What’s Stopping You?
Discussion in 'General Tundra Discussion' started by ItsAllAboutBallBearings, Sep 12, 2023.
  1. Sep 12, 2023 at 4:09 PM
    ItsAllAboutBallBearings [OP] New Member
    2016 Louisiana Edition
    Need to do a brake job on my 2016 and will be doing the work myself.
    Since I’m new to the Tundra, curious if y’all have any recommendations or issues with brands / models of rotors & pads.
  2. Sep 12, 2023 at 4:15 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I see what you did there. This topic will be a point of friction. It could get heated.
  3. Sep 12, 2023 at 4:33 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I did the fronts on mine, rotors were warped. I went with cryo rotors and yellow stuff pads. Easy job. Did same on a 21 RAV4. They stop great but create quite a bit of dust. Rims get dirty quick. Wife’s camry I did a power stop kit, all rotors and pads. Pretty happy with the kit and performance so far.
  4. Sep 12, 2023 at 6:57 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I use the stock stuff. It’s fine.
  5. Sep 12, 2023 at 6:58 PM
  6. Sep 13, 2023 at 3:53 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    I hear shims mentioned, can anyone elaborate on that? :hattip:
  7. Sep 13, 2023 at 5:58 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I did my rear brakes a month or so ago, also did the work myself. I used Advics rotors and pads, which I understand to be the OEM brand. I found them to be a very easy job, the most annoying part was adjusting the parking brake to seat right afterwards. I also noticed that for some reason, the back of the rotor has a lip on it that protrudes back far enough that it contacts part of the fixed framework that the calipers mount to…not the heat/dust shield, but some kind of guard in between that and the rotor. Previous wear on that part suggests my former rotors did the same thing. Apparently I’m not the only one who has experienced this because I found posts about it online. I am not too worried about it because it does not seem to impact brake function, and eventually they’ll stop grinding together.
  8. Sep 13, 2023 at 6:06 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If you're resurfacing your rotors ensure you have a good place that can turn them for you, otherwise you'll be looking for a while, like in my case, will probably have to travel 50 miles, because brake shops either don't have the machine, or is too small for the rotor to be completely turned.... I went Cryo treated slotted rotors.
  9. Sep 13, 2023 at 7:07 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I am not a fan of resurfacing rotors. In my experience once they start taking material off them, they tend to warp more easily. Given how cheap they are, relative to doing the job again in 10k miles, I find it better to just replace them.
    blackdemon_tt likes this.
  10. Sep 13, 2023 at 7:23 AM
    blackdemon_tt
    Not a fan of resurfacing either, I usually pad slap them and move on, but I have a rear rotor that was scratched up by sticking caliper so I went back to 1 OEM rotor all others are slotted cryo-treated. LOL.. These wont be back in stock until December, crazy.
  11. Sep 13, 2023 at 9:43 AM
    Bammer
    Monroe, CT
    My front rotors were resurfaced at 50k and new pads. 20k later, still good.
  12. Sep 13, 2023 at 9:48 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I've used Detroit Axle and PowerStop. No issues.
