Well, the hyper flash is disappointing!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Black, May 15, 2021.
  1. May 15, 2021 at 2:19 PM
    Black
    Black [OP] Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Just did the TRD Pro headlights with @iHacker harness.
    A bunch of reviews and YouTube videos said that these particular JDM Astar bulbs won’t cause hyper flash like other bulbs do.
    Well that is not the case for me at least. Put the flashers on first and she was nice and slow as she should be. Popped that right turn signal on and she goes haywire!
    JDM ASTAR Extremely Bright PX Chips 7440 7441 7443 7444 Amber Yellow Turn Signal LED Bulbs https://smile.amazon.com/dp/B00PHVU..._glt_fabc_VQ6ATMNYPF75GRRRE0C2?_encoding=UTF8
  2. May 15, 2021 at 2:24 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    That is really only applicable to 2018 plus trucks that came with led headlights from the factory. I’m using led blinkers with no resistor on my 18’ that came with led headlights. If you’re doing the conversion and using the harness, you still have to use resistors. Hazards are not controlled through the ecu. It’s just an on/off switch. Blinkers go through the ecu. The ecu detects a low pull on the circuit and hyper flashes to indicate a bulb is out. That’s why hazards will blink normally but blinkers will hyper flash.
    1lowlife and CCLJ03 like this.
  3. May 15, 2021 at 2:26 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Yeah it’s only 2018 and up. Something about the headlights being LED means the wiring is capable of handling front LED indicators without resistors.
  4. May 15, 2021 at 3:21 PM
    Black
    Ah. Thanks for the clarification.
  5. May 15, 2021 at 4:42 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Resistors are easy to add. I didn’t have to do it on my fronts, but still had to in my rear turns
  6. May 15, 2021 at 6:38 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I have those installed on my 2021 Limited, no hyper flash experience here. Interesting.
  7. May 15, 2021 at 6:41 PM
    Danman34
    Danman34 New Member
    Danny
    Your truck came with factory led headlights. The circuitry and wiring is different than non factory led headlight equipped trucks.
    KingsAustin[QUOTED] likes this.
