Went from 33 to 35, now hearing rubbing noise
Discussion in '2nd Gen Tundras (2007-2013)' started by Rozr1, Jun 3, 2023.
  1. Jun 3, 2023 at 3:44 PM
    Rozr1
    Rozr1 [OP] New Member
    2008 SR5 DC
    Hey guys, just put in new 35 milestar Patagonia on my 08 tundra and soon as I left discount tire I heard rubbing noise when doing full a turn. I thought a 6in lift was more then enough for 35 tires. Has anyone had issues with rubbing on 6in and 35 tires?
    D4x4TRD likes this.
  2. Jun 10, 2023 at 5:31 PM
    YoungManTan
    YoungManTan New Member
    San Diego
    2008 Desert Sand Tundra 5.7 Crew Cab 7Ft bed
    Billstien 5100 in front, .5” spacers, serviceable drive shaft u-joints, 18” Vision Nemesis Wheels, Kenwood touchscreen head unit
    I heard that if the mud flaps are installed they will still rub. I could be wrong tho…
  3. Jun 10, 2023 at 5:42 PM
    What is your wheel offset? A few common places to check......the small mudflap this is bolted to the bumper down at the bottom (held on by 2 bolts), the forward side of the wheel well liner itself, and the cab mount. You may need a cab mount chop.
  4. Jun 10, 2023 at 5:44 PM
    That is common. Depends on the tire size and wheel offset.
  5. Jun 10, 2023 at 5:48 PM
    YoungManTan
    San Diego
    I didn’t think about the wheel offset :monocle:
    Black Wolf likes this.
  6. Jun 10, 2023 at 5:53 PM
    For what it's worth....those Patagonia's are quite decent. Go back to Discount. They'll correct your issue.
  7. Jun 14, 2023 at 7:03 PM
    lake
    lake New Member
    i had same issue - i had to cut and melt part of the inner wheel well.
    I've got a 4.5 lift with 35 inch grapplers
  8. Jun 15, 2023 at 10:11 PM
    Rozr1
    2008 SR5 DC
    Truck doesn't have mud flaps up front guessing previous owner removed them
    I don't know my offset since I never measured it, but my wheels stick out a little so it's negative...so far just seen rubbing marks on the front liner. It appears to clear the rear inner mine just fine.
    Do you mean correcting issue by suggesting a smaller tire?
    Looks like I might have to do something similar myself, hopefully I can get to it this weekend.
  9. Jun 15, 2023 at 10:27 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If the rubbing is minimal on the liner, you can always try just heating it up a bit and 're-shaping' it to create a little additional space.
    Another common place for 35s to rub at full lock is the sway bar. I'd take a peek at that as well before you finalize your plan of attack.
  10. Jun 15, 2023 at 10:45 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    2.5 could move the front liner an inch, there are bolts under the front bumper, just need to take it out move the liner forward and drill new holes
  11. Jun 20, 2023 at 5:54 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
