Went Camping, not stoked on saggy backend
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by dhbrown, Apr 19, 2021.
  1. Apr 19, 2021 at 9:15 PM
    dhbrown
    dhbrown [OP] New Member
    2019 TRD Pro, black
    I went camping for the first time with my 2019 TRD Pro (just bought it Jan). Brought the big tent, the full kitchen setup (cast irons, etc), 5 gallons of water, Yeti 45, and my EBIKE on the rack bike rack. The truck dropped nearly down to the bump stops... No joke, I only had an half an inch left.
    Pretty bummed this suspension can't handle a pretty basic weekend setup... My old Tacoma w/ Old Man Emu springs and shocks wouldn't have heaved a sigh, while charging washboards no problem.
    I'm not looking to swap the springs or suspension until I blow it up, but what about an add-a-leaf? What have you guys done?
    IndianaGeologist likes this.
  2. Apr 20, 2021 at 12:06 AM
    Bigboitundra
    Bigboitundra New Member
    2018 tundra crewmax
    7 inch lift
    Air bags. That’s what I did with my truck. And a compressor.. it sucks how bad the rear end is on these trucks
    JCBerb, ATV25, 2undra and 2 others like this.
  3. Apr 20, 2021 at 12:15 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Poke around the forum a little bit and you’ll see more stories of woe in regards to the tundras payload capacity.
    DeesCrewMax likes this.
  4. Apr 20, 2021 at 4:46 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Too many of you guys are overthinking this issue. Why spend all that money on "Airbags" and compressors, that WILL fail sooner or later? Take the smart way out, and install longer "SHACKLES". They fix the problem and never require any maintenance.
    Work smarter, not harder.
    bulldog93, avssuc, AggiePhil and 8 others like this.
  5. Apr 20, 2021 at 4:49 AM
    Professional Hand Model
    Hand Protectors
    I believe you. I think the Honda Ridgeline has more haul cap than the 3rd Gen. Might be time to sell or trade into a 1st Gen Tundra.
  6. Apr 20, 2021 at 4:53 AM
    IndianaGeologist
    IndianaGeologist New Member
    You could give sumo springs a try. Affordable and simple to install. Looking to get myself a set.
  7. Apr 20, 2021 at 5:11 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  8. Apr 20, 2021 at 5:15 AM
    Willard
    Willard New Member
    2024 F250
    You bought a trim level that comes with a leveled, plush suspension, so it’s always going to appear to sag when you put anything in the bed.
  9. Apr 20, 2021 at 5:22 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I installed Roadmaster Active Suspension (RAS) on my 2017 Limited DC w/TRD package. Lifted the rear about 1.5" so it has a bit of a rake which I like. Sits level when towing my TT with a WDH - about 1,000 lbs static tongue weight.
  10. Apr 20, 2021 at 5:27 AM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    I just bought my first TT and the sales guy tried talking me into a WDH. LITTLE DID I KNOW how important they are. I did some research while I was sitting there waiting to sign paperwork and went ahead and changed my mind. My truck barely squats at all. It was money VERY well spent... and apparently, not all sales dudes are pure filth.
  11. Apr 20, 2021 at 5:54 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    OP, any idea how much all that stuff in your bed weighs? It's probably worth figuring out. @Willard has a great point about the front ride height of the PRO contributing to the appearance of sag.
    I was curious whether my leaf springs were worn out or not a couple years ago, before I leveled my truck. They certainly looked flat to me. So, I conducted an experiment to see. I parked on level ground with an empty bed and measured from center of hub to fender, then incrementally added weight to the bed and measured. The little table below summarizes my findings...1,380#--essentially my entire payload--in the bed resulted in zero rake (the cab was also empty). This experiment was done with completely stock, ten year old suspension components front and rear. If my truck had been leveled like the PRO at the time, a mere 540# in the bed would have produced negative rake.
  12. Apr 20, 2021 at 8:09 AM
    dhbrown
    2019 TRD Pro, black
    What is WDH?
    I'll probably just add a leaf. Way better than shackles, and not the production as airbags. Cheap too.
  13. Apr 20, 2021 at 8:23 AM
    BlackSheep
    Scott
    Kansas City, MO
    weight distribution hitch
    in what way is AAL better than shackles? I would take the opposite position.
  14. Apr 20, 2021 at 11:28 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
  15. Apr 20, 2021 at 12:59 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Once you tell us what all that gear weighs, we'll know why it's sagging.
    Saltyhero13 likes this.
  16. Apr 20, 2021 at 4:03 PM
    Elduder
    Elduder New Member
    Sumosprings are a cheap and easy option.
