What’s need to install TRD Pro dogs in 2017 Platinum?
Discussion in 'Lighting' started by meagain, Apr 9, 2024.
  1. Apr 9, 2024 at 7:58 AM
    meagain
    meagain [OP] New Member
    Hey all, I picked up some of the TRD Pro Rigid LED fog lights, and now need to install them. I received a pair of used lights and am awaiting arrival of the bezels. Are there any bolts or other pieces I need, or will I merely use what’s already on there? Will I remove hardware from the old bezels and round lights and use them with my new bezels and square lights?
    Thanks for the help, I haven’t actually found an install video here or elsewhere online, but with the popularity of the upgrade I assume I’m just not searching well.
  2. Apr 9, 2024 at 8:04 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    some say removing the bumper is the easiest way to change the fog lights. If you are using OEM parts everything should just bolt up and there should not be any problems. Everything you need should be there.
    when I did mine I just took it to the body shop and in 20 minutes they had it done and it cost me 100 dollars
    meagain[OP] likes this.
  3. Apr 9, 2024 at 8:08 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I may be barking up the wrong tree, but after a brief paws to reflect, I'm pretty sure you can just bolt them up with the existing hardware, the right collar bezels and plug the power leads in, pretty straightforward. Just howl here if you have more questions during installation and we'll sniff out some answers for you, it's no trouble to hound the forums here a little, no worries! Doggone easy install, no need to stress ahead of time at all.
    BillyB, AZBoatHauler, Mater and 3 others like this.
  4. Apr 9, 2024 at 8:11 AM
    MedCityMoto
  5. Apr 9, 2024 at 8:28 AM
    meagain
    Haha thanks guys, that was fast! And appreciate the humor @MedCityMoto
