity and cold performance. Synthetics flex more with cold temps
    A paper air filter is fine unless it going to see moisture like in severe off roading. If you look at the efficiency graph on the chart you will see they are all with a percent of each other 98.5% to say 99.5%. The graph meister who made the graph makes it look significant. It's basically the same filter efficiency.
  19. Oct 21, 2019 at 7:07 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    I have always use denso, pretty sure they make Toyota oem filter. I order from rockauto.
  20. Oct 21, 2019 at 8:03 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Dealers too. That is why I tell my daughter not to let them touch either filter.
  21. Oct 21, 2019 at 8:07 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Yep, they easily last a couple of years for an intake filter if you aren't on dirt roads. I look at mine and put them back in.
  22. Oct 21, 2019 at 8:09 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Same here and I will blow loose debris off
  23. Oct 21, 2019 at 12:27 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Stock filters just fine, until it gets dirty. Then, just replace it.
    YardBird and 7.62Tundra like this.
  24. Oct 21, 2019 at 12:35 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I agree 100%. Why waste money on something that results in no improvement. I never have bought in to the aftermarket air filter crap.
  25. Oct 21, 2019 at 4:27 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    After market air filters make sense for a race car that operates above 5k rpm all day and then gets rebuilt. Dirt gets right past a k+n and cannot be good for your engine. They should get a marketing award for still being in business
    YardBird likes this.
