Westcott Preload Collar
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bigslick43, Feb 13, 2021.
  1. Feb 13, 2021 at 11:23 AM
    Bigslick43
    Bigslick43 [OP] New Member
    Napa, CA
    2019 Super White TRD PRO
    SDHQ Sliders Line-X Bed Liner All Weather Floor Matts Westcott Designs Preload Collars Lift Kit Method MR312 18x9 +18 OS Toyo Open Country RT 35”x12.5”x18”
    I just ordered my Westcott Designs preload collar kit for my 2019 Pro. I want to run Method MR312 18x9 w/+18 OS with Toyo RT’s 35x12.5x18 tires. Do you think I will end up rubbing or need a BMC?
  2. Feb 13, 2021 at 11:39 AM
    TheBeast The Beach
    with +18 offset and a good alignment you might be ok.
    You might have to shim front bumper a bit.
    coachbuilder has some good options for running 35's on stock Pros.
    Bigslick43[OP] likes this.
  3. Feb 13, 2021 at 11:57 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    OE arms and +18 you are going to more than likwly need a CMC IMO. I dont think OE has enough to give you the caster you'll need with your setup.
    Hopefully someone with your setup will post up to confirm 100%.
    Good luck
  4. Feb 14, 2021 at 10:47 AM
    bceez
    bceez New Member
    21 TRD pro
    I just had the Westcott kit installed on my 21 pro. I’m running Toyo AT3 35/12.5R18 and had to do bmc and some bumper trimming. I can also tell you your truck is going to look killer!! I wasn’t expecting anything crazy since it’s only
    1.5 inches but it blew my mind how good it turned out. Let me know if you want pictures and I will throw some up.
  5. Feb 14, 2021 at 11:05 AM
    Bigslick43
    Napa, CA
    Send them bro! I can’t wait to get it all installed.what OS are your wheels? If stock wheels did you add spacers?
  6. Feb 14, 2021 at 11:06 AM
    bceez
    bceez New Member
    21 TRD pro
    Can do my man. I’m running Stealth SR8s. Dude your gonna love the end result!!! Will post some pictures here in a few.
  7. Feb 14, 2021 at 11:06 AM
    bceez
    bceez New Member
    21 TRD pro
    25mm offset
  8. Feb 14, 2021 at 11:46 AM
    bceez
    bceez New Member
    21 TRD pro
    Can do my man. I just caught a typo in my first post, my bad for not proof reading. I did NOT have to do a body mount chop but did have to do some front bumper work.
  9. Feb 14, 2021 at 11:48 AM
    bceez
    bceez New Member
    21 TRD pro
    Bigslick43, Pics aren’t great but If you find yourself in auburn area come on by! You can check it out
    robertz81 and Bigslick43[OP] like this.
  10. Feb 14, 2021 at 11:54 AM
    Bigslick43
    Napa, CA
    Your truck looks awesome. Thanks for the pictures.
  11. Feb 14, 2021 at 11:56 AM
    Bigslick43
    Napa, CA
    Perfect height. I love that stuffed look! The tires fill the wheel wells perfectly!
  12. Feb 14, 2021 at 11:57 AM
    bceez
    bceez New Member
    21 TRD pro
    Thank you sir.
  13. Feb 14, 2021 at 11:58 AM
    bceez
    bceez New Member
    21 TRD pro
    Post some pictures when your truck is done!! Excited for you my dude.
  14. Feb 14, 2021 at 12:30 PM
    Bigslick43
    Napa, CA
    I will but it will be 6-8 weeks. Not sure why they quoted me so long. Just ordered it all last week.