  17. Apr 20, 2021 at 6:50 PM
    dhbrown
    2019 TRD Pro, black
    Here's my rough estimate on how much everything weighs:
    Yakima HD towers and crossbars - 30 lbs
    Retrax Tonneau Cover - 90 lbs
    2 water jugs (2.5 gallons) - 45 lbs
    American Van drawer - 50 lbs
    Miscellaneous camp gear - 30 lbs
    Yeti 45 cooler, packed - 50 lbs
    E bike and motorcycle hitch rack -- 300 lbs
    Total 595 lbs.
    In my opinion that is not that much. These numbers are not 100 percent, but I would say, total weight is actually lighter than this.
    I'm going to add a leaf. Seems to be the most logical.
  18. Apr 24, 2021 at 12:23 PM
    Downytide
    GTA
    OP, just got my truck back from bunch of work, during the downtime I had the dealer install RAS, it definitely sits bit higher now, and I have about 200lbs of stuff in the bed all the time, I don't notice any more firmness on normal road, but it felt like I added rear sway bar during corners.
    Rear no longer sags.
  19. Apr 25, 2021 at 5:39 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Hey Downytide, Curious question could you have gone with the Coachbuilder plus one or two to raise the back to keep it from squatting. Thanks.
  20. Apr 25, 2021 at 5:54 AM
    Sunnier
    Sunny
    San Diego, CA
    OP you can add a leaf, sounds like you kinda decided to do this before you posted, and just wanted to let others know you’re disappointed with the crappy payload. Most on here have not been impressed with add a leaf— essentially, you can count on the actual depth of the added leaf, but it won’t stop the sag happening.
    dhbrown[QUOTED][OP] likes this.
  21. Apr 25, 2021 at 6:07 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Over time, the add a leaf will probably conform to the rest of the leaf pack.
    You are not experiencing abnormal sag. You instead bought a truck with a level static stance. There is a reason trucks sit higher in the back when empty. Any leveled truck will “sag” with a small load
  22. Apr 25, 2021 at 6:37 AM
    BlackSheep
    Scott
    Kansas City, MO
    this has been my experience with AALs. And, it doesn’t take very long to happen, either. My shackles, however, have provided consistent lift for over two years with constant weight in the bed of 300-400#. And, improve the ride quality, thanks to replacing the stock rubber spring bushing with poly.
  23. Apr 25, 2021 at 7:46 AM
    Downytide
    GTA
    Probably, but I do tow, so the RAS were added mainly to aid towing, I don't think the coachbuilder kit would help much with that.
    RusPro21[QUOTED] likes this.
  24. Apr 27, 2021 at 8:24 AM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    DO NOT do an add a leaf. I went with the @Icon_Adrian add a leaf a couple years ago and all I've had are problems with squeaking. They seem to hold fine when towing, but I've taken my truck back to the shop 3 times in the last two years to get them to work on the squeak. Seems like add a leaf manufacturers aren't able to build their add a leaf to fit perfectly with OEM leafs. Now I'm considering going completely back to stock on leafs and adding lift shackles. The other option is to replace the whole leaf pack, but that's the pricier option. Just my two cents.
  25. Apr 27, 2021 at 9:06 AM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Agree with SoCalTundy. You can add a leaf as a cheaper option for now, but if going that route might as well change out the whole leaf kit. Unless you don't mind hearing your truck bed squeak when it bounces. This is my rear setup: Coachbuilder Shackles +2 (1.25 inch lift) and SumoSprings. Bilstein 6112 set @ 1.9" in front.
    Rear is approx. 1" higher than the front, but levels out nicely when towing/hauling.
  26. Apr 27, 2021 at 10:16 AM
    SoCalTundy
    What’s the purpose of the sumosprings? Is it like a bump stop? I didn’t come across these in my research when I lifted my truck 2.5 years ago.
  27. Apr 27, 2021 at 10:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Sumo springs are supplemental. Imagine them as a foam “airbag”. I have the lightest ones on mine. They work fantastic for hauling, but you cannot run them unloaded it is punishing
    15whtrd and SoCalTundy like this.
  28. Apr 27, 2021 at 10:29 AM
    SoCalTundy
    10-4. I tow a few times a year and even then it’s just a utility trailer with dirt toys. Probably not worth considering them for me.
  29. Apr 27, 2021 at 10:45 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I hear ya. My TT is pretty small so a lot of stuff gets loaded in my bed, which the sumos are fantastic for. I will be following the lead of another forum member and ordering a second set, then trimming them down to be normal bumpstops. This way i can have a daily driving and a hauling setup with a quick swap
    SoCalTundy[QUOTED] likes this.
  30. Apr 28, 2021 at 12:59 AM
    Quicksand_Tundra
    Jon
    Yes. Upgraded bump stop to help enhance load carrying ability, and stabilize ride. Happy with setup.
